1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem building aravisGigE on Centos 7
To: 'Michael Davidsaver' <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 30 Jun 2018 13:41:49 +0000
Hi Michael,
Thanks, adding the second line below to the Makefile fixed it.
PROD_SYS_LIBS += giomm-2.4
PROD_SYS_LIBS += gio-2.0 gobject-2.0 gthread-2.0 glib-2.0
I was puzzled why it worked previously when the Makefile contained only the first line, i.e. giomm=2.4.
I think I have figured it out.  If I add this line to the Makefile it builds fine without the second line above:
STATIC_BUILD=NO
If it is building dynamically then libgiomm-2.4.so has the information it needs to know what other libraries are required.  But if I build statically then I need to specify the other libraries.  When this worked previously for me I must have been building dynamically.  Does this make sense?
-----Original Message-----
Sent: Friday, June 29, 2018 6:45 PM
To: Mark Rivers <[email protected]>; [email protected]
Subject: Re: Problem building aravisGigE on Centos 7
On 06/29/2018 03:44 PM, Mark Rivers wrote:
> /bin/ld: /home/epics/devel/areaDetector-3-3/aravisGigE/lib/linux-x86_64/libaravisCamera.a(aravisCamera.o): undefined reference to symbol 'g_signal_connect_data'
> /lib64/libgobject-2.0.so.0: error adding symbols: DSO missing from command line
This is the same issue once removed.  -lgobject is missing.
pkg-config is your friend here.
aravis 0.3.8 lists it's dependencies as
> glib-2.0 gobject-2.0 gio-2.0 libxml-2.0 gthread-2.0
https://github.com/epicsdeb/aravis/blob/master/aravis.pc.in#L9
copy+paste these to pkg-config
> $ pkg-config --libs glib-2.0 gobject-2.0 gio-2.0 libxml-2.0 gthread-2.0
> -lgio-2.0 -lgobject-2.0 -lxml2 -lgthread-2.0 -pthread -lglib-2.0
So your
> -laravisCamera -laravis-0.4 -lNDPlugin -lADBase -lntndArrayConverter -lnt -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -lnetCDF -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -ljpeg -lxml2 -lNeXus -lhdf5 -lblosc -lszip -lzlib -lasyn -lautosave -lbusy -lcalc -ldevIocStats -lsscan -lseq -lpv -ldbRecStd -ldbCore -lca -lCom -Wl,-Bdynamic -lgiomm-2.4 -lX11 -lXext -lpthread   -lreadline -lm -lrt -ldl -lgcc
is missing gobject, gthread, and glib itself.
These results on debian 9 w/ glib 2.50.3-2, your mileage may vary.
Re: Problem building aravisGigE on Centos 7 Michael Davidsaver
Problem building aravisGigE on Centos 7 Mark Rivers
Prev: Re: Problem building aravisGigE on Centos 7 Michael Davidsaver
Next: Re: Problem building aravisGigE on Centos 7 Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 30 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
