Hi Han,
The change to macLib I discussed is attached should you wish to apply it
to your copy of Base; I am committing this to the Base-3.15 branch so it
will appear in the next release.
- Andrew
On 07/31/2018 07:48 PM, Jeong Han Lee wrote:
> Hi Bruce and Andrew,
> My intention isn't in EPICS IOC DB, I would like to use msi to handle
> many configuration files instead of m4 in specifically ESS EPICS
> building environment and my own EPICS building environment as well. I
> would like to stay within existent epics applications as much as possible.
> I didn't look at its source codes, but it's better to have a flag to
> turn ".undefined" or ",recursive" warning texts.
> However, you can simply ignore my question if you don't have any
> resources. Maybe I can spend some time later to implement this feature
> by myself.
> Thanks for everything!
> Han
> On 08/01/2018 02:04 AM, Bruce Hill wrote:
>> I'd be in favor of removing them unless the -V flag was set.
>> Most of our msi use is intended to be loaded w/ macro definitions in
>> our st.cmd
>> file, so it's just annoying to see ",undefined" in files we've built
>> up from templates
>> when we know we'll define those macros later.
>> We set the -V flag only for those few msi uses where the files need to
>> have
>> all macros expanded. For those cases it would still be helpful to see
>> the ",undefined" or ",recursive" warning text in the msi output file
>> as we do now.
>> Cheers,
>> - Bruce
>> On 07/31/2018 02:57 PM, Andrew Johnson wrote:
>>> If there is a consensus that they are not useful I have a modification
>>> that removes the ",undefined" error indicator from the output generated
>>> by macLib (and hence the output from msi as long as the -V flag is used)
>>> when it encounters a $(macro) that it doesn't have a value for. There is
>>> also a ",recursive" marker for macros that are defined in a substitution
>>> file using themselves.
>>> As Bruce said, these markers don't change how a file is interpreted by
>>> an IOC when they are present, but if you feed the output into some other
>>> tool that doesn't understand them they might be annoying.
>>> Please discuss here if you particularly like or dislike these markers.
>>> - Andrew
>>> On 07/30/2018 04:23 PM, Jeong Han Lee wrote:
>>>> Hi,
>>>> Is there any other way to suppress or omit (,undefined) in the
>>>> output
>>>> file by using MSI?
>>>> Thanks,
>>>> Han
diff --git a/src/libCom/macLib/macCore.c b/src/libCom/macLib/macCore.c
index 55d3171..6a69a8a 100644
--- a/src/libCom/macLib/macCore.c
+++ b/src/libCom/macLib/macCore.c
@@ -902,11 +902,15 @@ static void refer ( MAC_HANDLE *handle, MAC_ENTRY *entry, int level,
- /* Bad reference, insert $(name,errval) */
+ /* Bad reference, insert either $(name,<error>) or $(name) */
if ( v < valend ) *v++ = '$';
if ( v < valend ) *v++ = '(';
cpy2val( refname, &v, valend );
- cpy2val( errval, &v, valend );
+ if (handle->flags & FLAG_SUPPRESS_WARNINGS) {
+ if ( v < valend ) *v++ = ')';
+ else
+ cpy2val( errval, &v, valend );
cleanup:
if (pop) {
- Re: a question for msi Andrew Johnson
- a question for msi Jeong Han Lee
- Re: a question for msi Bruce Hill
- Re: a question for msi Jeong Han Lee
Re: mrfioc2 Linux driver Michael Davidsaver
<2018>
2025
2026
<2018>
2025
2026
