1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS Mailing Lists Configuration Changes
To: EPICS tech-talk <[email protected]>
Date: Mon, 16 Jul 2018 11:34:30 -0500
In order to resolve a problem with some tech-talk messages being marked
as Spam due to dmarc email security policies, I slightly changed the
Mailman configuration of all the APS-run EPICS mailing lists over the
weekend. This had the effect of giving all messages a From: address of
the list itself (the author's name is included too), with a Reply-To:
header pointing to the author's email.
This morning I discovered a more targeted solution to the original issue
 in GNU Mailman which only applies this configuration setting to
messages coming from addresses whose domains request dmarc security, so
I changed the list configuration to use that instead. This now means
that messages from some posters will look slightly different to others,
depending whether the author's email provider has configured dmarc
security or not.
Matt Rippa sent me the following links for those interested in more detail:
https://dmarc.org/wiki/FAQ#s_3
http://onlinegroups.net/blog/2014/04/10/yahoo-dmarc-better-mailing-list-manager/
http://blogs.msdn.com/b/tzink/archive/2015/05/28/solving-the-problem-of-dmarc-s-incompatibility-with-mailing-lists-part-1.aspx
- Andrew
Prev: OCEM NGPS power supply unit rory.potter--- via Tech-talk
Next: Re: caget randomly returns Channel connect timed out Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Question about store array in MySQL by using RDB Channel Archive lzf neu
ANJ, 16 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
