1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caget randomly returns Channel connect timed out
To: <[email protected]>
Date: Thu, 12 Jul 2018 15:12:22 -0500
Hi Matt,
On 07/12/2018 02:54 PM, Matt Rippa wrote:
> We ran a simple caget (once per second) from a linux host to an upgraded
> IOC. With the new rtems/3.14.12.7 <http://3.14.12.7> IOC, it often
> experiences timeouts as shown below. With our legacy vxworks/3.13.9 IOC
> there are no timeouts logged. Relevant info is shown below. The
> caRepeater is running on the linux host.
If your IOC is busy the caget default search timeout of 1 second may be
too short, have you tried using 'caget -w 5 tcs:ak:astCtx' say?
> I'm thinking that setting the linux host EPICS_CA_ADDR_LIST=YES may
> help. I'm running that test now.
I have never seen an EPICS_CA_ADDR_LIST as long as yours, but given that
you seem to be searching multiple subnets maybe you do need that.
I don't think setting EPICS_CA_AUTO_ADDR_LIST to YES will make any
difference to this behaviour (your epicsPrtEnvParams showed it as YES
already, so unless you have explicitly changed it for the client you're
probably already searching your local subnet as well).
HTH,
- Andrew
> EPICS_CA_ADDR_LIST=172.17.2.255 172.17.3.255 172.17.102.130
> 172.17.105.20 172.16.102.130 aom-vme sbfmcao01.cl.gemini.edu
> mcao-stealth.cl.gemini.edu 172.17.106.111 172.17.105.37
> 172.17.107.50 172.17.55.101 172.17.101.101 172.17.65.255
> 172.17.102.139 172.17.102.138
> linux> caget tcs:ak:astCtx
> tcs:ak:astCtx                  0
> Channel connect timed out: 'tcs:ak:astCtx' not found.
> tcs:ak:astCtx                  0
Re: caget randomly returns Channel connect timed out Michael Davidsaver
caget randomly returns Channel connect timed out Matt Rippa
Prev: Re: NDArrayPool Mark Rivers
Next: Re: caget randomly returns Channel connect timed out Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: caget randomly returns Channel connect timed out Matt Rippa
ANJ, 12 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
