1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caget randomly returns Channel connect timed out
To: Andrew Johnson <[email protected]>, [email protected]
Date: Thu, 12 Jul 2018 13:47:33 -0700
On 07/12/2018 01:12 PM, Andrew Johnson wrote:
> Hi Matt,
> On 07/12/2018 02:54 PM, Matt Rippa wrote:
>> We ran a simple caget (once per second) from a linux host to an upgraded
>> IOC. With the new rtems/3.14.12.7 <http://3.14.12.7> IOC, it often
>> experiences timeouts as shown below. With our legacy vxworks/3.13.9 IOC
>> there are no timeouts logged. Relevant info is shown below. The
>> caRepeater is running on the linux host.
> If your IOC is busy the caget default search timeout of 1 second may be
> too short, have you tried using 'caget -w 5 tcs:ak:astCtx' say?
@Matt, If this doesn't have an effect I'd suggest taking a packet capture
to see whether these is a search reply coming back.
As it happens, I had an symptom similar to this while playing around
with an mvme31000 emulator.  The issue turned out to be dropped RX
interrupts due to a bug in the emulator.  The effect was due to
a hard coded 1 second timeout in CA during TCP connect().
Have you tried the simple test of letting 'ping' run for a while?
If the reported latencies aren't stable, it may be a sign of a
lower level issue.
>> I'm thinking that setting the linux host EPICS_CA_ADDR_LIST=YES may
>> help. I'm running that test now.
> I have never seen an EPICS_CA_ADDR_LIST as long as yours, but given that
> you seem to be searching multiple subnets maybe you do need that.
Agreed.  For this test I'd suggest setting EPICS_CA_ADDR_LIST with only
the IP of the IOC you're testing.  Along with EPICS_CA_AUTO_ADDR_LIST=NO
> I don't think setting EPICS_CA_AUTO_ADDR_LIST to YES will make any
> difference to this behaviour (your epicsPrtEnvParams showed it as YES
> already, so unless you have explicitly changed it for the client you're
> probably already searching your local subnet as well).
Also if both IOC and client tools are 3.14.12.x then you can try
EPICS_CA_AUTO_ADDR_LIST=NO EPICS_CA_ADDR_LIST= EPICS_CA_NAME_SERVERS=<IP>
This will skip the UDP search altogether and do a TCP search.
> HTH,
> - Andrew
>> EPICS_CA_ADDR_LIST=172.17.2.255 172.17.3.255 172.17.102.130
>> 172.17.105.20 172.16.102.130 aom-vme sbfmcao01.cl.gemini.edu
>> mcao-stealth.cl.gemini.edu 172.17.106.111 172.17.105.37
>> 172.17.107.50 172.17.55.101 172.17.101.101 172.17.65.255
>> 172.17.102.139 172.17.102.138
>> linux> caget tcs:ak:astCtx
>> tcs:ak:astCtx                  0
>> Channel connect timed out: 'tcs:ak:astCtx' not found.
>> tcs:ak:astCtx                  0
Re: caget randomly returns Channel connect timed out Ignacio
Re: caget randomly returns Channel connect timed out Matt Rippa
Re: caget randomly returns Channel connect timed out Andrew Johnson
Prev: Re: caget randomly returns Channel connect timed out Andrew Johnson
Next: Re: caget randomly returns Channel connect timed out Ignacio
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 12 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
