1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MEDM compilation on Ubuntu 16.04
To: Bob Soliday <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 19 Jul 2018 19:20:36 +0000
Hi All,
Upon your recommendations I set:
I)  "STATIC_BUILD=NO" in  /areaDetector/configure/CONFIG_SITE.local.Linux file
II) "USR_LIBS_Linux = Xm Xt Xmu X11 Xext" in /medm/medm/Makefile
MEDM compiled with this configuration and created medm binary file that starts the user interface. We will further test the UI.
Thank you all for your help.
Best,
Alper
Alper Kinaci, PhD
Sr Computational Specialist
Research Computing Services
Information Technology
Northwestern University
847.467.7615
Sent: Wednesday, July 18, 2018 11:24 AM
To: Alper Kinaci; [email protected]
The problem you are having due to STATIC_BUILD being set to YES.
On 07/18/2018 11:12 AM, Bob Soliday wrote:
Oh I didn't read your whole message. I had setup a new environment on Ubuntu 16.04 with the latest version of medm:
cd epics/extensions/src
git clone https://github.com/epics-extensions/medm
With only the one change to the makefile and setting MOTIF_LIB and X11_LIB to /usr/lib/x86_64-linux-gnu, I was able to build medm without any errors.
On 07/18/2018 11:04 AM, Bob Soliday wrote:
Sorry, this email was just showed up in my inbox a week late for some reason.
There is a comment in the medm/Makefile about the Xp library not being required for some versions of Linux. You can uncomment the modified USR_LIBS_Linux definition that has Xp removed and then recompile.
On 07/10/2018 05:37 PM, Alper Kinaci wrote:
Dear Developers,
I am trying to build MEDM on our Epics (base-3.15.5) and areaDetector (specifically ADEiger) installations on an Ubuntu 16.04 machine. I followed the instructions on "https://epics.anl.gov/extensions/medm/" webpage however one of the packages needed for MEDM, i.e. libxp-dev (and also libxp), is not available for this version of Ubuntu.
I can find the library deb file (libxp-dev_1.0.2-1ubuntu1_amd64.deb) for Ubuntu 14.04 however I am not sure if this package will work with our operating system.
If I comment out the line "USR_LIBS_Linux = Xm Xt Xp Xmu X11 Xext" and uncomment "USR_LIBS_Linux = Xm Xt Xmu X11 Xext" to remove libXp linkage in medm Makefile, the compilation still fails due to some undefined references to functions. That reminds me the errors I receive when some header files are missing. I included the error lines in my compilation at the end.
I will appreciate any guidance or hint on this issue. Thank you for your consideration.
Best regards,
Alper
Alper Kinaci, PhD
847.467.7615
/usr/bin/g++ -o medm -Wl,-Bstatic -L/home/epics-admin/Documents/areaDetector/lib/linux-x86_64 -L/home/epics-admin/Documents/base-3.15.5/lib/linux-x86_64 -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/home/epics-admin/Documents/areaDetector/lib/linux-x86_64 -Wl,-rpath,/home/epics-admin/Documents/base-3.15.5/lib/linux-x86_64 -Wl,-rpath,/usr/lib/x86_64-linux-gnu           -rdynamic -m64             medmCA.o actions.o bubbleHelp.o callbacks.o browserHelp.o channelPalette.o colorPalette.o dialogs.o display.o eventHandlers.o help.o medm.o medmArc.o medmBar.o medmByte.o medmChoiceButtons.o medmCommon.o medmComposite.o medmControl.o medmDisplay.o medmImage.o medmIndicator.o medmMenu.o medmMessageButton.o medmMeter.o medmMonitor.o medmOval.o medmPixmap.o medmPolygon.o medmPolyline.o medmRectangle.o medmRelatedDisplay.o medmShellCommand.o medmStripChart.o medmText.o medmTextEntry.o medmTextUpdate.o medmValuator.o medmWheelSwitch.o medmWidget.o objectPalette.o productDescriptionShell.o resourcePalette.o updateMonitors.o updateTask.o utils.o xgif.o   -lANLwidgets -lPrintUtils -lca -lCom -lXm -lXt -lXmu -lX11 -lXext -Wl,-Bdynamic  -lpthread   -lreadline -lm -lrt -ldl -lgcc
