1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem with database parsing in EPICS 7.0.1
Date: Tue, 4 Sep 2018 17:27:01 +0000
Folks,
I am trying to run EPICS 7.0.1.1 on my production IOCs, including vxWorks.
I am getting the following errors when loading records for the Allen Bradley driver.  These load fine on base 3.14.12.5 and 3.15.5.  These are the errors:
Can't set "13IDA:eps_bi1.INP" to "#L0 A0 C0 S11 F0 @" Error (512,512)
Error at or before ")" in file "/corvette/home/epics/support/CARS/CARSApp/Db/eps_inputs.db" line 6
Can't set "13IDA:eps_bi2.INP" to "#L0 A0 C0 S8 F0 @" Error (512,512)
Can't set "13IDA:eps_bi6.INP" to "#L0 A0 C2 S3 F0 @" Error (512,512)
This is the database file being loaded via dbLoadTemplate:
grecord(bi,"$(P)eps_bi$(N)")
        field(DESC,"$(DESC)")
        field(SCAN,"I/O Intr")
        field(DTYP,"AB-16 bit BI")
        field(INP,"#L0 A$(A) C$(C) S$(S) F0 @")
        field(ZNAM,"$(ZNAM)")
        field(ZSV, "$(ZSV)")
        field(ONAM,"$(ONAM)")
        field(OSV,"$(OSV)")
Is there something wrong with the INP line that is tolerated in 3.14 and 3.15 but not in 7.0?
Re: Problem with database parsing in EPICS 7.0.1 Williams Jr., Ernest L.
RE: Problem with database parsing in EPICS 7.0.1 Mark Rivers
Prev: CAEN V1720 EPICS Driver Kyle Hesse
Next: Re: Problem with database parsing in EPICS 7.0.1 Williams Jr., Ernest L.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 04 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
