1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Motor record question
To: 'Jörn Dreyer' <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Mon, 23 Jul 2018 09:50:01 -0500
The PIGCS2 support uses this approach.
CreateGCSController creates an instance of the appropriate class of controller based on the controller's version string:
https://github.com/epics-modules/motor/blob/3683d3f0eaae1b5893cd32615174b646cf259581/motorApp/PIGCS2Src/PIGCSController.cpp#L42
Kevin
On 07/23/2018 09:29 AM, Mark Rivers wrote:
Hi Jörn,
Perhaps what you are asking is if you can define multiple classes:
- Stepper with encoder
- Stepper without encoder
- Piezo with encoder
- Piezo without encoder
I think you should be able to do that using inheritance.  You could create a base axis class that your controller class knows about, but then have the actual axis objects based on derived classes that implement the different types.
Re: Motor record question Jörn Dreyer
RE: Motor record question Mark Rivers
Prev: RE: Motor record question Mark Rivers
Next: Re: Motor record question Jörn Dreyer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 24 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
