1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question about displaying process memory allocation on Linux
To: Mark Engbretson <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 26 Jun 2018 14:28:21 +0000
Hi Mark,
> but do you have a suggested place where you might suggest putting NDArrayPool::emptyFreeList() so that memory will always be flushed, when it can be?
That's a tricky question.  The point of the free list is that it should be more efficient than calling malloc() and free() for the large NDArrays each time a new one is allocated and freed.  If the free list were regularly emptied it would defeat this optimization.  That being said I have not actually benchmarked the time to use NDArrayPool->alloc vs calling new NDArray(ndims, dims, dataType, 0, NULL).
> And perhaps a place where it can be done automagically when memory is about to be exceeded so that AD just starts to dump frames instead of crashing because there is no free memory left?
If by "no free memory left" you mean exceeding maxMemorySize then that is already the case, and has been for a long time.  If NDArrayPool->alloc() would exceed the maxMemorySize then it deletes NDArrays from the free list until enough memory is available (if possible).
However, prior to R3-3 each driver and plugin had its own NDArrayPool, and so it was difficult to use maxMemorySize effectively.  It is the total memory in the IOC that matters, but previously one had to set the maxMemorySize for each driver and plugin.  In R3-3 all plugins get their NDArrays from the driver's NDArrayPool, so a single setting of maxMemorySize is all that is needed, and it controls that driver and all of its plugins.
Sent: Tuesday, June 26, 2018 9:03 AM
To: Mark Rivers; [email protected]
Subject: RE: Question about displaying process memory allocation on Linux
Not an answer to your Linux issues . . . sorry . . . . but do you have a suggested place where you might suggest putting NDArrayPool::emptyFreeList() so that memory will always be flushed, when it can be? And perhaps a place where it can be done automagically when memory is about to be exceeded so that AD just starts to dump frames instead of crashing because there is no free memory left?
From: [email protected] <[email protected]> On Behalf Of Mark Rivers
Sent: Tuesday, June 26, 2018 8:52 AM
To: [email protected]
Subject: Question about displaying process memory allocation on Linux
Folks,
In areaDetector the NDArrays are allocated from a free list in NDArrayPool.  Previously once a large number of arrays had been allocated on the free list there was no way to free that memory back to the OS without restarting the IOC.  I have now added an NDArrayPool::emptyFreeList() method and an EmptyFreeList record that results in a call to that method.
When I test on Windows and I look at the Commit Size for the simDetector process in Task Manager I see exactly what I expect.  If I have large queues and the detector is acquiring faster than the plugins can process the free list contains NDArrays totaling over 3GB.   The Commit Size is ~3.2 GB.  When I process the EmptyFreeList record the CommitSize immediately drops to 0.2 GB.
I am trying to see if I see the same thing on Linux, using the ps –o trs,vsz,drs command.
This is what I see when I first start the simDetector IOC, before I collect any images.  Note that the virtual memory size (VSZ) is already 5GB.  This seems strange.  Can anyone explain?
corvette:dxpSITORO/iocBoot/iocFalconX1>ps -p 115038 -o trs,vsz,drs
TRS    VSZ   DRS
15838 5080984 5065145
This is what I see after collecting enough images that there is a total of 3GB of NDArrays allocated.  VSZ has increased by 3GB (from 5GB to 8GB), which is what I expect.
TRS    VSZ   DRS
15838 8171424 8155585
This is what I see when acquisition has stopped and all plugins have competed.  The NDArrays are now all on the free list, VSZ remains at 8 GB, which is what I expect.
TRS    VSZ   DRS
This is what I see after I process the EmptyFreeList record.  Note that VSZ has only decreased by about 0.2GB, not by 3GB which I would have expected.  Can anyone explain?
TRS    VSZ   DRS
15838 7974816 7958977
Is there another statistic I can look at to see that my process has indeed returned all 3GB to the OS?
RE: Question about displaying process memory allocation on Linux Mark Engbretson
Question about displaying process memory allocation on Linux Mark Rivers
Prev: Re: Question about displaying process memory allocation on Linux Jörn Dreyer
Next: RE: Question about displaying process memory allocation on Linux Mark Engbretson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Question about displaying process memory allocation on Linux Mark Engbretson
ANJ, 26 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
