1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mrfioc2 Linux driver
To: Steve Kinder - UKRI STFC <[email protected]>
Cc: EPICS <[email protected]>
Date: Fri, 10 Aug 2018 08:35:44 -0700
On 08/10/2018 06:31 AM, Steve Kinder - UKRI STFC wrote:
> # uname -a
> Linux TST-T02-IOC-CS-02.dl.ac.uk 3.10.0-514.6.1.el7.x86_64 #1 SMP Tue Jan 17 11:12:41 CST 2017 x86_64 x86_64 x86_64 GNU/Linux
So x86, I just wanted to be certain.  In the IOC shell run:
> pcidiagset 81 0 0
> pciread 32 0 0x64
The Version register is offset 0x2c.  The control register (0x4)
has a bit which enables byte order swapping for all registers
(including Control).
The sequence which sets this up is:.
https://github.com/epics-modules/mrfioc2/blob/master/evrMrmApp/src/drvemSetup.cpp#L575-L580
which I've not had problems with before.
If you want to go further you can run
> pcidiagset 81 0 0
> pciwrite 32 4 0
> pciread 32 0 0x64
> pciwrite 32 4 0x02000002
> pciread 32 0 0x64
One of these (I think the second) should show Version==0x17060207
> ________________________________
> From: Michael Davidsaver <[email protected]>
> Sent: 10 August 2018 13:14:11
> To: Kinder, Steve (STFC,DL,TECH)
> Cc: EPICS
> Steve, It looks like the value read from the Version register is backwards. 0x17 should be the MSB.  What does "uname -r" show?
> On Fri, Aug 10, 2018, 4:37 AM Steve Kinder - UKRI STFC <[email protected]<mailto:[email protected]>> wrote:
> Sorry to have more questions. But I am going in the right direction.
> On calling the setup from the IOC I now get:
> epics> mrmEvrSetupPCI("EVR-01", "81:0.0")
> Device EVR-01  129:0.0 slot=6
> Using IRQ 88
> FWVersion 0x07020617
> Error: Firmware does not correspond to an EVR
> Is this a symptom of using 2-2-0? Or is there some simpler explanation/solution? Sounds like the firmware isn't compatible with the support module and/or driver?
> Steve
> From: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> on behalf of Steve Kinder - UKRI STFC <[email protected]<mailto:[email protected]>>
> Sent: 07 August 2018 16:40:53
> To: [email protected]<mailto:[email protected]>
> Subject: mrfioc2 Linux driver
> Hello all
> I am trying to get an MRF PCIe-EVR-300DC configured and working on Linux using mrfioc2. I think I have an IOC built. I think I have some understanding of the parameters to mrmEvrSetupPCI(EVR-01, 1, 0, 0, 0). I could well be wrong on those but that isn't the source of my immediate problem. Executing the previous call gives:
> Can't open /sys/module/mrf/parameters/interfaceversion in order to read kernel module interface version. Is kernel module loaded?
> I found some documentation that indicates an MRF kernel driver is also required:
> $ make -C /location/of/mrmShared/linux \
> KERNELDIR=/lib/modules/`uname -r`/build modules_install
> $ sudo depmod -a
> $ sudo modprobe mrf
> I seem to need to execute the first line as root or I get permissions problems. However then I get:
> # make -C /home/controls/work/R3.14.12.5/support/mrfioc2/3-0-0/mrmShared/linux KERNELDIR=/lib/modules/`uname -r`/build modules_install
> make: Entering directory `/home/controls/work/R3.14.12.5/support/mrfioc2/3-0-0/mrmShared/linux'
> make -C /lib/modules/3.10.0-514.6.1.el7.x86_64/build M=/home/controls/work/R3.14.12.5/support/mrfioc2/3-0-0/mrmShared/linux modules_install
> make[1]: Entering directory `/usr/src/kernels/3.10.0-514.6.1.el7.x86_64'
> Makefile:641: Cannot use CONFIG_CC_STACKPROTECTOR_STRONG: -fstack-protector-strong not supported by compiler
>   DEPMOD  3.10.0-514.6.1.el7.x86_64
> make[1]: Leaving directory `/usr/src/kernels/3.10.0-514.6.1.el7.x86_64'
> make: Leaving directory `/home/controls/work/R3.14.12.5/support/mrfioc2/3-0-0/mrmShared/linux'
> The documentation dates back to 2015, Rev 7, so may be out of date?
> Any advice/help would be much appreciated. Further documentation?
> My kernel is 3.10.0-514.6.1.el7.x86_64, mrfioc2 3-0-0
> Thanks
> Steve
> d
> o
> m
> o
> d
> p
> r
> o
> b
> e
> m
> r
> f
Re: mrfioc2 Linux driver Steve Kinder - UKRI STFC
Re: mrfioc2 Linux driver Michael Davidsaver
Prev: Re: mrfioc2 Linux driver Steve Kinder - UKRI STFC
Next: Re: mrfioc2 Linux driver Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Re: mrfioc2 Linux driver Steve Kinder - UKRI STFC
ANJ, 13 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