/usr/lib/x86_64-linux-gnu/libXm.a(Label.o): In function `Redisplay':
(.text+0xef8): undefined reference to `XftDrawSetClip'
/usr/lib/x86_64-linux-gnu/libXm.a(LabelG.o): In function `_XmRedisplayLabG':
(.text+0x3543): undefined reference to `XftDrawSetClip'
/usr/lib/x86_64-linux-gnu/libXm.a(TextIn.o): In function `SelfInsert':
(.text+0x6cf3): undefined reference to `XftTextExtentsUtf8'
/usr/lib/x86_64-linux-gnu/libXm.a(TextOut.o): In function `FindWidth':
(.text+0x190e): undefined reference to `XftTextExtentsUtf8'
(.text+0x19d3): undefined reference to `XftTextExtentsUtf8'
/usr/lib/x86_64-linux-gnu/libXm.a(TextOut.o): In function `FindHeight':
(.text+0x221c): undefined reference to `XftTextExtentsUtf8'
(.text+0x22f5): undefined reference to `XftTextExtentsUtf8'
/usr/lib/x86_64-linux-gnu/libXm.a(XmString.o):(.text+0x6d1): more undefined references to `XftTextExtentsUtf8' follow
/usr/lib/x86_64-linux-gnu/libXm.a(XmString.o): In function `SubStringPosition':
(.text+0xc1af): undefined reference to `XftTextExtents16'
(.text+0xc243): undefined reference to `XftTextExtents16'
/usr/lib/x86_64-linux-gnu/libXm.a(XmString.o): In function `_render':
(.text+0xe2c5): undefined reference to `XftDrawSetClip'
/usr/lib/x86_64-linux-gnu/libXm.a(TextF.o): In function `FindPixelLength.part.6':
(.text+0x1dbe): undefined reference to `XftTextExtentsUtf8'
(.text+0x1f15): undefined reference to `XftTextExtentsUtf8'
(.text+0x1fa5): undefined reference to `XftTextExtentsUtf8'
/usr/lib/x86_64-linux-gnu/libXm.a(TextF.o): In function `PrintableString':
(.text+0x27ae): undefined reference to `XftTextExtentsUtf8'
/usr/lib/x86_64-linux-gnu/libXm.a(TextF.o): In function `TextFieldResetIC':
(.text+0x8522): undefined reference to `XftTextExtentsUtf8'
/usr/lib/x86_64-linux-gnu/libXm.a(XmRenderT.o): In function `FreeRendition':
(.text+0x10aa): undefined reference to `XftFontClose'
(.text+0x10cc): undefined reference to `FcPatternDestroy'
/usr/lib/x86_64-linux-gnu/libXm.a(XmRenderT.o): In function `ValidateAndLoadFont':
(.text+0x1d1f): undefined reference to `FcPatternCreate'
(.text+0x1d45): undefined reference to `FcPatternAddString'
(.text+0x1d63): undefined reference to `FcPatternAddString'
(.text+0x1d81): undefined reference to `FcPatternAddString'
(.text+0x1d9f): undefined reference to `FcPatternAddString'
(.text+0x1e01): undefined reference to `XftFontMatch'
(.text+0x1e12): undefined reference to `XftFontOpenPattern'
(.text+0x20c5): undefined reference to `FcPatternAddInteger'
(.text+0x20df): undefined reference to `FcPatternAddInteger'
(.text+0x20f9): undefined reference to `FcPatternAddInteger'
(.text+0x2113): undefined reference to `FcPatternAddInteger'
(.text+0x212d): undefined reference to `FcPatternAddInteger'
/usr/lib/x86_64-linux-gnu/libXm.a(XmRenderT.o): In function `_XmXftDrawCreate':
(.text+0x4b69): undefined reference to `XftDrawCreate'
(.text+0x4c42): undefined reference to `XftDrawCreateBitmap'
/usr/lib/x86_64-linux-gnu/libXm.a(XmRenderT.o): In function `_XmXftDrawString2':
(.text+0x4df7): undefined reference to `XftDrawStringUtf8'
(.text+0x4e1f): undefined reference to `XftDrawString32'
(.text+0x4e4f): undefined reference to `XftDrawString16'
/usr/lib/x86_64-linux-gnu/libXm.a(XmRenderT.o): In function `_XmXftDrawString':
(.text+0x4f44): undefined reference to `XftDrawRect'
(.text+0x4fd6): undefined reference to `XftDrawStringUtf8'
(.text+0x500e): undefined reference to `XftDrawString32'
(.text+0x504e): undefined reference to `XftDrawString16'
(.text+0x507c): undefined reference to `XftTextExtents16'
(.text+0x50ac): undefined reference to `XftTextExtentsUtf8'
(.text+0x515c): undefined reference to `XftTextExtents32'
