1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Trouble building with Visual Studio 2017
To: "'Hammonds, John P.'" <[email protected]>, Tech Talk <[email protected]>
Date: Wed, 20 Jun 2018 19:41:00 +0000
Hi John,
Visual Studio 2017 Community Edition does come with a vcvarsall.bat.  This is my batch file that I use when opening a new cmd shell to work with VS2017:
rem Set the PATH for EPICS builds
call C:\EPICS\setup_epics_path.bat
rem This file sets up for an EPICS windows-x64 build
set EPICS_HOST_ARCH=windows-x64-static-vs2017
rem These are the locations of "make", "re2c", "Perl", and EPICS base.  Prepend them to the PATH.
rem Execute the Visual Studio batch file for 64-bit builds
"C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build\vcvarsall.bat" amd64
I put the path stuff in a separate file because I have a bunch of batch files like the above, for different versions of VS, and for 32/64 bit builds.  This is setup_epics_path.bat
rem This file sets the path for builds
set PATH=C:\Program Files\GNU make;^
C:\Program Files\re2c;^
C:\Perl64\bin;^
H:\epics\base\bin\windows-x64-static;^
H:\epics\extensions\bin\windows-x64-static;^
%PATH%
You may need to install an optional package when installing VC2017 Community to get the VC\Auxiliary\Build\vcvarsall.bat directory and files.
I suspect this may fix your problem with epicsTempFile, because I saw this in this tech-talk message https://epics.anl.gov/tech-talk/2016/msg01636.php
I’ve managed to reproduce a epicsTempFile.obj error and in this case it was caused by make not being able to locate the Visual Studio compiler.
From: [email protected] <[email protected]> On Behalf Of Hammonds, John P.
Sent: Wednesday, June 20, 2018 1:32 PM
To: Tech Talk <[email protected]>
Subject: Trouble building with Visual Studio 2017
I am trying a new build of EPICS, starting with base of course, on Windows.  Since I did not have the compiler on this (a virtual machine on a Mac actually) I grabbed the latest community edition which was 2017.  In the past I would make simple mods to the win32.bat in startup directory and things would work.  So far I have not found the vsvarsall.bat location in this version so I simply went to the ‘x64 Native Tools Command Prompt for VS 2017’ set the EPICS_HOST_ARCH to windows-x64 and set path to include location of make and perl and started compiling.  Everything starts OK but I reach a point where I get the following error:
cl -EHsc -GR      -DUSE_TYPED_RSET          -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include         -c ../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp
process_begin: CreateProcess(NULL, cl -EHsc -GR -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp, ...) failed.
make (e=2): The system cannot find the file specified.
make[3]: *** No rule to make target 'epicsTempFile.obj', needed by 'antelope.exe'.  Stop.
make[3]: Leaving directory 'C:/epics/base-3.16.1/src/libCom/O.windows-x64'
make[2]: *** [../../configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[2]: Leaving directory 'C:/epics/base-3.16.1/src/libCom'
make[1]: *** [../configure/RULES_DIRS:84: libCom.install] Error 2
make[1]: Leaving directory 'C:/epics/base-3.16.1/src'
make: *** [configure/RULES_DIRS:84: src.install] Error 2
make: Leaving directory 'C:/epics/base-3.16.1'
I have tried this with base-3.15.5, base-3.16.1 and base-7.0.1.1 and all stop at the same place with very similar errors (haven’t checked if they are totally identical.
Has anyone seen this problem?
John
Trouble building with Visual Studio 2017 Hammonds, John P.
Prev: Building pvData using R3.15.4 fails DPCuneo
Next: Re: A recent R3.15.5 Patch file Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Trouble building with Visual Studio 2017 Hammonds, John P.
Next: Building pvData using R3.15.4 fails DPCuneo
ANJ, 20 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
