1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Inverting control inputs on SIS3280?
To: Jesse Hopkins <[email protected]>
Date: Thu, 9 Aug 2018 00:12:41 +0000
Hi Jesse,
I was able to test it on our lab IOC remotely. I am testing in input mode 3, where pin 4 is the Inhibit input.  I don't have any signal connected to pin 4.  When I set InputPolarity=Normal it counts fine in both scaler and MCS mode.  When I change InputPolarity=Inverted it does not count in either scaler or MCS mode.  This makes be believe that the changes I made are working.  Let me know if you find otherwise.
Sent: Wednesday, August 8, 2018 12:56 PM
To: Mark Rivers
Cc: [email protected]
Mark,
Thanks! That was quick. I won't have a chance to test it until the beam goes down, as we're using the SIS3820 for other experiments right now. I'll let you know how it goes.
All the best.
- Jesse
Jesse Hopkins, PhD
Beamline Scientist
BioCAT, Sector 18
Advanced Photon Source
On Wed, Aug 8, 2018 at 11:46 AM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
Hi Jesse,
I just added support to the driver and .template file for a new InputPolarity record for the SIS3820.  I have also updated the medm screen, and the .req file for autosave.
I am away from the lab, so I have not tested it yet.  But you can get the master branch of mca from Github and see if it works for you.
From: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> on behalf of Jesse Hopkins <[email protected]<mailto:[email protected]>>
Sent: Wednesday, August 8, 2018 10:46 AM
To: [email protected]<mailto:[email protected]>
Subject: Inverting control inputs on SIS3280?
Hi all,
I have an SIS3280 that I want to use the inhibit count signal for (this can be done on input 4 in mode 2, for example). Unfortunately,I want to inhibit on a TTL low signal, while my SIS3820 requires an active high inhibit. The SIS3820 does support inverting the control inputs, by setting bit 19 in the Acquisition Operation Mode. I didn't see it as a record in the documentation (http://cars9.uchicago.edu/software/epics/mcaStruck.html). Is there a way to do this from the EPICS driver? If not, is this something that you would consider adding to the driver?
(I could invert the signal externally, but it would be nice to avoid that complication)
Thanks.
- Jesse
Jesse Hopkins, PhD
Beamline Scientist
BioCAT, Sector 18
Inverting control inputs on SIS3280? Jesse Hopkins
Re: Inverting control inputs on SIS3280? Mark Rivers
Re: Inverting control inputs on SIS3280? Jesse Hopkins
Prev: Re: IOC Crash with No Exception Generated Ricardo Cardenes via Tech-talk
Next: Re: mrfioc2 Linux driver Steve Kinder - UKRI STFC
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Inverting control inputs on SIS3280? Jesse Hopkins
Next: bitSets and PVStructure Heinz Junkes
ANJ, 14 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
