1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with database parsing in EPICS 7.0.1
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 5 Sep 2018 18:53:12 +0000
Hi Mark,
We are in SLAC, saw similar issues in epics 7 and had a chance to look at the code for parsing under the dbStatic.
The code has been re-witten many parts. The new code checks up the address syntax more strictly.
It does not allow extra ID character such as your case.
We also found the param string is not an optional anymore in epics 7 for all of the address types except RF_IO.
Even, we don't need to put param string in the address, we need to put "@" symbol to avoid error messages from the new parser.
ex) "#C0 S0" for VME_IO, the new parser gives an error message,
     To avoid the error message, we need to put "#C0 S0 @"
It looks like a bug, Till suggested a  bug fix for this issue in launchpad for epics-base.
Thank you.
Best regards,
Kukhee
Kukhee Kim
TID AIR Advanced Control System
SLAC National Accelerator Laboratory
2575 Sand Hill Rd, MS 94
Menlo Park, CA 94025
Email: [email protected]
Phone: (650)926-4912
Fax:   (650)926-2923
From: [email protected] <[email protected]> on behalf of Mark Rivers <[email protected]>
Sent: Tuesday, September 4, 2018 10:44 AM
To: [email protected]
Subject: RE: Problem with database parsing in EPICS 7.0.1
Ø  Is there something wrong with the INP line that is tolerated in 3.14 and 3.15 but not in 7.0?
I found the problem.  The INP field contained this:
        field(INP,"#L0 A$(A) C$(C) S$(S) F0 @")
That is incorrect, the “F0” does not belong there.  It was probably a leftover from a CAMAC_IO INP link.  It was ignored in 3.14. and 3.15, but generates an error in 7.0.  Removing the F0 fixes the errors.
Sent: Tuesday, September 4, 2018 12:27 PM
Subject: Problem with database parsing in EPICS 7.0.1
Folks,
I am trying to run EPICS 7.0.1.1 on my production IOCs, including vxWorks.
I am getting the following errors when loading records for the Allen Bradley driver.  These load fine on base 3.14.12.5 and 3.15.5.  These are the errors:
Can't set "13IDA:eps_bi1.INP" to "#L0 A0 C0 S11 F0 @" Error (512,512)
Error at or before ")" in file "/corvette/home/epics/support/CARS/CARSApp/Db/eps_inputs.db" line 6
Can't set "13IDA:eps_bi2.INP" to "#L0 A0 C0 S8 F0 @" Error (512,512)
Can't set "13IDA:eps_bi6.INP" to "#L0 A0 C2 S3 F0 @" Error (512,512)
This is the database file being loaded via dbLoadTemplate:
grecord(bi,"$(P)eps_bi$(N)")
        field(DESC,"$(DESC)")
        field(SCAN,"I/O Intr")
        field(DTYP,"AB-16 bit BI")
        field(ZNAM,"$(ZNAM)")
        field(ZSV, "$(ZSV)")
        field(ONAM,"$(ONAM)")
        field(OSV,"$(OSV)")
Re: Problem with database parsing in EPICS 7.0.1 Ralph Lange
Problem with database parsing in EPICS 7.0.1 Mark Rivers
RE: Problem with database parsing in EPICS 7.0.1 Mark Rivers
Prev: Re: Linux network tuning Kyle Lanclos
Next: Re: Problem with database parsing in EPICS 7.0.1 Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Problem with database parsing in EPICS 7.0.1 Mark Rivers
ANJ, 05 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
