1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Build "std" against base 3.14.12.3
Date: Thu, 16 Aug 2018 14:40:49 +0000
Hello everyone,
I got the EPICS module “std” from github (git clone https://github.com/epics-modules/std.git). From its configure/RELEASE, my initial thought was that the module should work with base-3.15.3 & asyn-R4-30. I tried that out and indeed the module “std” is built successfully against base-3.15.3.
Since we are still using base 3.14.12.3 at NSLS-II and we have lots of Debian packages already built for EPICS, I’d like to take the advantage of this existing infrastructure so that I am trying to build "std" against base 3.14.12.3 (provided by the Debian packages). The build failed when it tried to build the ioc application “stdApp”. It seems the library “libstd.*” is not found (not included in the path) although I can clearly see “lib/linux-x86_64/libstd.*” is actually generated.
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../delayCmd.cpp
/usr/bin/ar -rc   libstd.a        scalerRecord.o devScalerAsyn.o drvScalerSoft.o drvScaler974.o epidRecord.o devEpidSoft.o devEpidSoftCallback.o devEpidFast.o timestampRecord.o throttleRecord.o devTimeOfDay.o pvHistory.o femto.o delayDo.o delayCmd.o
/usr/bin/ranlib libstd.a
/usr/bin/g++ -o libstd.so -shared -fPIC -Wl,-soname,libstd.so -Wl,-hlibstd.so -L/usr/lib/epics/lib/linux-x86_64 -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64       -m64               scalerRecord.o devScalerAsyn.o drvScalerSoft.o drvScaler974.o epidRecord.o devEpidSoft.o devEpidSoftCallback.o devEpidFast.o timestampRecord.o throttleRecord.o devTimeOfDay.o pvHistory.o femto.o delayDo.o delayCmd.o    -lasyn -lseq -lpv -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64/libstd.so
mkdir ../../../lib
mkdir ../../../lib/linux-x86_64
Installing library ../../../lib/linux-x86_64/libstd.a
perl /usr/lib/epics/bin/linux-x86_64/registerRecordDeviceDriver.pl ../O.Common/std.dbd std_registerRecordDeviceDriver /epics/iocs/vme-03idc-testing/std > std.tmp
mv std.tmp std_registerRecordDeviceDriver.cpp
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64      -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       std_registerRecordDeviceDriver.cpp
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64      -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../stdMain.cpp
/usr/bin/g++ -o stdApp  -L/usr/lib/epics/lib/linux-x86_64 -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64       -m64               std_registerRecordDeviceDriver.o stdMain.o    -lstd -lseq -lpv -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
std_registerRecordDeviceDriver.o: In function `std_registerRecordDeviceDriver':
std_registerRecordDeviceDriver.cpp:(.text+0xc8): undefined reference to `pvar_func_doAfterIocInitRegistrar'
std_registerRecordDeviceDriver.cpp:(.text+0xd2): undefined reference to `pvar_func_delayDoRegistrar'
std_registerRecordDeviceDriver.o: In function `_GLOBAL__sub_I_std_registerRecordDeviceDriver':
std_registerRecordDeviceDriver.cpp:(.text.startup+0x3a3): undefined reference to `pvar_rset_throttleRSET'
std_registerRecordDeviceDriver.cpp:(.text.startup+0x3b1): undefined reference to `pvar_func_throttleRecordSizeOffset'
collect2: error: ld returned 1 exit status
make[3]: *** [stdApp] Error 1
make[3]: Leaving directory `/epics/iocs/vme-03idc-testing/std/stdApp/src/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/epics/iocs/vme-03idc-testing/std/stdApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/epics/iocs/vme-03idc-testing/std/stdApp'
make: *** [stdApp.install] Error 2
$ ls -lht lib/linux-x86_64/
total 1000K
-r--r--r-- 1 yhu yhu 633K Aug 16 09:36 libstd.a
-r-xr-xr-x 1 yhu yhu 355K Aug 16 09:36 libstd.so
yhu@xf03idc-ioc1:/epics/iocs/vme-03idc-testing/std
Then, I typed “make” again. The built passed and the ioc application “stdApp” was generated. See below. During the second “make”, we can see a new path (-L/epics/iocs/vme-03idc-testing/std/lib/linux-x86_64) is added and that path is where the generated libraries “libstd.*” are located.
$ make
make -C ./configure install
make[1]: Entering directory `/epics/iocs/vme-03idc-testing/std/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install
make[2]: Entering directory `/epics/iocs/vme-03idc-testing/std/configure/O.linux-x86_64'
perl /usr/lib/epics/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory `/epics/iocs/vme-03idc-testing/std/configure/O.linux-x86_64'
make -C O.RTEMS-mvme3100 -f ../Makefile TOP=../.. T_A=RTEMS-mvme3100 install
make[2]: Entering directory `/epics/iocs/vme-03idc-testing/std/configure/O.RTEMS-mvme3100'
make[2]: Leaving directory `/epics/iocs/vme-03idc-testing/std/configure/O.RTEMS-mvme3100'
make[1]: Leaving directory `/epics/iocs/vme-03idc-testing/std/configure'
make -C ./stdApp install
make[1]: Entering directory `/epics/iocs/vme-03idc-testing/std/stdApp'
make -C ./src install
make[2]: Entering directory `/epics/iocs/vme-03idc-testing/std/stdApp/src'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[3]: Entering directory `/epics/iocs/vme-03idc-testing/std/stdApp/src/O.linux-x86_64'
/usr/bin/g++ -o stdApp  -L/epics/iocs/vme-03idc-testing/std/lib/linux-x86_64 -L/usr/lib/epics/lib/linux-x86_64 -Wl,-rpath,/epics/iocs/vme-03idc-testing/std/lib/linux-x86_64 -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64       -m64               std_registerRecordDeviceDriver.o stdMain.o    -lstd -lseq -lpv -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
Installing script ../../../bin/linux-x86_64/showBurtDiff
mkdir ../../../bin
mkdir ../../../bin/linux-x86_64
Installing script ../../../bin/linux-x86_64/wrapCmd
Installing script ../../../bin/linux-x86_64/wrapper
Installing created file ../../../bin/linux-x86_64/stdApp
I guess there must be some changes/improvements on the Base build rules. I searched in tech-talk and tried all kinds of configurations as discussed at https://epics.anl.gov/tech-talk/2016/msg01063.php, but still could not build the module “std” by the first “make”.
Could anyone tell me how to solve this build problem if I really want to build “std” against base 3.14.12.3?
Best,
Yong Hu
NSLS-II Controls Group
RE: Build "std" against base 3.14.12.3 Mark Rivers
Prev: Re: CS-Studio Archive engine data base connection error Kasemir, Kay
Next: RE: EDM X/Y Plot segfaults Sinclair, John William
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Build "std" against base 3.14.12.3 Mark Rivers
ANJ, 16 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
