1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Parse a variable-length, multi-column waveform in stream device
Date: Wed, 8 Aug 2018 09:09:05 +0000
Hi
We are trying to implement an IOC for the Libera Spark BPM using stream device, one of the tricky commands for example is TBT_IQ <N> which returns a variable-length buffer of turn-by-turn data. An example:
TBT_IQ 3
22 -36  19 -38  16 -31  -3  -31
39 -212 29 -212 26 -163 -37 -150
39 -175 36 -176 27 -133 -21 -129
As you can see the output is an array of fixed columns (IQ parameters) and variable rows (waveforms length). In a single line you can easily parse and skip any value, but in this format we have two problems:
1.       Is it possible to parse variable number of IN commands in the protocol file?
2.       Variable "IN" commands mean variable waveform length, is this possible in EPICS?
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo
Re: Parse a variable-length, multi-column waveform in stream device Dirk Zimoch
Prev: Anton's retirement; caQtDM Mezger Anton Christian (PSI)
Next: Re: Parse a variable-length, multi-column waveform in stream device Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 08 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
