Hi Catharina,
I can reproduce your problem, but I have a workaround.
The problem is that it finds the libpvcam.so at link time, but not at run time.
Here is the output of ldd on the application file. Note that it cannot find libpvcam.so.
corvette:pvcamIOC/bin/linux-x86>ldd pvCamApp
linux-gate.so.1 => (0xf7719000)
libpvcam.so => not found
libraw1394.so.11 => /lib/libraw1394.so.11 (0xf76ef000)
libX11.so.6 => /lib/libX11.so.6 (0xf75b3000)
libXext.so.6 => /lib/libXext.so.6 (0xf75a0000)
libpthread.so.0 => /lib/libpthread.so.0 (0xf7584000)
libreadline.so.6 => /lib/libreadline.so.6 (0xf7547000)
librt.so.1 => /lib/librt.so.1 (0xf753e000)
libdl.so.2 => /lib/libdl.so.2 (0xf7539000)
libstdc++.so.6 => /lib/libstdc++.so.6 (0xf744e000)
libm.so.6 => /lib/libm.so.6 (0xf740c000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xf73f0000)
libc.so.6 => /lib/libc.so.6 (0xf7230000)
libxcb.so.1 => /lib/libxcb.so.1 (0xf7205000)
/lib/ld-linux.so.2 (0x56638000)
libtinfo.so.5 => /lib/libtinfo.so.5 (0xf71e3000)
libXau.so.6 => /lib/libXau.so.6 (0xf71df000)
Trying to run the application leads to an error as expected:
corvette:pvcamIOC/iocBoot/iocPvCam>../../bin/linux-x86/pvCamApp st.cmd
../../bin/linux-x86/pvCamApp: error while loading shared libraries: libpvcam.so: cannot open shared object file: No such file or directory
However, I can work around the problem by adding the ADPvCam/lib/linux-x86 directory to LD_LIBRARY_PATH:
corvette:pvcamIOC/iocBoot/iocPvCam>setenv LD_LIBRARY_PATH /home/epics/devel/areaDetector/ADPvCam/lib/linux-x86:$LD_LIBRARY_PATH
Then the application starts OK:
errlogInit(20000)
< envPaths
epicsEnvSet("ARCH","win32-x86")
epicsEnvSet("IOC","iocPVCam")
epicsEnvSet("TOP","J:/epics/devel/areaDetector-1-10")
epicsEnvSet("SUPPORT","J:/epics/devel")
epicsEnvSet("ASYN","J:/epics/devel/asyn-4-22")
epicsEnvSet("CALC","J:/epics/devel/calc-3-2")
LD_LIBRARY_PATH is not a very elegant solution, there should be a better way of doing this.
-----Original Message-----
Sent: Wednesday, June 6, 2018 8:54 AM
To: Mark Rivers <[email protected]>; [email protected]
Subject: AW: ADPvcam: can't create IOC because of missing build (bin) folder
Hi Mark,
Thanks for your answer.
I managed to get the bin folder for ADPvCam, this is my output:
txmuser@xmasctrl:/opt/epics/support_test_area/areaDetector/ADPvCam$ make -sj clean uninstall
txmuser@xmasctrl:/opt/epics/support_test_area/areaDetector/ADPvCam$ make make -C ./configure install
make[1]: Entering directory '/opt/epics/support_test_area/areaDetector/ADPvCam/configure'
perl /opt/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install
make[2]: Entering directory '/opt/epics/support_test_area/areaDetector/ADPvCam/configure/O.linux-x86_64'
perl /opt/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory '/opt/epics/support_test_area/areaDetector/ADPvCam/configure/O.linux-x86_64'
make[1]: Leaving directory '/opt/epics/support_test_area/areaDetector/ADPvCam/configure'
make -C ./pvcamSupport install
make[1]: Entering directory '/opt/epics/support_test_area/areaDetector/ADPvCam/pvcamSupport'
mkdir O.Common
make[2]: Entering directory '/opt/epics/support_test_area/areaDetector/ADPvCam/pvcamSupport/O.linux-x86_64'
Installing generic include file ../../include/pvcam.h mkdir ../../include Installing generic include file ../../include/pv_icl.h Installing os dependent include file ../../include/os/Linux/master.h mkdir ../../include/os mkdir ../../include/os/Linux Installing libpvcam.so mkdir ../../lib mkdir ../../lib/linux-x86_64
