1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Virtual circuit unresponsive on CA Gateway
To: "Hu, Yong" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 29 Aug 2018 06:35:19 +0000
Hello Yong,
Thanks a lot for your reply with the information.
We are using the 3.14.12.4 for the CA gateways.
For the information, we were running virtualized CA gateways and yesterday we have built an additional CA gateway on another physical machine without virtualization for comparison of virtualized and physical CA gateways.
As the result, we observed that the message is often being occurred on a virtualized CA gateway but no such message on the physical machine based CA gateway.
In our case for the moment it seems the message is related with performance of system such as network traffic processing.
Thanks again.
Sangwon
Sent: Wednesday, August 29, 2018 12:29 AM
To:
윤상원 <[email protected]>; [email protected]
Subject: Re: Virtual circuit unresponsive on CA Gateway
Hi Sangwon,
Take a look at this: https://bugs.launchpad.net/epics-base/+bug/541238
At the end, Andrew said “Probably fixed in later versions of Base ….”, “R3.14.10 released”.
Which version of Base is your CA gateway built against?
Best,
Yong
From: <[email protected]> on behalf of 윤상원 <[email protected]>
Date: Tuesday, August 28, 2018 at 3:29 AM
Subject: Virtual circuit unresponsive on CA Gateway
Hello,
We are running several CA gateways for providing access to PVs for clients including OPIs.
I observed the warning message “Virtual circuit unresponsive” on log files of the CA gateways.
For instance,
Aug 28 15:29:19 Warning: Virtual circuit unresponsive 172.17.101.21:5064
Aug 28 15:53:40 Warning: Virtual circuit unresponsive 172.17.101.80:5064
In addition, when the message is logged on a log file, connections to PVs of the IOC server related with the message (ex. 172.17.101.21) are disconnected.
At the time, connection to the same PVs which directly connects to the IOC server instead of CA gateway is still continued and client (camonitor) can receive changes from the IOC without disturbance.
For the information, we are running two versions of CA gateways, v2.0.4.0 and v2.1.0.
Could anyone please share any guidance or comments in the case?
Thanks in advance for your guidance or any comments.
Sangwon
Re: Virtual circuit unresponsive on CA Gateway Ralph Lange
Virtual circuit unresponsive on CA Gateway 윤상원
Re: Virtual circuit unresponsive on CA Gateway Hu, Yong
Prev: RE: Macro definitions for compiling areaDetector R3.3.2 Li, Ji
Next: Re: Virtual circuit unresponsive on CA Gateway Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Virtual circuit unresponsive on CA Gateway Hu, Yong
ANJ, 29 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
