1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Modbus Polling disable/enable
Date: Thu, 6 Sep 2018 09:15:55 +0000
Hello Tech-talk
I'm currently working in a module which relies on the modbus module and I need to create a button in the user
interface that allows to disable the read polling.
As it is working now, readPoller still reads the values even if the associated record is disabled.
I found two ways of achieving the goal:
    1. Set pollMsec  to a value less or equal to 0 and add an extra record for each register that has periodic scan and writes to MODBUS_READ (disable button would disable this record)
    2. Use absolute addressing (modbusStartAddress=-1) and change all the records to be periodic scanned
The downside of the first solution is that I need to have double records for each modbus register.
The downside of the second solution is that this might be a feature of absolute addressing that might change, as documentation
is not explicit on the point that absolute addressing mode disables the readPoller thread and calls doModbusIO on record's demand.
My question is:  what is the recommended way?
Best regards and thank you,
Emilio
RE: Modbus Polling disable/enable Mark Rivers
Prev: asking for help on s7nodave =?gb18030?b?s8nN/rvG5a0=?=
Next: Re: asking for help on s7nodave Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Modbus Polling disable/enable Mark Rivers
ANJ, 06 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