make[2]: Leaving directory '/opt/epics/support_test_area/areaDetector/ADPvCam/pvcamSupport/O.linux-x86_64'
make[1]: Leaving directory '/opt/epics/support_test_area/areaDetector/ADPvCam/pvcamSupport'
make -C ./pvcamApp install
make[1]: Entering directory '/opt/epics/support_test_area/areaDetector/ADPvCam/pvcamApp'
make -C ./src install
make[2]: Entering directory '/opt/epics/support_test_area/areaDetector/ADPvCam/pvcamApp/src'
perl /opt/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[3]: Entering directory '/opt/epics/support_test_area/areaDetector/ADPvCam/pvcamApp/src/O.linux-x86_64'
Installing dbd file ../../../dbd/pvCamSupport.dbd mkdir ../../../dbd
make[3]: Leaving directory '/opt/epics/support_test_area/areaDetector/ADPvCam/pvcamApp/src/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/support_test_area/areaDetector/ADPvCam/pvcamApp/src'
make -C ./Db install
make[2]: Entering directory '/opt/epics/support_test_area/areaDetector/ADPvCam/pvcamApp/Db'
mkdir O.Common
make[3]: Entering directory '/opt/epics/support_test_area/areaDetector/ADPvCam/pvcamApp/Db/O.linux-x86_64'
Installing db file ../../../db/pvCam.template mkdir ../../../db
make[3]: Leaving directory '/opt/epics/support_test_area/areaDetector/ADPvCam/pvcamApp/Db/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/support_test_area/areaDetector/ADPvCam/pvcamApp/Db'
make[1]: Leaving directory '/opt/epics/support_test_area/areaDetector/ADPvCam/pvcamApp'
make -C ./iocs install
make[1]: Entering directory '/opt/epics/support_test_area/areaDetector/ADPvCam/iocs'
make -C ./pvcamIOC install
make[2]: Entering directory '/opt/epics/support_test_area/areaDetector/ADPvCam/iocs/pvcamIOC'
make[3]: Entering directory '/opt/epics/support_test_area/areaDetector/ADPvCam/iocs/pvcamIOC/configure'
mkdir O.Common
make[4]: Entering directory '/opt/epics/support_test_area/areaDetector/ADPvCam/iocs/pvcamIOC/configure/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/support_test_area/areaDetector/ADPvCam/iocs/pvcamIOC/configure/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/support_test_area/areaDetector/ADPvCam/iocs/pvcamIOC/configure'
make[3]: Entering directory '/opt/epics/support_test_area/areaDetector/ADPvCam/iocs/pvcamIOC/pvcamApp'
make[4]: Entering directory '/opt/epics/support_test_area/areaDetector/ADPvCam/iocs/pvcamIOC/pvcamApp/src'
mkdir O.Common
make[5]: Entering directory '/opt/epics/support_test_area/areaDetector/ADPvCam/iocs/pvcamIOC/pvcamApp/src/O.linux-x86_64'
perl /opt/epics/base/bin/linux-x86_64/makeIncludeDbd.pl pvCamSupport.dbd base.dbd NDPluginSupport.dbd ADSupport.dbd NDFileNull.dbd NDFileNetCDF.dbd NDFileMagick.dbd NDFileTIFF.dbd NDFileJPEG.dbd NDFileNexus.dbd NDFileHDF5.dbd asyn.dbd asSupport.dbd busySupport.dbd calcSupport.dbd sscanSupport.dbd pvCamAppInclude.dbd echo "../O.Common/pvCamAppInclude.dbd : ../Makefile" >> pvCamApp.dbd.d Expanding dbd Installing created dbd file ../../../dbd/pvCamApp.dbd mkdir ../../../dbd
make[5]: Leaving directory '/opt/epics/support_test_area/areaDetector/ADPvCam/iocs/pvcamIOC/pvcamApp/src/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/support_test_area/areaDetector/ADPvCam/iocs/pvcamIOC/pvcamApp/src'
make[3]: Leaving directory '/opt/epics/support_test_area/areaDetector/ADPvCam/iocs/pvcamIOC/pvcamApp'
make -C ./iocBoot install
make[3]: Entering directory '/opt/epics/support_test_area/areaDetector/ADPvCam/iocs/pvcamIOC/iocBoot'
make -C ./iocPvCam install
make[4]: Entering directory '/opt/epics/support_test_area/areaDetector/ADPvCam/iocs/pvcamIOC/iocBoot/iocPvCam'
make[4]: Nothing to be done for 'install'.
