1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caget randomly returns Channel connect timed out
To: <[email protected]>
Date: Mon, 16 Jul 2018 12:07:40 -0500
Hi Dirk,
On 07/16/2018 02:42 AM, Dirk Zimoch via Tech-talk wrote:
> We at PSI hat problems with new Cisco switches (I don't know the model)
> dropping CA directed broadcasts (i.e. broadcasts into another subnet,
> such as 172.17.2.255 172.17.3.255) and even blocking them for a while
> when the rate went over a certain limit (e.g. when a huge UI starts up).
> I think that was supposed to be a counter measure against denial of
> service attacks. It took over a year of discussion with Cisco to get a fix.
You managed to get Cisco to support the conversion of a UDP packet sent
to a subnet's broadcast address into a real broadcast packet on that
subnet? I'm impressed! Our older HP switches used to allow this but IT
replaced them several years ago (we weren't relying on this behaviour,
which does have some fairly obvious DoS attack possibilities).
For the record, can you find out if that Cisco solution is specific to a
particular model or family of switches, or if they made it generic?
- Andrew
RE: caget randomly returns Channel connect timed out Mark Rivers
caget randomly returns Channel connect timed out Matt Rippa
Re: caget randomly returns Channel connect timed out Andrew Johnson
Re: caget randomly returns Channel connect timed out Michael Davidsaver
Re: caget randomly returns Channel connect timed out Matt Rippa
Re: caget randomly returns Channel connect timed out Dirk Zimoch via Tech-talk
Prev: EPICS Mailing Lists Configuration Changes Andrew Johnson
Next: RE: caget randomly returns Channel connect timed out Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: caget randomly returns Channel connect timed out Dirk Zimoch via Tech-talk
ANJ, 16 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
