Hej Tim and all,
We actually got the slit working in the motion controller.
I have, anyway, used the 2slit.db, mainly for testing & learning.
For the motor module, I use a patched version, which keeps the record
in UDF state, until the poller has really talked to the controller.
As a result, the soft motors sometimes (depending on the timing)
stay in "link alarm".
A movement will make the alarm disappear.
Do you think we can go through the db file next week,
some help is wanted.
BR
/Torsten
On 08/03/18 18:20, Mooney, Tim M. wrote:
There is also, in the optics module, 2slit_soft.vdb, which uses soft motor records, instead of ao records, for center and width.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] <[email protected]> on behalf of Goetze, Kurt A. <[email protected]>
Sent: Thursday, March 8, 2018 10:51:13 AM
To: Torsten Bögershausen; [email protected]
Subject: RE: Controling a slit system with 2 hard and 4 soft motorrs
Hi Torsten,
The synApps optics module has support for this type of thing:
https://github.com/epics-modules/optics/blob/master/opticsApp/Db/2slit.db
Kurt
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Torsten Bögershausen
Sent: Thursday, March 08, 2018 10:40 AM
To: [email protected]
Subject: Controling a slit system with 2 hard and 4 soft motorrs
Hej motorists,
I recently learned about the transform record, which can be used to control a slit with 2 physical axes in the way that you can set the values for GAP and CENTER and the position of the physical blades are calculated. (Or vice versa)
Does anybody have a super-duper-luxus template file which uses 4 soft motors together with some calc and transform records ?
Thanks in advance
/Torsten
- Re: Controling a slit system with 2 hard and 4 soft motorrs Mooney, Tim M.
- Controling a slit system with 2 hard and 4 soft motorrs Torsten Bögershausen
- RE: Controling a slit system with 2 hard and 4 soft motorrs Goetze, Kurt A.
motor R6-10-1 released Kevin Peterson
RE: EPICS for CompactRio LOTRUS Paul
<2018>
2025
2026
Re: Controling a slit system with 2 hard and 4 soft motorrs Pearson, Matthew R.
<2018>
2025
2026