make[4]: Leaving directory '/opt/epics/support_test_area/areaDetector/ADPvCam/iocs/pvcamIOC/iocBoot/iocPvCam'
make[3]: Leaving directory '/opt/epics/support_test_area/areaDetector/ADPvCam/iocs/pvcamIOC/iocBoot'
make[2]: Leaving directory '/opt/epics/support_test_area/areaDetector/ADPvCam/iocs/pvcamIOC'
make[1]: Leaving directory '/opt/epics/support_test_area/areaDetector/ADPvCam/iocs'
txmuser@xmasctrl:/opt/epics/support_test_area/areaDetector/ADPvCam$ ls
configure dbd include lib pvcamApp README.md
db documentation iocs Makefile pvcamSupport RELEASE.md
txmuser@xmasctrl:/opt/epics/support_test_area/areaDetector/ADPvCam$ ls iocs/pvcamIOC/bin/linux-x86/ pvCamApp txmuser@xmasctrl:/opt/epics/support_test_area/areaDetector/ADPvCam$
But I can't start the IOC:
txmuser@xmasctrl:/opt/epics/support_test_area/areaDetector/ADPvCam$ cd iocs/pvcamIOC/iocBoot/iocPvCam/ txmuser@xmasctrl:/opt/epics/support_test_area/areaDetector/ADPvCam/iocs/pvcamIOC/iocBoot/iocPvCam$ ../../bin/linux-x86/pvCamApp ./st.cmd
../../bin/linux-x86/pvCamApp: error while loading shared libraries: libpvcam.so: cannot open shared object file: No such file or directory txmuser@xmasctrl:/opt/epics/support_test_area/areaDetector/ADPvCam/iocs/pvcamIOC/iocBoot/iocPvCam$
I will try ADPICam as suggested.
Catharina
Von: Mark Rivers [[email protected]]
Gesendet: Dienstag, 29. Mai 2018 14:24
An: Häbel, Catharina; [email protected]
Betreff: Re: ADPvcam: can't create IOC because of missing build (bin) folder
Hi Catharina,
I don't think the ADPvCam software will work for that camera. It is complicated, but PvCam was written by Photometrics. Photometrics and Princeton Instruments are both part of Roper Scientific, and some older Princeton Instruments cameras do work with PvCam.
However, recent Princeton cameras do not work with PvCam, they only work with the new PICam from Princeton. PICam is the underlying library for LightField, which is their end-user software. PICam is free, while LightField costs money. LightField runs on Windows only.
There are 2 areaDetector drivers that should work with your SOPHIA-X0 camera:
- ADPICam (Windows and Linux, though their Linux support is poorly documented. It is mentioned in this manual:
ftp://ftp.piacton.com/Public/Manuals/Princeton%20Instruments/PICam%205.x%20Programmers%20Manual.pdf)
- ADLightField (Windows only)
Sent: Monday, May 28, 2018 4:14 PM
To: Häbel, Catharina; [email protected]
Subject: Re: ADPvcam: can't create IOC because of missing build (bin) folder
Hi Catharina,
> I have used the areaDetector R3-2 and the ADPvCam R2-2, EPICS 3.14.12.4 and Debian 9 to build an IOC for the Princeton SOPHIA-XO Camera.
> But there is no bin folder created as it is the case for e.g. by building an IOC for ADAndor. Any help is welcome.
What architecture are you building for? ADPvCam only supports 32-bit Linux and Windows architectures, not 64-bit.
