On 06/30/2018 06:41 AM, Mark Rivers wrote:
> Hi Michael,
> Thanks, adding the second line below to the Makefile fixed it.
> PROD_SYS_LIBS += giomm-2.4
> PROD_SYS_LIBS += gio-2.0 gobject-2.0 gthread-2.0 glib-2.0
> I was puzzled why it worked previously when the Makefile contained only the first line, i.e. giomm=2.4.
> I think I have figured it out. If I add this line to the Makefile it builds fine without the second line above:
> STATIC_BUILD=NO
> If it is building dynamically then libgiomm-2.4.so has the information it needs to know what other libraries are required. But if I build statically then I need to specify the other libraries. When this worked previously for me I must have been building dynamically. Does this make sense?
Yes. Static libraries (.a files) don't contain the dependency information found in shared object (.so).
So when linking STATIC_BUILD=NO, only the direct dependencies need to be listed (it doesn't hurt to list all).
With STATIC_BUILD=YES, all dependencies must be listed, and in a specific order (direct first).
- Re: Problem building aravisGigE on Centos 7 Ralph Lange
- Problem building aravisGigE on Centos 7 Mark Rivers
- Re: Problem building aravisGigE on Centos 7 Michael Davidsaver
- RE: Problem building aravisGigE on Centos 7 Mark Rivers
<2018>
2025
2026
<2018>
2025
2026
