Hello Ahmad,
StreamDevice can read variable length arrays. You need to set NELM to
the maximum number of elements. StreamDevice will set NORD to the number
of elements found. Modern EPICS versions are able to handle variable
length arrays when the client sets up a monitor using 0 for the
requested array length. It should then use the current NORD value.
However StreamDevice reads arrays in rows, not columns. If you have a
waveform record and use { separator=" "; in "%i"; }, stream device will
repeat the "%i" up to NELM times (or until end of line, until the
separator is not found any more or until the conversion fails).
But in your case it seems you have interlaced arrays:
a[0] b[0] c[0] d[0] e[0] f[0] g[0] h[0]
a[1] b[1] c[1] d[1] e[1] f[1] g[1] h[1]
a[2] b[2] c[2] d[2] e[2] f[2] g[2] h[2]
So StreamDevice will see the first elements of each array, not all
elements of one array.
StreamDevice would be able to read rows with variable length:
a[0] a[1] a[2] ...
b[0] b[1] b[2] ...
c[0] c[1] c[2] ...
d[0] d[1] d[2] ...
e[0] e[1] e[2] ...
f[0] f[1] f[2] ...
g[0] g[1] g[2] ...
h[0] h[1] h[2] ...
Also this will not help:
in "%i %*i %*i %*i %*i %*i %*i %*i";
Because the first %i reads all the elements in the row before even
parsing the first %*i.
I need a new syntax to specify interlaces arrays.
The only way I can think to at the moment is to pre-process the input
with a regsub which removed the "other" array elements from the input,
but I need to test that first. It may be quite inefficient. Thus if <N>
becomes huge (say >1000) parsing may be quite slow.
I will tell you soon if I can find a solution...
Dirk
On 08.08.2018 11:09, Abdalla Ahmad wrote:
Hi
We are trying to implement an IOC for the Libera Spark BPM using stream
device, one of the tricky commands for example is TBT_IQ <N> which
returns a variable-length buffer of turn-by-turn data. An example:
TBT_IQ 3
22 -36 19 -38 16 -31 -3 -31
39 -212 29 -212 26 -163 -37 -150
39 -175 36 -176 27 -133 -21 -129
As you can see the output is an array of fixed columns (IQ parameters)
and variable rows (waveforms length). In a single line you can easily
parse and skip any value, but in this format we have two problems:
1.Is it possible to parse variable number of IN commands in the protocol
file?
2.Variable "IN" commands mean variable waveform length, is this possible
in EPICS?
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo <http://www.sesame.org.jo/>
- RE: Parse a variable-length, multi-column waveform in stream device Abdalla Ahmad
- Parse a variable-length, multi-column waveform in stream device Abdalla Ahmad
Re: IOC Crash with No Exception Generated Ricardo Cardenes via Tech-talk
<2018>
2025
2026
<2018>
2025
2026
