1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem concerning callback function on multiple channels by using Cachannel
To: lzf neu <[email protected]>
Cc: Epics <[email protected]>
Date: Thu, 19 Jul 2018 19:55:34 +0000
Hi again,
To answer the second question,
> how to specify callback function on two or multiple PVs at once.
I added a descriptive snippet to the documents.
https://cachannel.readthedocs.io/en/latest/recipes.html#connect-multiple-channels-and-monitor-changes
Best
Xiaoqiang
> On 19 Jul 2018, at 16:45, lzf neu <[email protected]> wrote:
> Dear Dr. Wang and all,
> I have a problem concerning Cachannel to consult you please.
> The manual says:
> CaChannel.add_masked_array_event(...) can specify a callback function to be executed whenever changes occur to a PV.
> For example, I have two PVs, one is 'caLab:okok_left', another one is 'caLab:okok_right', their values change continuously, I try to write the following codes to monitor them:
> from CaChannel import ca, CaChannel
> class myDriver(Driver):
>     def __init__(self):
>         Driver.__init__(self)
>         self.chan_left = CaChannel('caLab:okok_left')
>         self.chan_left.searchw()
>         self.chan_left.add_masked_array_event(None, None, None, self.value_callback_left)
>         self.chan_right = CaChannel('caLab:okok_right')
>         self.chan_right.searchw()
>         self.chan_right.add_masked_array_event(None, None, None, self.value_callback_right)
>     def value_callback_left(self, epics_args_left, user_args_left):
>         value_left=epics_args_left['pv_value']
>         print "monitor caLab:okok_left"
>     def value_callback_right(self, epics_args_right, user_args_right):
>         value_right=epics_args_right['pv_value']
>         print "monitor caLab:okok_right"
> if __name__ == '__main__':
>     server = SimpleServer()
>     server.createPV(prefix, pvdb)
>     driver = myDriver()
>     while True:
>         server.process(0.1)
> However, It seems only the first PV('caLab:okok_left') is running and value_callback_left function works, the second one is blocked.
> I looked up the manual and know the following codes can perform the search request at once, but I have no idea how to write the callback function for each PVs at once.:
> chans = {pvname: CaChannel(pvname) for pvname in ['pv1', 'pv2', 'pv3', ...]}
> for chan in chans.values():
> chan.search()
> Therefore, if I have two PVs or multiple PVs, how to specify callback function on two or multiple PVs at once.
> Any help will be appreciated and could you please show me an example, thank you very much.
> Zhefu
Problem concerning callback function on multiple channels by using Cachannel lzf neu
Prev: Re: MEDM compilation on Ubuntu 16.04 Alper Kinaci
Next: Re: Delta Tau Power Brick LV-IMS driver Mark Davis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem concerning callback function on multiple channels by using Cachannel Wang Xiaoqiang (PSI)
Next: Base R3.14.12.8-rc1 Published Andrew Johnson
ANJ, 20 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
