1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Delta Tau motor control problem
To: "J. Lewis Muir" <[email protected]>
Date: Mon, 6 Aug 2018 07:29:30 -0400
Hi Lewis,
Sorry if my response was a bit confusing.  I did realize what you were asking, and I agree that having a stop button on the UI makes sense and would generally be a faster and safer alternative to correcting a typo in a setpoint.
But it is true that (prior to my setting the InPosBand value on the controller to a non-0 value) that using the STOP field of the motor record to stop a movement would also result in the motor record waiting for the status value from the controller to indicate the last movement-related command had completed, which would never happen unless/until I directly (via a command-line shell on the controller itself) gave the controller a new move command and let it complete the move (I expect doing it through the vendor's IDE would achieve the same thing).
Mark Davis NSCL/FRIB Control Systems Software Engineer [email protected]
On 8/3/2018 11:15 AM, J. Lewis Muir wrote:
On 08/02, Mark Davis wrote:
On 8/1/2018 3:45 PM, J. Lewis Muir wrote:
On 08/01, Mark Davis wrote:
I assume that the driver SHOULD still work with the default Yes
value.  Using the No value is not only less efficient, but could be
a real problem.  If someone makes a typo when entering a new
setpoint, it wouldn't matter if they realized their mistake and
quickly entered the correct setpoint before the device has moved
very much - It would still go all the way to the incorrect setting
before starting to move to the correct position.
Couldn't you just stop the move?
Interesting question.
I just tried giving it a new setpoint and then setting STOP to 1
before it finished moving.  But the same problem occurs:  It stops,
the done moving bit is till clear, and it won't take any new
setpoints.
My main point here was just about the user scenario you described where
the user makes a mistake and then tries to quickly enter the correct
setpoint, but the motor goes all the way to the incorrect setpoint
before starting the move to the correct setpoint.  I was just suggesting
that the user could quickly stop the move rather than quickly entering
a new setpoint.  That works, right?  The motor doesn't continue moving
to the incorrect setpoint after the user has commanded a stop, right?  I
understand your bigger issue with the behavior, but just from a safety
point of view for the user scenario you described, stopping the move is
no less safe than entering the correct setpoint.  If anything, stopping
is probably a little safer just because the user wouldn't have to think
about the correct setpoint and enter it; they could just stop the move.
But then you're saying that after commanding a stop, you can no longer
command a move to a new setpoint, ever?  That seems broken.
Lewis
Re: Delta Tau motor control problem Pearson, Matthew R.
Fwd: Re: Delta Tau motor control problem Mark Davis
Re: Delta Tau motor control problem J. Lewis Muir
Prev: Re: streamDevice 32-Bit ULONG endianess Dirk Zimoch
Next: Re: Delta Tau motor control problem [email protected]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Delta Tau motor control problem J. Lewis Muir
Next: Re: Delta Tau motor control problem Pearson, Matthew R.
ANJ, 06 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
