Hi
Yes, RDB channel archiver can store waveform data (as any other Channel Access PV data); and users can retrieve the stored waveform data using e.g.: CSS DataBrowser (and waveform analyzer).
Answer to your 1.25GS/s requirement: If you have a HW good enough and the sampled data well partitioned into waveforms, then yes, it is possible to archive the data with use of one-or-more RDB archiver instances and with properly scaled SQL storage.
Detailed answer requires more information about how the waveforms are processed at IOC side -- in terms of their update rate, NORD, NELM, FTVL.
Tomas
Od: [email protected] <[email protected]> za uživatele lzf neu <[email protected]>
Odesláno: úterý 26. června 2018 7:40:19 Komu: [email protected] Předmět: Question about RDB Channel archiver engine be used for the waveform channels
| ANJ, 27 Jun 2018 |
Home
News
About
Talk
Base
Modules
Extensions
