1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Some questions from a first-time driver author
To: [email protected]
Date: Mon, 30 Jul 2018 11:41:07 +1000
I'm new to EPICS and I'm writing a new driver for an IP connected xray pulse detection device. I was wondering if more experienced people can help me with a couple of questions I have.
I've written a driver using PVs as the method for accessing the device state and it works but in some ways it seems unnecessarily awkward:
1. I use separate longin and longout record types for getting and setting integer device variables. Is it possible to use just a single record for both input and output of the same variable? That seems like it would avoid unnecessary duplication and confusion between the two records.
2. My C code registers dsets for each of the input and output types I use. These each provide an init method and either a read or write method depending on the direction. PV client writes result in immediate calls to my write callback from the dset which is what I expected but PV client reads only access the internal stored state of the record, they don't call my read method. Instead I have to get the value into the record using a SCAN field to regularly update the record. This seems to call the read method correctly. Is there a way to get the PV read to directly call my read method so I can provide the instantaneously correct value rather than just the most recently polled value?
Thanks for your help,
  Zik Saleeba, Senior Software Engineer
  [email protected]
Re: Some questions from a first-time driver author Dirk Zimoch
Re: Some questions from a first-time driver author Mark Rivers
Prev: RE: Detect VC++ version in Makefile? Freddie Akeroyd - UKRI STFC
Next: Re: Some questions from a first-time driver author Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Detect VC++ version in Makefile? Mark Rivers
ANJ, 30 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