It works fine for me to build on the linux-x86 architecture. Here is the output:
corvette:~/devel/areaDetector/ADPvCam>echo $EPICS_HOST_ARCH
linux-x86
corvette:~/devel/areaDetector/ADPvCam>make -sj clean uninstall
make[1]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/configure'
perl -CSD /corvette/usr/local/epics-devel/base-7.0.1/bin/linux-x86/makeMakefile.pl O.linux-x86 ../..
perl -CSD /corvette/usr/local/epics-devel/base-7.0.1/bin/linux-x86/makeMakefile.pl O.vxWorks-ppc32 ../..
mkdir -p O.Common
make -C O.linux-x86 -f ../Makefile TOP=../.. \
T_A=linux-x86 install
make[2]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/configure/O.linux-x86'
perl -CSD /corvette/usr/local/epics-devel/base-7.0.1/bin/linux-x86/convertRelease.pl checkRelease
make[2]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/configure/O.linux-x86'
make -C O.vxWorks-ppc32 -f ../Makefile TOP=../.. \
T_A=vxWorks-ppc32 install
make[2]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/configure/O.vxWorks-ppc32'
make[2]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/configure/O.vxWorks-ppc32'
make[1]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/configure'
make[1]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamSupport'
mkdir -p O.Common
make[2]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamSupport/O.linux-x86'
Installing generic include file ../../include/pvcam.h mkdir ../../include Installing generic include file ../../include/pv_icl.h Installing OS dependent include file ../../include/os/Linux/master.h mkdir ../../include/os mkdir ../../include/os/Linux Installing libpvcam.so mkdir ../../lib/linux-x86
make[2]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamSupport/O.linux-x86'
make[2]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamSupport/O.vxWorks-ppc32'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamSupport/O.vxWorks-ppc32'
make[1]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamSupport'
make[1]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp'
make[2]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/src'
perl -CSD /corvette/usr/local/epics-devel/base-7.0.1/bin/linux-x86/makeMakefile.pl O.linux-x86 ../../..
perl -CSD /corvette/usr/local/epics-devel/base-7.0.1/bin/linux-x86/makeMakefile.pl O.vxWorks-ppc32 ../../..
mkdir -p O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../.. \
make[3]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/src/O.linux-x86'
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -D_FILE_OFFSET_BITS=64 -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/home/epics/devel/asyn-4-33/include -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/Linux -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.1/include -MM -MF drvPVCamEpics.d ../drvPVCamEpics.c
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -D_FILE_OFFSET_BITS=64 -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/home/epics/devel/asyn-4-33/include -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/Linux -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.1/include -MM -MF pvCam.d ../pvCam.cpp
make[3]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/src/O.linux-x86'
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -D_FILE_OFFSET_BITS=64 -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/home/epics/devel/asyn-4-33/include -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/Linux -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.1/include -c ../pvCam.cpp
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -D_FILE_OFFSET_BITS=64 -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/home/epics/devel/asyn-4-33/include -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/Linux -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.1/include -c ../drvPVCamEpics.c
/usr/bin/ar -rc libpvCam.a pvCam.o drvPVCamEpics.o
/usr/bin/ranlib libpvCam.a
/usr/bin/g++ -o libpvCam.so -shared -fPIC -Wl,-hlibpvCam.so -L/home/epics/devel/areaDetector-3-2/ADPvCam/lib/linux-x86 -L/home/epics/devel/areaDetector-3-2/ADCore/lib/linux-x86 -L/home/epics/devel/areaDetector-3-2/ADSupport/lib/linux-x86 -L/home/epics/devel/asyn-4-33/lib/linux-x86 -L/usr/local/epics-devel/base-7.0.1/lib/linux-x86 -rdynamic -m32 pvCam.o drvPVCamEpics.o -lpvcam -lADBase -lasyn -lntndArrayConverter -lnt -lpvDatabase -lpvAccess -lpvData -lnetCDF -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -ljpeg -lxml2 -lNeXus -lhdf5 -lblosc -lszip -lzlib -ldbRecStd -ldbCore -lca -lCom -Wl,-Bdynamic -lX11 -lXext -lpthread -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86/libpvCam.so
Installing library ../../../lib/linux-x86/libpvCam.a
make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../.. \
make[3]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/src/O.vxWorks-ppc32'
/usr/local/vw/vxWorks-6.9.4/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/vxWorks -I../../../include -I/corvette/home/epics/devel/asyn-4-33/include -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/vxWorks -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/vxWorks -I/corvette/usr/local/epics-devel/base-7.0.1/include -I/usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h/wrn/coreip -MM > drvPVCamEpics.d ../drvPVCamEpics.c
/usr/local/vw/vxWorks-6.9.4/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/vxWorks -I../../../include -I/corvette/home/epics/devel/asyn-4-33/include -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/vxWorks -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/vxWorks -I/corvette/usr/local/epics-devel/base-7.0.1/include -I/usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h/wrn/coreip -MM > pvCam.d ../pvCam.cpp
In file included from ../pvCam.cpp:11:
../pvCamSrc.h:36:20: error: master.h: No such file or directory
make[3]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/src/O.vxWorks-ppc32'
make[3]: Nothing to be done for `install'.
