1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: 4k x 4k camera options?
Date: Tue, 19 Jun 2018 16:41:42 +0000
Hi Neil,
Your specifications would be met with the EmergentVision HR-20000M. But instead of 10Gb Ethernet interface (32fps), request a 25Gb interface to get the desired frame rate.
https://emergentvisiontec.com
The prices are compatible to FLIR.
Kaz
Date: Tue, 6 Mar 2018 20:29:00 +0000
To: "'[email protected]'" <[email protected]>,
Message-ID: <[email protected]>
Content-Type: text/plain; charset="us-ascii"
Hi Neil,
You might look at the FLIR Oryx ORX-10G-123S6M-C.  It is 4096 x 3000 at 68 fps.  So it does not quite meet your specs in the vertical dimension, but it is simple to interface because it is 10 Gbit Ethernet and it is only $3,950.  How much is the CMOSIS CMV50000 camera you are looking at, and is that CameraLink?
https://www.ptgrey.com/oryx-123-mp-10-gige-mono-sony-imx253-2
I am writing a driver for the Spinnaker SDK that this camera uses.
https://github.com/areaDetector/ADSpinnaker
The driver is not finished, but it is currently functional and I am using it for both GigE and USB-3 cameras.
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Tuesday, March 06, 2018 9:31 AM
To: [email protected]
Subject: 4k x 4k camera options?
Hi All,
One of our beamlines has requested a camera capable of recording images of at least 4k x 4k pixels, ideally at 50+ fps.  We currently have one of the CMOSIS CMV50000 based cameras in mind, but wondered if anyone could recommend any other cameras that are worth considering?
Regards and thanks,
Neil
Prev: Re: MEDM installation Andrew Johnson
Next: EPICS Meeting Talk files Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: 4k x 4k camera options? neil.obrien
Next: Regarding Help to explore my carrier in EPICS sunny badkul
ANJ, 19 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
