1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: a question for msi
To: <[email protected]>
Date: Fri, 10 Aug 2018 14:06:41 -0500
My bad, updated patch attached. Note that this does not include the
changes necessary for the Base self-tests to pass, those will be in the
commit to the Git repo.
- Andrew
On 08/10/2018 11:43 AM, Andrew Johnson wrote:
> Hi Han,
> The change to macLib I discussed is attached should you wish to apply it
> to your copy of Base; I am committing this to the Base-3.15 branch so it
> will appear in the next release.
> - Andrew
diff --git a/src/libCom/macLib/macCore.c b/src/libCom/macLib/macCore.c
index 55d3171..6f84d6b 100644
--- a/src/libCom/macLib/macCore.c
+++ b/src/libCom/macLib/macCore.c
@@ -902,11 +902,16 @@ static void refer ( MAC_HANDLE *handle, MAC_ENTRY *entry, int level,
-    /* Bad reference, insert $(name,errval) */
+    /* Bad reference, insert either $(name,<error>) or $(name) */
     if ( v < valend ) *v++ = '$';
     if ( v < valend ) *v++ = '(';
     cpy2val( refname, &v, valend );
-    cpy2val( errval, &v, valend );
+    if (handle->flags & FLAG_SUPPRESS_WARNINGS) {
+        if ( v < valend ) *v++ = ')';
+        *v = '\0';
+    else
+        cpy2val( errval, &v, valend );
 cleanup:
     if (pop) {
Re: a question for msi Jeong Han Lee
Re: a question for msi Andrew Johnson
Re: a question for msi Bruce Hill
Prev: Re: a question for msi Andrew Johnson
Next: RE: Parse a variable-length, multi-column waveform in stream device Abdalla Ahmad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: a question for msi Jeong Han Lee
ANJ, 13 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
