1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: 答复: Question about store array in MySQL by using RDB Channel Archive
To: "Kasemir, Kay" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 18 Jul 2018 14:29:37 +0000
Thank you very much for your reply.
And I meet another problem to consult you please:
My CSS version is 4.1.1. Retriving the waveforms by CSS data browser for 1 hour induces out of memory problems. I try to solve the problem to increase the default live data buffer size to 10000 and more for data browser, and fetch size to the upper limit for RDB archive and also increase the max_array_bytes in CSS.
However, the out of memory problems are still exist when the data browser running a period of time less than an hour and during that time the waveforms are not continuous and part of data may lost and are displayed straight line in data browser.
Thanks in advance.
Zhefu
发件人: Kasemir, Kay <[email protected]>
发送时间: 2018年7月17日 13:47:23
收件人: lzf neu; [email protected]
主题: Re: Question about store array in MySQL by using RDB Channel Archive
Hi:
>    1) There is a waveform array contains 1560 double type elements, I want to store them in mysql in real-time by using ArchiveEngine. To do so, I have imported the mysql_schema.sql  in the attatchment and then start the ArchiveEngine.  However, when performing "select * from sample" command in mysql, only one data are in "float_val" column.  It seems mysql cannot store array directly. Could any one tell me how to store  array in MySQL by using RDB Channel Archive.
The 'sample' table is for scalar data. For array samples, it only holds the first array element.
The complete array is stored as a blob in the 'array_val' table.
See also https://github.com/ControlSystemStudio/cs-studio/blob/master/applications/archive/archive-plugins/org.csstudio.archive.rdb/dbd/array_encoding.txt
Having said that, the archive engine is more of a long-term monitoring tool than a short-term data acquisition tool.
To capture waveforms, you may want to look into the area detector toolset.
>   2) For testing the performance of ArchiveEngine with diffenet parameters (write_period, batch_size, buffer_reserve) versus write speed (samples  per second), could any one tell me how to record the writing speed of ArchiveEngine with  above parameters.
The archive engine's web interface shows
     Last Written   - time when the engine last wrote, typically every 30 seconds
     Write Count   - How many samples it last wrote
     Write Duration  - How long that took in seconds
If you divide Write Count  by Write Duration, you get the basic performance of your RDB setup, i.e. how many values per second you can write.
-Kay
Question about store array in MySQL by using RDB Channel Archive lzf neu
Re: Question about store array in MySQL by using RDB Channel Archive Kasemir, Kay
Prev: Rotating Image in NDPluginPva plugin Shen, Guobao
Next: Rotating Image in NDPluginPva plugin Shen, Guobao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Question about store array in MySQL by using RDB Channel Archive Kasemir, Kay
Next: Parse IEEE 488.2-1992 Block format with StreamDevice? Christoph Schroeder
ANJ, 18 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
