1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOC Crash with No Exception Generated
From: Ricardo Cardenes via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: Talk EPICS Tech <[email protected]>
Date: Wed, 8 Aug 2018 13:46:27 -1000
On Wed, Aug 8, 2018 at 1:07 PM Michael Davidsaver <[email protected]> wrote:
On 08/08/2018 03:16 AM, Ricardo Cardenes wrote:
>     When things are (apparently) working, what does epicsThreadShowAll() show?
> I can't really tell. At that point I can't interact with the iocsh console without making the system crash (see point #3), and CA is lost.
In this case, you could put epicsThreadShowAll() at the end of your startup script.
This is a capture from one of the times where the IOC booted all the way through:
tc2-sim-ioc> epicsThreadShowAll
            PRIORITY
    ID    EPICS RTEMS   STATE    WAIT         NAME
 0a010001   91 108         RUN          _main_
 0a010002   99 100        Wmsg 22010001 ImsgDaemon
 0a010003   10 189        Wmtx 1a010011 errlog
 0a010007   90 109        Wmtx 1a01002f NTPTimeSync
 0a010008   10 189        Wmtx 1a010038 taskwd
 0a010009   90 109        Wmtx 1a01003a ClockTimeSync
 0a01000a   70 129        Wmtx 1a010258 timerQueue
 0a01000b   59 140        Wmtx 1a01025d cbLow
 0a01000c   64 135        Wmtx 1a01025e cbMedium
 0a01000d   71 128        Wmtx 1a01025f cbHigh
 0a01000e   50 149        Wmtx 1a010262 dbCaLink
 0a01000f   58 141        Wmtx 1a010273 timerQueue
 0a010010   70 129        Wmtx 1a013619 scanOnce
 0a010011   60 139        Wmtx 1a01361b scan10
 0a010012   61 138        Wmtx 1a01361d scan5
 0a010013   62 137        Wmtx 1a01361f scan2
 0a010014   63 136        Wmtx 1a013621 scan1
 0a010015   64 135        Wmtx 1a013623 scan0.5
 0a010016   65 134        Wmtx 1a013625 scan0.2
 0a010017   66 133        Wmtx 1a013627 scan0.1
 0a010018   67 132        Wmtx 1a013629 scan0.05
 0a010019   18 181       Wevnt          CAS-TCP
 0a01001a   17 182       Delay          CAS-beacon
 0a01001b   16 183       Wevnt          CAS-UDP
 0a01001c   10 189       Delay          bcYearMonitor
 0a01001d   10 189        Wmtx 1a013657 ipToAsciiProxy
 0a01001e   51 148        Wmtx 1a013660 timerQueue
 0a01001f   52 147       Wevnt          CAC-UDP
 0a010020   10 189       Wevnt          CAC-repeater
 0a010021   51 148         RUN          CAC-event
 0a010022   50 149        Wmtx 1a0136c9 timeSeq
 0a010023   51 148        Wmtx 1a0136e0 CAC-event
 0a010024   50 149        Wmtx 1a0136e7 tcsSeqSysSimulate
 0a010025   50 149        Wmtx 1a0136f4 tcsSeqSysSimulate
 0a010026   50 149        Wmtx 1a013701 tcsSeqSysSimulate
 0a010027   50 149        Wmtx 1a01370e tcsSeqSysSimulate
 0a010028   50 149        Wmtx 1a01371b tcsSeqSysSimulate
 0a010029   50 149        Wmtx 1a013728 tcsSeqSysSimulate
 0a01002a   50 149        Wmtx 1a013735 tcsSeqSysSimulate
 0a01002b   50 149        Wmtx 1a013742 tcsSeqSysSimulate
 0a01002c   50 149        Wmtx 1a01374f tcsSeqSysSimulate
 0a01002d   50 149        Wmtx 1a01375c tcsSeqGsaoiSimulate
 0a01002e   50 149        Wmtx 1a013768 tcsSeqInit
 0a01002f   51 148        Wmtx 1a0136c0 timerQueue
 0a010030   52 147       Wevnt          CAC-UDP
 0a010031   50 149        Wmtx 1a01376a tcsSeqInit_1
 0a010032   50 149        Wmtx 1a01376c tcsSeqInit_2
 0a010033   50 149        Wmtx 1a01376e tcsSeqInit_3
 0a010034   50 149        Wmtx 1a013770 tcsSeqInit_4
 0a010035   50 149        Wmtx 1a013772 tcsSeqInit_5
 0a010036   50 149        Wmtx 1a013774 tcsSeqInit_6
 0a010037   50 149        Wmtx 1a013776 tcsSeqInit_7
 0a010038   50 149        Wmtx 1a013778 tcsSeqInit_8
 0a010039   50 149        Wmtx 1a01377a tcsSeqInit_9
 0a01003a   50 149        Wmtx 1a01377c tcsSeqInit_10
 0a01003b   50 149        Wmtx 1a01386f tcsReadHrwfs
>     I can't explain this.  The "main" thread should be running with high priority (91).
>     It could hang if an iocsh function blocks locking a mutex held by a hung thread.
>     But simply pressing "return" shouldn't do this.
> I can't either, the high priority of the "_main_" thread flies in the face of the "something is hogging the CPU for everything low-priority". iocsh would need to stall itself in the same way for everything else to die, and I'm not sure what could cause this. I've had a look at the code that reads commands from the prompt and it's relatively straightforward.
I'm not sure if it is relevant, but which readline variant are you using?
> $ grep COMMANDLINE_LIBRARY configure/os/CONFIG_SITE.Common.RTEMS
> COMMANDLINE_LIBRARY = EPICS
It occurs to me that, while at NSLS2, I encountered a bad interaction between libtecla and RTEMS 4.10
which sounds similar.
#COMMANDLINE_LIBRARY = LIBTECLA
COMMANDLINE_LIBRARY = READLINE
Using the standard config, seems to me.
Re: IOC Crash with No Exception Generated Andrew Johnson
IOC Crash with No Exception Generated Matt Rippa via Tech-talk
Re: IOC Crash with No Exception Generated Ricardo Cardenes via Tech-talk
Re: IOC Crash with No Exception Generated Michael Davidsaver
Prev: Re: IOC Crash with No Exception Generated Michael Davidsaver
Next: Re: Inverting control inputs on SIS3280? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: IOC Crash with No Exception Generated Andrew Johnson
ANJ, 09 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
