1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: DBE_PROPERTY and Gateway
To: "'[email protected]'" <[email protected]>
Date: Fri, 3 Aug 2018 10:31:15 +0000
Hello,
I'm trying to pick up when a record's EGU changes within my OPI. I've configured the relevant setting in CS-Studio to monitor DBE_PROPERTY and this works fine locally.
However, when trying to do the same through a gateway CS-Studio will get the event but will not correctly update its units.
I wonder if this may be because the gateway is putting an undefined timestamp on the property event? E.g. I am getting:
C:\Instrument\Apps\EPICS>camonitor -m p LOCAL:PV
LOCAL:PV       2018-08-03 10:57:54.819651 10
C:\Instrument\Apps\EPICS>camonitor -m p PV:THROUGH:GATEWAY
PV:THROUGH:GATEWAY          2018-08-03 11:03:18.015750 10
PV:THROUGH:GATEWAY          <undefined> 10
I am running version 2.1.0 of the gateway, base 3.15.5 and running under Windows.
My gateway has the -mask set to vap, from a quick look through the gateway code I'm not sure if this is required or not?
I'm happy to dig a bit further into this and put the work in to fix it but before I do does anyone else have experience of running a similar set up? Or any general insight into the issue?
Dominic Oram
ISIS Neutron and Muon Source
Prev: Re: streamDevice 32-Bit ULONG endianess Dirk Zimoch
Next: Fwd: Re: Delta Tau motor control problem Mark Davis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Stream Device: Parse response that includes checksum of command string Dirk Zimoch
Next: Re: DBE_PROPERTY and Gateway Shankar, Murali
ANJ, 03 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