/usr/lib/x86_64-linux-gnu/libXm.a(XmRenderT.o): In function `_XmXftFontAverageWidth':
(.text+0x5285): undefined reference to `XftTextExtents8'
/usr/lib/x86_64-linux-gnu/libXm.a(XmRenderT.o): In function `_XmXftDrawDestroy':
(.text+0x4c9f): undefined reference to `XftDrawDestroy'
/usr/lib/x86_64-linux-gnu/libXm.a(XmRenderT.o): In function `_XmXftSetClipRectangles':
(.text+0x5233): undefined reference to `XftDrawSetClipRectangles'
/usr/lib/x86_64-linux-gnu/libXm.a(Jpeg.o): In function `load_jpeg':
(.text+0x6c): undefined reference to `jpeg_std_error'
(.text+0x9d): undefined reference to `jpeg_destroy_decompress'
(.text+0xdb): undefined reference to `jpeg_CreateDecompress'
(.text+0xed): undefined reference to `jpeg_stdio_src'
(.text+0xff): undefined reference to `jpeg_read_header'
(.text+0x10c): undefined reference to `jpeg_calc_output_dimensions'
(.text+0x119): undefined reference to `jpeg_start_decompress'
(.text+0x17e): undefined reference to `jpeg_read_scanlines'
(.text+0x1b5): undefined reference to `jpeg_finish_decompress'
(.text+0x1c2): undefined reference to `jpeg_destroy_decompress'
/usr/lib/x86_64-linux-gnu/libXm.a(Png.o): In function `png_load_file.constprop.0':
(.text+0x7a): undefined reference to `png_sig_cmp'
(.text+0xbc): undefined reference to `png_create_read_struct'
(.text+0xce): undefined reference to `png_create_info_struct'
(.text+0x102): undefined reference to `png_destroy_read_struct'
(.text+0x118): undefined reference to `png_destroy_read_struct'
(.text+0x14b): undefined reference to `png_init_io'
(.text+0x15a): undefined reference to `png_set_sig_bytes'
(.text+0x169): undefined reference to `png_read_info'
(.text+0x199): undefined reference to `png_get_IHDR'
(.text+0x1f1): undefined reference to `png_get_valid'
(.text+0x219): undefined reference to `png_set_gray_to_rgb'
(.text+0x22d): undefined reference to `png_get_gAMA'
(.text+0x245): undefined reference to `png_read_update_info'
(.text+0x254): undefined reference to `png_get_rowbytes'
(.text+0x26e): undefined reference to `png_get_channels'
(.text+0x2e8): undefined reference to `png_read_image'
(.text+0x2fc): undefined reference to `png_read_end'
(.text+0x325): undefined reference to `png_destroy_read_struct'
(.text+0x369): undefined reference to `png_set_gamma'
(.text+0x37e): undefined reference to `png_set_expand'
(.text+0x39a): undefined reference to `png_destroy_read_struct'
(.text+0x3ae): undefined reference to `png_set_expand'
(.text+0x3cd): undefined reference to `png_destroy_read_struct'
(.text+0x3e6): undefined reference to `png_set_strip_16'
(.text+0x3f6): undefined reference to `png_set_expand'
/usr/lib/x86_64-linux-gnu/libXt.a(Shell.o): In function `SetSessionProperties':
(.text+0x2158): undefined reference to `SmcSetProperties'
(.text+0x221d): undefined reference to `SmcSetProperties'
(.text+0x22ab): undefined reference to `SmcDeleteProperties'
/usr/lib/x86_64-linux-gnu/libXt.a(Shell.o): In function `XtInteractPermission':
(.text+0x346b): undefined reference to `SmcInteractDone'
/usr/lib/x86_64-linux-gnu/libXt.a(Shell.o): In function `StopManagingSession.isra.10':
(.text+0x3499): undefined reference to `SmcCloseConnection'
/usr/lib/x86_64-linux-gnu/libXt.a(Shell.o): In function `GetIceEvent':
(.text+0x35ac): undefined reference to `SmcGetIceConnection'
(.text+0x35b8): undefined reference to `IceProcessMessages'
/usr/lib/x86_64-linux-gnu/libXt.a(Shell.o): In function `JoinSession':
(.text+0x3864): undefined reference to `SmcModifyCallbacks'
(.text+0x3870): undefined reference to `SmcClientID'
(.text+0x38c1): undefined reference to `SmcGetIceConnection'
(.text+0x38c9): undefined reference to `IceConnectionNumber'
(.text+0x3a29): undefined reference to `SmcOpenConnection'
