1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem with database parsing in EPICS 7.0.1
Date: Tue, 4 Sep 2018 17:44:02 +0000
Ø  Is there something wrong with the INP line that is tolerated in 3.14 and 3.15 but not in 7.0?
I found the problem.  The INP field contained this:
        field(INP,"#L0 A$(A) C$(C) S$(S) F0 @")
That is incorrect, the “F0” does not belong there.  It was probably a leftover from a CAMAC_IO INP link.  It was ignored in 3.14. and 3.15, but generates an error in 7.0.  Removing the F0 fixes the errors.
Sent: Tuesday, September 4, 2018 12:27 PM
To: [email protected]
Subject: Problem with database parsing in EPICS 7.0.1
Folks,
I am trying to run EPICS 7.0.1.1 on my production IOCs, including vxWorks.
I am getting the following errors when loading records for the Allen Bradley driver.  These load fine on base 3.14.12.5 and 3.15.5.  These are the errors:
Can't set "13IDA:eps_bi1.INP" to "#L0 A0 C0 S11 F0 @" Error (512,512)
Error at or before ")" in file "/corvette/home/epics/support/CARS/CARSApp/Db/eps_inputs.db" line 6
Can't set "13IDA:eps_bi2.INP" to "#L0 A0 C0 S8 F0 @" Error (512,512)
Can't set "13IDA:eps_bi6.INP" to "#L0 A0 C2 S3 F0 @" Error (512,512)
This is the database file being loaded via dbLoadTemplate:
grecord(bi,"$(P)eps_bi$(N)")
        field(DESC,"$(DESC)")
        field(SCAN,"I/O Intr")
        field(DTYP,"AB-16 bit BI")
        field(ZNAM,"$(ZNAM)")
        field(ZSV, "$(ZSV)")
        field(ONAM,"$(ONAM)")
        field(OSV,"$(OSV)")
Re: Problem with database parsing in EPICS 7.0.1 Kim, Kukhee
Problem with database parsing in EPICS 7.0.1 Mark Rivers
Prev: Re: Problem with database parsing in EPICS 7.0.1 Williams Jr., Ernest L.
Next: VisualDCT bugfix release 2.8.1 Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Problem with database parsing in EPICS 7.0.1 Kim, Kukhee
ANJ, 05 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
