1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Question about displaying process memory allocation on Linux
Date: Tue, 26 Jun 2018 13:51:32 +0000
Folks,
In areaDetector the NDArrays are allocated from a free list in NDArrayPool.  Previously once a large number of arrays had been allocated on the free list there was no way to free that memory back to the OS without restarting the IOC.  I have now added an NDArrayPool::emptyFreeList() method and an EmptyFreeList record that results in a call to that method.
When I test on Windows and I look at the Commit Size for the simDetector process in Task Manager I see exactly what I expect.  If I have large queues and the detector is acquiring faster than the plugins can process the free list contains NDArrays totaling over 3GB.   The Commit Size is ~3.2 GB.  When I process the EmptyFreeList record the CommitSize immediately drops to 0.2 GB.
I am trying to see if I see the same thing on Linux, using the ps –o trs,vsz,drs command.
This is what I see when I first start the simDetector IOC, before I collect any images.  Note that the virtual memory size (VSZ) is already 5GB.  This seems strange.  Can anyone explain?
corvette:dxpSITORO/iocBoot/iocFalconX1>ps -p 115038 -o trs,vsz,drs
TRS    VSZ   DRS
15838 5080984 5065145
This is what I see after collecting enough images that there is a total of 3GB of NDArrays allocated.  VSZ has increased by 3GB (from 5GB to 8GB), which is what I expect.
TRS    VSZ   DRS
15838 8171424 8155585
This is what I see when acquisition has stopped and all plugins have competed.  The NDArrays are now all on the free list, VSZ remains at 8 GB, which is what I expect.
TRS    VSZ   DRS
This is what I see after I process the EmptyFreeList record.  Note that VSZ has only decreased by about 0.2GB, not by 3GB which I would have expected.  Can anyone explain?
TRS    VSZ   DRS
15838 7974816 7958977
Is there another statistic I can look at to see that my process has indeed returned all 3GB to the OS?
RE: Question about displaying process memory allocation on Linux Mark Engbretson
Re: Question about displaying process memory allocation on Linux Jörn Dreyer
Re: Question about displaying process memory allocation on Linux J. Lewis Muir
Re: Question about displaying process memory allocation on Linux Andrew Johnson
Prev: Re: CPP example NTTable builder Heinz Junkes
Next: RE: Question about displaying process memory allocation on Linux Mark Engbretson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Question about RDB Channel archiver engine be used for the waveform channels Mazanec Tomáš
ANJ, 27 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