/usr/lib/x86_64-linux-gnu/libXt.a(Shell.o): In function `XtSessionReturnToken':
(.text+0x4792): undefined reference to `SmcInteractDone'
(.text+0x47ce): undefined reference to `SmcInteractRequest'
(.text+0x4847): undefined reference to `SmcSaveYourselfDone'
(.text+0x4880): undefined reference to `SmcRequestSaveYourselfPhase2'
/usr/lib/x86_64-linux-gnu/libXt.a(Shell.o): In function `CallSaveCallbacks':
(.text+0x48b2): undefined reference to `SmcSaveYourselfDone'
/usr/lib/x86_64-linux-gnu/libXt.a(Shell.o): In function `XtCallCancelCallbacks':
(.text+0x49fb): undefined reference to `SmcSaveYourselfDone'
/usr/lib/x86_64-linux-gnu/libX11.a(ClDisplay.o): In function `XCloseDisplay':
(.text+0xd3): undefined reference to `xcb_disconnect'
/usr/lib/x86_64-linux-gnu/libX11.a(OpenDis.o): In function `OutOfMemory':
(.text+0x444): undefined reference to `xcb_disconnect'
/usr/lib/x86_64-linux-gnu/libX11.a(OpenDis.o): In function `XOpenDisplay':
(.text+0x87c): undefined reference to `xcb_get_setup'
(.text+0xe36): undefined reference to `xcb_get_maximum_request_length'
/usr/lib/x86_64-linux-gnu/libX11.a(xcb_disp.o): In function `_XConnectXCB':
(.text+0x14c): undefined reference to `xcb_parse_display'
(.text+0x1be): undefined reference to `xcb_connect_to_display_with_auth_info'
(.text+0x1de): undefined reference to `xcb_get_file_descriptor'
(.text+0x1fb): undefined reference to `xcb_generate_id'
(.text+0x26e): undefined reference to `xcb_connection_has_error'
(.text+0x286): undefined reference to `xcb_connect'
/usr/lib/x86_64-linux-gnu/libX11.a(xcb_io.o): In function `require_socket':
(.text+0x6a3): undefined reference to `xcb_take_socket'
/usr/lib/x86_64-linux-gnu/libX11.a(xcb_io.o): In function `poll_for_event':
(.text+0x824): undefined reference to `xcb_poll_for_event'
/usr/lib/x86_64-linux-gnu/libX11.a(xcb_io.o): In function `poll_for_response':
(.text+0x920): undefined reference to `xcb_poll_for_reply'
/usr/lib/x86_64-linux-gnu/libX11.a(xcb_io.o): In function `_XSend':
(.text+0xbb2): undefined reference to `xcb_writev'
/usr/lib/x86_64-linux-gnu/libX11.a(xcb_io.o): In function `_XEventsQueued':
(.text+0xc7d): undefined reference to `xcb_connection_has_error'
/usr/lib/x86_64-linux-gnu/libX11.a(xcb_io.o): In function `_XReadEvents':
(.text+0xd9a): undefined reference to `xcb_connection_has_error'
(.text+0xe34): undefined reference to `xcb_wait_for_event'
/usr/lib/x86_64-linux-gnu/libX11.a(xcb_io.o): In function `_XAllocIDs':
(.text+0xfaf): undefined reference to `xcb_generate_id'
/usr/lib/x86_64-linux-gnu/libX11.a(xcb_io.o): In function `_XReply':
(.text+0x113d): undefined reference to `xcb_wait_for_reply'
collect2: error: ld returned 1 exit status
/home/epics-admin/Documents/base-3.15.5/configure/RULES_BUILD:201: recipe for target 'medm' failed
make[2]: *** [medm] Error 1
make[2]: Leaving directory '/home/epics-admin/Documents/areaDetector/epics-extensions/medm/medm/O.linux-x86_64'
/home/epics-admin/Documents/base-3.15.5/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/epics-admin/Documents/areaDetector/epics-extensions/medm/medm'
/home/epics-admin/Documents/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'medm.install' failed
make: *** [medm.install] Error 2
MEDM compilation on Ubuntu 16.04 Alper Kinaci
Re: MEDM compilation on Ubuntu 16.04 Bob Soliday
Prev: Base R3.14.12.8-rc1 Published Andrew Johnson
Next: Re: Problem concerning callback function on multiple channels by using Cachannel Wang Xiaoqiang (PSI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: MEDM compilation on Ubuntu 16.04 Bob Soliday
Next: Re: MEDM compilation on Ubuntu 16.04 Jeong Han Lee
ANJ, 19 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