make[2]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/src'
make[2]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/Db'
mkdir -p O.Common
make[3]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/Db/O.linux-x86'
Installing template file ../../../db/pvCam.template mkdir ../../../db
make[3]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/Db/O.linux-x86'
make[3]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/Db/O.vxWorks-ppc32'
make[3]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/Db/O.vxWorks-ppc32'
make[2]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/Db'
make[1]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp'
make[1]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs'
make[2]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC'
make[3]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/configure'
mkdir -p O.Common
make[4]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/configure/O.linux-x86'
make[4]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/configure/O.linux-x86'
make[4]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/configure/O.vxWorks-ppc32'
make[4]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/configure/O.vxWorks-ppc32'
make[3]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/configure'
make[3]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/pvcamApp'
make[4]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/pvcamApp/src'
mkdir -p O.Common
make[5]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/pvcamApp/src/O.linux-x86'
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -D_FILE_OFFSET_BITS=64 -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I../../../../../include/os/Linux -I../../../../../include -I/corvette/home/epics/devel/asyn-4-33/include -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/Linux -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include -I/corvette/home/epics/devel/autosave-5-9/include/os/Linux -I/corvette/home/epics/devel/autosave-5-9/include -I/corvette/home/epics/devel/busy-1-7/include -I/corvette/home/epics/devel/calc-3-7/include -I/corvette/home/epics/devel/seq-2-2-5/include -I/corvette/home/epics/devel/sscan-2-11-1/include -I/corvette/home/epics/devel/devIocStats-3-1-15/include/os/Linux -I/corvette/home/epics/devel/devIocStats-3-1-15/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.1/include -MM -MF pvCamAppMain.d ../pvCamAppMain.cpp
Creating dbd file pvCamApp.dbd
perl -CSD /corvette/usr/local/epics-devel/base-7.0.1/bin/linux-x86/dbdExpand.pl -I. -I.. -I../O.Common -I../../../dbd -I../../../../../dbd -I/corvette/home/epics/devel/asyn-4-33/dbd -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/dbd -I/corvette/home/epics/devel/autosave-5-9/dbd -I/corvette/home/epics/devel/busy-1-7/dbd -I/corvette/home/epics/devel/calc-3-7/dbd -I/corvette/home/epics/devel/seq-2-2-5/dbd -I/corvette/home/epics/devel/sscan-2-11-1/dbd -I/corvette/home/epics/devel/devIocStats-3-1-15/dbd -I/corvette/usr/local/epics-devel/base-7.0.1/dbd -o pvCamApp.dbd pvCamSupport.dbd base.dbd NDPluginSupport.dbd ADSupport.dbd NDFileNull.dbd NDPluginPva.dbd PVAServerRegister.dbd NDFileNetCDF.dbd NDFileMagick.dbd NDFileTIFF.dbd NDFileJPEG.dbd NDFileNexus.dbd NDFileHDF5.dbd asyn.dbd asSupport.dbd busySupport.dbd calcSupport.dbd devIocStats.dbd sscanSupport.dbd
perl -CSD /corvette/usr/local/epics-devel/base-7.0.1/bin/linux-x86/registerRecordDeviceDriver.pl -I. -I.. -I../O.Common -I../../../dbd -I../../../../../dbd -I/corvette/home/epics/devel/asyn-4-33/dbd -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/dbd -I/corvette/home/epics/devel/autosave-5-9/dbd -I/corvette/home/epics/devel/busy-1-7/dbd -I/corvette/home/epics/devel/calc-3-7/dbd -I/corvette/home/epics/devel/seq-2-2-5/dbd -I/corvette/home/epics/devel/sscan-2-11-1/dbd -I/corvette/home/epics/devel/devIocStats-3-1-15/dbd -I/corvette/usr/local/epics-devel/base-7.0.1/dbd -o pvCamApp_registerRecordDeviceDriver.cpp ../O.Common/pvCamApp.dbd pvCamApp_registerRecordDeviceDriver /home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -D_FILE_OFFSET_BITS=64 -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I../../../../../include/os/Linux -I../../../../../include -I/corvette/home/epics/devel/asyn-4-33/include -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/Linux -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include -I/corvette/home/epics/devel/autosave-5-9/include/os/Linux -I/corvette/home/epics/devel/autosave-5-9/include -I/corvette/home/epics/devel/busy-1-7/include -I/corvette/home/epics/devel/calc-3-7/include -I/corvette/home/epics/devel/seq-2-2-5/include -I/corvette/home/epics/devel/sscan-2-11-1/include -I/corvette/home/epics/devel/devIocStats-3-1-15/include/os/Linux -I/corvette/home/epics/devel/devIocStats-3-1-15/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.1/include -MM -MF pvCamApp_registerRecordDeviceDriver.d pvCamApp_registerRecordDeviceDriver.cpp
make[5]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/pvcamApp/src/O.linux-x86'
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -D_FILE_OFFSET_BITS=64 -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I../../../../../include/os/Linux -I../../../../../include -I/corvette/home/epics/devel/asyn-4-33/include -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/Linux -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include -I/corvette/home/epics/devel/autosave-5-9/include/os/Linux -I/corvette/home/epics/devel/autosave-5-9/include -I/corvette/home/epics/devel/busy-1-7/include -I/corvette/home/epics/devel/calc-3-7/include -I/corvette/home/epics/devel/seq-2-2-5/include -I/corvette/home/epics/devel/sscan-2-11-1/include -I/corvette/home/epics/devel/devIocStats-3-1-15/include/os/Linux -I/corvette/home/epics/devel/devIocStats-3-1-15/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.1/include -c pvCamApp_registerRecordDeviceDriver.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -D_FILE_OFFSET_BITS=64 -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I../../../../../include/os/Linux -I../../../../../include -I/corvette/home/epics/devel/asyn-4-33/include -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/Linux -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include -I/corvette/home/epics/devel/autosave-5-9/include/os/Linux -I/corvette/home/epics/devel/autosave-5-9/include -I/corvette/home/epics/devel/busy-1-7/include -I/corvette/home/epics/devel/calc-3-7/include -I/corvette/home/epics/devel/seq-2-2-5/include -I/corvette/home/epics/devel/sscan-2-11-1/include -I/corvette/home/epics/devel/devIocStats-3-1-15/include/os/Linux -I/corvette/home/epics/devel/devIocStats-3-1-15/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.1/include -c ../pvCamAppMain.cpp
/usr/bin/g++ -o pvCamApp -Wl,-Bstatic -L/home/epics/devel/areaDetector-3-2/ADPvCam/lib/linux-x86 -L/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/lib/linux-x86 -L/home/epics/devel/areaDetector-3-2/ADCore/lib/linux-x86 -L/home/epics/devel/areaDetector-3-2/ADSupport/lib/linux-x86 -L/home/epics/devel/asyn-4-33/lib/linux-x86 -L/home/epics/devel/autosave-5-9/lib/linux-x86 -L/home/epics/devel/busy-1-7/lib/linux-x86 -L/home/epics/devel/calc-3-7/lib/linux-x86 -L/home/epics/devel/devIocStats-3-1-15/lib/linux-x86 -L/home/epics/devel/seq-2-2-5/lib/linux-x86 -L/home/epics/devel/sscan-2-11-1/lib/linux-x86 -L/usr/local/epics-devel/base-7.0.1/lib/linux-x86 -rdynamic -m32 pvCamApp_registerRecordDeviceDriver.o pvCamAppMain.o -lpvCam -lNDPlugin -lADBase -lntndArrayConverter -lnt -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -lnetCDF -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -ljpeg -lxml2 -lNeXus -lhdf5 -lblosc -lszip -lzlib -lasyn -lautosave -lbusy -lcalc -ldevIocStats -lsscan -lseq -lpv -ldbRecStd -ldbCore -lca -lCom -Wl,-Bdynamic -lpvcam -lraw1394 -lX11 -lXext -lpthread -lreadline -lm -lrt -ldl -lgcc
Installing created executable ../../../bin/linux-x86/pvCamApp mkdir ../../../bin/linux-x86
make[5]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/pvcamApp/src/O.vxWorks-ppc32'
