1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Transfering array of 256 elements to driver
To: 'Jörn Dreyer' <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 31 May 2018 14:11:00 +0000
> Hi Mark and Michael,
> her is how I configured the waveform record:
> record(waveform, $(P)$(R)$(I):DelayTimeA) {
> 	field (DESC,	"Delay of channel A")
> 	field (DTYP,	"asnyInt32ArrayOut")
> 	field (OUT,		"@asyn($(PORT), 0, 100) DELAYTIMEA")
> 	field (FTVL, 	"LONG")
> 	field (NELM, 	"256")
> At IOC startup I get the following error message:
> >Can't set "XXX:Test1:DelayTimeA.DTYP" to "asnyInt32ArrayOut"
> >Error at or before ")" in file "db/Delay.db" line 355
> >Record "XXX:Test1:DelayTimeA" does not have a field "OUT"
> This somehow contradicts the information. And the record reference manual
> defines also onle the INP field for the waveform record.
Perhaps the OUT field is misnamed: instead for waveform it just means "data", and it's up to the device support to decide how to treat it.  You can even read the data some of the time and write at other times (yes, occasionally this makes sense).
Re: Transfering array of 256 elements to driver Andrew Johnson
Transfering array of 256 elements to driver Jörn Dreyer
RE: Transfering array of 256 elements to driver [email protected]
Re: Transfering array of 256 elements to driver Mark Rivers
Re: Transfering array of 256 elements to driver Jörn Dreyer
Prev: Re: Transfering array of 256 elements to driver Mark Rivers
Next: Re: Transfering array of 256 elements to driver Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
