1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Open .opi filenames with spaces from command line?
To: "'J. Lewis Muir'" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 29 May 2018 17:20:30 +0000
> I assume you also set the P and R macros in CSS under Preferences -> CSS Applications -> Display -> BOY -> OPI Runtime?  (Or one of the methods noted in [1]?)
No, because I am using top-level screens like ADTop.opi that don't require P and R to be set, they hard-code them for the displays they launch.
> I was trying to avoid compiling medm for Windows and installing an X11 server on Windows.
There is no need to compile medm for Windows.  There is a nice msi installer for the EPICS Windows Tools (medm, command line utilites, etc.) here:
https://epics.anl.gov/distributions/win32/
We have been using the MobaXterm program as the X11 server.  It is very nice, with good ssh client and is available for free or for a small fee if you want support.
https://mobaxterm.mobatek.net/
-----Original Message-----
Sent: Tuesday, May 29, 2018 10:47 AM
Subject: Re: Open .opi filenames with spaces from command line?
On 05/29, Mark Rivers wrote:
> I then open CSS with no command line arguments and then use File/Open
> in CSS to open the top-level display, for example ADTop.opi.  From
> there I can open simDetector.opi and all related displays, and CSS
> will find them with no problem because they are all in the same
> directory as ADTop.opi.
Hi, Mark!
Thanks for sharing your method.  I'll try that.  I assume you also set the P and R macros in CSS under Preferences -> CSS Applications -> Display -> BOY -> OPI Runtime?  (Or one of the methods noted in [1]?)
I was thinking that CSS would be the fastest works-out-of-the-box solution for areaDetector and plugin displays under Windows, but now I'm not so sure.  I was trying to avoid compiling medm for Windows and installing an X11 server on Windows.  But maybe I'm close with CSS, and if I can accept the inconvenience of not being able to start a display from the command line, it will still be fine.
Thanks!
Lewis
[1] https://epics.anl.gov/tech-talk/2012/msg00375.php
Open .opi filenames with spaces from command line? J. Lewis Muir
RE: Open .opi filenames with spaces from command line? Mark Rivers
Re: Open .opi filenames with spaces from command line? J. Lewis Muir
Prev: Re: Open .opi file from command line with CSS Display Builder? Kasemir, Kay
Next: R3.15 camonitor formatting Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Open .opi filenames with spaces from command line? J. Lewis Muir
Next: A recent R3.15.5 Patch file Jeong Han Lee
ANJ, 30 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
