On 30.07.2018 03:41, Zik Saleeba wrote:
I'm new to EPICS and I'm writing a new driver for an IP connected xray pulse detection device. I was wondering if more experienced people can help me with a couple of questions I have.
Welcome to the wonderful world of EPICS device driver programming.
I've written a driver using PVs as the method for accessing the device state and it works but in some ways it seems unnecessarily awkward:
1. I use separate longin and longout record types for getting and setting integer device variables. Is it possible to use just a single record for both input and output of the same variable? That seems like it would avoid unnecessary duplication and confusion between the two records.
Yes you can, but EPICS does not really support that. You typically have
a set value and a readback value. Things really become awkward when you
want to update your set records with changes someone did outside EPICS.
2. My C code registers dsets for each of the input and output types I use. These each provide an init method and either a read or write method depending on the direction. PV client writes result in immediate calls to my write callback from the dset which is what I expected but PV client reads only access the internal stored state of the record, they don't call my read method. Instead I have to get the value into the record using a SCAN field to regularly update the record. This seems to call the read method correctly. Is there a way to get the PV read to directly call my read method so I can provide the instantaneously correct value rather than just the most recently polled value?
That is how EPICS is designed. The idea is that the load on the hardware
does not depend on the number of clients. So you set a scan rate and
whether 0 or 1000 clients want to know the value, it is always the same
to the device. However sometimes that sucks. In that case the client can
write a 1 to the .PROC field using a synchronous caput (which will wait
until the record has finished processing) and then read the value.
Thanks for your help,
Have you considered to use asyn and StreamDevice for your IP connected
device?
Dirk
- Re: Some questions from a first-time driver author Zik Saleeba
- Some questions from a first-time driver author Zik Saleeba
Re: Some questions from a first-time driver author Mark Rivers
<2018>
2025
2026
<2018>
2025
2026
