1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Transfering array of 256 elements to driver
To: Jörn Dreyer <[email protected]>
Date: Thu, 31 May 2018 14:00:17 +0000
You also have OUT where it must be INP even for output records.
Sent from my iPhone
> On May 31, 2018, at 8:57 AM, Mark Rivers <[email protected]> wrote:
> You have a typo in your DTYP.
> Sent from my iPhone
>> On May 31, 2018, at 8:28 AM, Jörn Dreyer <[email protected]> wrote:
>> Hi Mark and Michael,
>> her is how I configured the waveform record:
>> record(waveform, $(P)$(R)$(I):DelayTimeA) {
>> field (DESC,    "Delay of channel A")
>> field (DTYP,    "asnyInt32ArrayOut")
>> field (OUT,        "@asyn($(PORT), 0, 100) DELAYTIMEA")
>> field (FTVL,    "LONG")
>> field (NELM,    "256")
>> At IOC startup I get the following error message:
>>> Can't set "XXX:Test1:DelayTimeA.DTYP" to "asnyInt32ArrayOut"
>>> Error at or before ")" in file "db/Delay.db" line 355
>>> Record "XXX:Test1:DelayTimeA" does not have a field "OUT"
>> This somehow contradicts the information. And the record reference manual
>> defines also onle the INP field for the waveform record.
>> Regards,
>> Jörn
>> Am Donnerstag, 31. Mai 2018, 15:01:35 CEST schrieb Mark Rivers:
>>> Hi Jörn
>>>> The waveform record supports only INP direction.
>>> The devAsynInt32Array.dbd file defines both input and output.
>>> corvette:asyn/asyn/devEpics>more devAsynInt32Array.dbd
>>> device(waveform,INST_IO,asynInt32ArrayWfIn,"asynInt32ArrayIn")
>>> device(waveform,INST_IO,asynInt32ArrayWfOut,"asynInt32ArrayOut")
>>> Your waveform record would use DTYP="asynInt32ArrayOut".
>>> Mark
>>> ________________________________
>>> From: [email protected] <[email protected]> on
>>> behalf of [email protected] <[email protected]> Sent:
>>> Thursday, May 31, 2018 7:54 AM
>>> To: 'Jörn Dreyer'; [email protected]
>>> Subject: RE: Transfering array of 256 elements to driver
>>> From: [email protected] [mailto:[email protected]]
>>>> I'm working on a driver that needs to set 256 values into one hardware
>>>> register. What type of database record should I use for this purpose?
>>> In fact this is not so: you can write in either direction when processing
>>> the record, it's up to the device driver to decide whether to push or pull
>>> waveform data, so the waveform record will be what you need.
>>> This e-mail and any attachments may contain confidential, copyright and or
>>> privileged material, and are for the use of the intended addressee only. If
>>> you are not the intended addressee or an authorised recipient of the
>>> addressee please notify us of receipt by returning the e-mail and do not
>>> use, copy, retain, distribute or disclose the information in or attached to
>>> the e-mail. Any opinions expressed within this e-mail are those of the
>>> individual and not necessarily of Diamond Light Source Ltd. Diamond Light
>>> Source Ltd. cannot guarantee that this e-mail or any attachments are free
>>> from viruses and we cannot accept liability for any damage which you may
>>> sustain as a result of software viruses which may be transmitted in or with
>>> the message. Diamond Light Source Limited (company no. 4375679). Registered
>>> in England and Wales with its registered office at Diamond House, Harwell
>>> Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United
>>> Kingdom
>> Dr. Joern Dreyer
>> HIBEF DAQ + Controls
>> Institut für Strahlenphysik
>> Helmholtz-Zentrum Dresden - Rossendorf e.V
>> Abt. FWKX                Tel: +49 351 260 3263
>>                                FAX: +49 351 260 3700
>> 01314 Dresden        eMail: [email protected]
>> Helmholtz-Zentrum Dresden - Rossendorf e.V (HZDR)
>> Bautzner Landstraße 400, 01328 Dresden
>> Vorstand: Prof. Dr. Dr. h. c. Roland Sauerbrey, Dr. Ulrich Breuer
>> Vereinsregister: VR 1693 beim Amtsgericht Dresden
Transfering array of 256 elements to driver Jörn Dreyer
RE: Transfering array of 256 elements to driver [email protected]
Re: Transfering array of 256 elements to driver Mark Rivers
Re: Transfering array of 256 elements to driver Jörn Dreyer
Prev: Re: Transfering array of 256 elements to driver Mark Rivers
Next: RE: Transfering array of 256 elements to driver [email protected]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