/usr/local/vw/vxWorks-6.9.4/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/vxWorks -I../../../include -I../../../../../include -I/corvette/home/epics/devel/asyn-4-33/include -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/vxWorks -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include -I/corvette/home/epics/devel/autosave-5-9/include/os/vxWorks -I/corvette/home/epics/devel/autosave-5-9/include -I/corvette/home/epics/devel/busy-1-7/include -I/corvette/home/epics/devel/calc-3-7/include -I/corvette/home/epics/devel/seq-2-2-5/include -I/corvette/home/epics/devel/sscan-2-11-1/include -I/corvette/home/epics/devel/devIocStats-3-1-15/include/os/vxWorks -I/corvette/home/epics/devel/devIocStats-3-1-15/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/vxWorks -I/corvette/usr/local/epics-devel/base-7.0.1/include -I/usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h/wrn/coreip -MM > pvCamAppMain.d ../pvCamAppMain.cpp
/usr/local/vw/vxWorks-6.9.4/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/vxWorks -I../../../include -I../../../../../include -I/corvette/home/epics/devel/asyn-4-33/include -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/vxWorks -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include -I/corvette/home/epics/devel/autosave-5-9/include/os/vxWorks -I/corvette/home/epics/devel/autosave-5-9/include -I/corvette/home/epics/devel/busy-1-7/include -I/corvette/home/epics/devel/calc-3-7/include -I/corvette/home/epics/devel/seq-2-2-5/include -I/corvette/home/epics/devel/sscan-2-11-1/include -I/corvette/home/epics/devel/devIocStats-3-1-15/include/os/vxWorks -I/corvette/home/epics/devel/devIocStats-3-1-15/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/vxWorks -I/corvette/usr/local/epics-devel/base-7.0.1/include -I/usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h/wrn/coreip -MM > pvCamApp_registerRecordDeviceDriver.d pvCamApp_registerRecordDeviceDriver.cpp
make[5]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/pvcamApp/src/O.vxWorks-ppc32'
make[5]: Nothing to be done for `install'.
make[4]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/pvcamApp/src'
make[3]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/pvcamApp'
make[3]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/iocBoot'
make[4]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/iocBoot/iocPvCam'
make[4]: Nothing to be done for `install'.
make[4]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/iocBoot/iocPvCam'
make[3]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/iocBoot'
make[2]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC'
make[1]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs'
corvette:~/devel/areaDetector/ADPvCam>ls iocs/pvcamIOC/bin/linux-x86/ pvCamApp
Note that you may need to install the 32-bit versions of some packages on your Linux system if it is a 64-bit system.
From: [email protected] <[email protected]> on behalf of Häbel, Catharina <[email protected]>
Sent: Monday, May 28, 2018 10:03 AM
To: [email protected]
Subject: ADPvcam: can't create IOC because of missing build (bin) folder
I have used the areaDetector R3-2 and the ADPvCam R2-2, EPICS 3.14.12.4 and Debian 9 to build an IOC for the Princeton SOPHIA-XO Camera. But there is no bin folder created as it is the case for e.g. by building an IOC for ADAndor. Any help is welcome.
Thanks
Catharina
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (kommissarisch), Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
https://www.helmholtz-berlin.de
Postadresse:
D-14109 Berlin
- RE: ADPvcam: can't create IOC because of missing build (bin) folder Mark Rivers
- ADPvcam: can't create IOC because of missing build (bin) folder Häbel, Catharina
- Re: ADPvcam: can't create IOC because of missing build (bin) folder Mark Rivers
- AW: ADPvcam: can't create IOC because of missing build (bin) folder Häbel, Catharina
MVME3100 FPU Support on RTEMS 4.10.2 Matt Rippa
<2018>
2025
2026
<2018>
2025
2026
