1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: a simple question about pyepics
From: Ricardo Cardenes via Tech-talk <[email protected]>
To: [email protected]
Cc: Talk EPICS Tech <[email protected]>
Date: Tue, 21 Aug 2018 05:02:08 -1000
Note epics.ca.find_libca() is just trying to find a regular dynicamic library, not one defining a Python module. So, in this case you either (assuming Linux):
  • have it in a directory accessible by any normal program (eg. can you run "caget" from the command line?)
  • have it in a directory included in your LD_LIBRARY_PATH (same as before, but defined in your environment, instead of in the /etc/ld.conf* files)
  • have the path to the library declared as PYEPICS_LIBCA
Any of thoe should work, from more general to more specific.
Now, the message you're getting ("cannot connect to lyx:ai3") seems to be consistent with CA not reaching the PV, so maybe:
  • EPICS_CA_ADDR_LIST is not defined correctly in the environment where you're running Python
  • The IOC is not accessible for some reason
  • lyx:ai3 does not exist? (typo??)
Cheers,
Ricardo
On Sat, Aug 18, 2018 at 6:14 PM 梁雅翔 <[email protected]> wrote:
Hi all,
      My environment:  CentOS 7(64),epics 3.15.5, python 2.7.5, pyepics from pip.
      I could not connect the pv when I using pyepics ( I set the EPICS_BASE,EPICS_HOST_ARCH, PYEPICS_LIBCA ).
    First I started the example IOC, and it worked fine.
    Then I try to connect it using pyepics.
Then I got these:
>>> import epics
>>> from epics import caget, caput
>>> m1 = caget('lyx:ai3')
print m1
>>> print m1
      I think maybe the question was installation. Since I didn't understand these sentences well in document of pyepics.
************ sentence in document **************************
Getting Started, Setting up the Epics Environment
Put the dynamic library somewhere in the Python path. A convenient place might be the same site-packages/pyepics library folder as the python package is installed.
To find out which CA library will be used by pyepics, use:
>>> import epics >>> epics.ca.find_libca()
      I knew where the libcaI is. But I didn't know where I should put it in python path. So I did not put the libca.so in python path.
     And others was fine. For python I knew such a little thing.
     Could someone give me some help. Why I could not connect it.
Thanks.
Liang yx
Re: a simple question about pyepics Andrew Johnson
a simple question about pyepics 梁雅翔
Prev: RE: Installing extra CONFIG_SITE file Hinko Kocevar
Next: Re: Installing extra CONFIG_SITE file Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: a simple question about pyepics Mooney, Tim M.
Next: Re: a simple question about pyepics Andrew Johnson
ANJ, 21 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
