On 09/08/2018 09:07 PM, Mark Rivers wrote:
> Hi Michael,
> You said:
>>> long soft_init(void *after)
>>> int before_after = (after == 0) ? 0 : 1
>> Device support init() is called with 'int'. So this test behaves unpredictably when sizeof(void*) != sizeof(int).
> I find this a bit confusing. devSup.h defines the following:
> #ifdef __cplusplus
> extern "C" {
> typedef long (*DEVSUPFUN)(void *); /* ptr to device support function*/
> #else
> typedef long (*DEVSUPFUN)(); /* ptr to device support function*/
> #endif
In C an empty argument list 'funcname()' declares a function which can accept _any_ argument list.
An actual empty argument list is 'funcname(void)'. I'm not going to try to explain the c++ aspect
now as I can't remember the reasoning.
It may be sufficient to show that in C the following is valid.
> DEVSUPFUN fn = ...;
> (*fn)(0); // call as fn(int)
> (*fn)("foo"); // call as fn(const char *)
> typedef struct dset { /* device support entry table */
> long number; /*number of support routines*/
> DEVSUPFUN report; /*print report*/
> DEVSUPFUN init; /*init support layer*/
> DEVSUPFUN init_record; /*init device for particular record*/
> DEVSUPFUN get_ioint_info; /* get io interrupt information*/
> /*other functions are record dependent*/
> } dset;
> So the init function is defined to be a DEVSUPFUN, which is function taking a void * argument and returning a long.
If you're confused that init is really 'init(int)', consider that get_ioint_info is
really 'get_ioint_info(int,dbCommon*,IOCSCANPVT*)'.
> There are no examples of the implementation of a device support init() function in the 3.15.5 Application Developer's Guide, though it does say in section 12.4.2 that the definition of the DSET init() function is:
> long init( int after);
> The only examples I can find of DSET init() functions in base are the devXXSoftCallback.c functions, where XX = ai, bi, si, etc. These do define init() to take an int argument.
> It appears to me that this is a very common mistake in synApps. This is a search of the entire synApps tree for files named dev*.c* which contain the string "init(void".
It is, in synapps and elsewhere. I'm hoping to begin moving away from untyped function pointers with:
https://code.launchpad.net/~epics-core/epics-base/+git/dtypedset/+merge/332730
Have a look at the proposed new 'struct typed_dset'.
> Does this mean that all of these files need to be changed to work reliably on systems where a void * and an int are different sizes?
Yes.
> Thanks,
> Mark
> -----Original Message-----
> From: Michael Davidsaver <[email protected]>
> Sent: Saturday, September 8, 2018 1:43 AM
> To: Andrew Johnson <[email protected]>; Mooney, Tim M. <[email protected]>; Mark Rivers <[email protected]>; Peterson, Kevin M. <[email protected]>
> Cc: [email protected]
> Subject: Re: Problems with soft motors
> On 09/07/2018 06:47 PM, Andrew Johnson wrote:
>> Hi Tim,
>> That code definitely looks kinkey, anything that relies on relative
>> thread priorities isn't going to work properly on an OS that doesn't
>> have a strict priority scheduler (Linux, Windows etc.).
>> Whether that's what's causing Mark's issue I can't say though, I did
>> no more than look at the routine you pointed to.
> soft_motor_task() is accessing records w/o locking. Also, access of union members 'mr->dinp.value.constantStr' vs. '.pv_link' w/o first testing 'mr->dinp.type' CONSTANT vs. CA_LINK/DB_LINK seems to me a recipe for surprise.
>> - Andrew
>> On 09/07/2018 12:15 PM, Mooney, Tim M. wrote:
>>> Hi Mark,
>>> I'll make a wild guess: The function, soft_init(), in
>>> motor/motorApp/SoftMotorSrc/devSoftAux.cc, seems vulnerable to
>>> changes in EPICS base that might not have had consequences for other
>>> code I know of. This code has always seemed a little hinky to me.
>>> Do you see the error message "cannot find dbCaLink task." in the IOC
>>> console output after iocInit?
>>> Tim Mooney ([email protected]) (630)252-5417 Beamline Controls Group
>>> (www.aps.anl.gov) Advanced Photon Source, Argonne National Lab
>>> *From:* Mark Rivers <[email protected]>
>>> *Sent:* Thursday, September 6, 2018 6:23:32 PM
>>> *To:* Peterson, Kevin M.; Mooney, Tim M.; Johnson, Andrew N.
>>> *Cc:* [email protected]
>>> *Subject:* Problems with soft motors
>>> Hi,
>>> I am having a serious problem with soft motor device support. These
>>> are databases that have worked fine for over 10 years. The databases
>>> are the ones in motorApp/Db: pseudoMotor.db and sumDiff2D.db.
>>> The databases are very simple: there are 2 real motors and 2 soft
>>> motors. One soft motor moves both real motors in the same direction,
>>> and the other soft motor moves the real motors in the opposite
>>> direction. The readback of the first soft motor is the average of
>>> the real motors, while the other is the difference of the real
>>> motors. The calculations are done in transform records. There is
>>> also a transform record that calculates when the soft motors are done
>>> moving, which is just the logical AND of the real motor .DMOV fields.
>>> The main problem I am seeing is that the transform records are
>>> updating OK, but for some motors these values are not getting back
>>> into the motor record.
>>> Here is an example of the debugging output of the devSoft.cc when a
>>> real motor is moved, and the soft motors, pm5 and pm6 are updating
>>> during that real motor move.
>>> soft_dinp_func(): HARDMOVE set for 13BMD:pm5.
>>> soft_rdbl_func(): updated RMP = 901 for 13BMD:pm5.
>>> update(): dmov=0 for 13BMD:pm5.
>>> update(): DMOV=0 for 13BMD:pm5.
>>> soft_rdbl_func(): updated RMP = 23 for 13BMD:pm6.
>>> update(): dmov=1 for 13BMD:pm6.
>>> update(): DMOV=1 for 13BMD:pm6.
>>> soft_rdbl_func(): updated RMP = 930 for 13BMD:pm5.
>>> soft_rdbl_func(): updated RMP = 80 for 13BMD:pm6.
>>> soft_dinp_func(): Done moving set for 13BMD:pm5.
>>> update(): DMOV=1 for 13BMD:pm5.
>>> soft_rdbl_func(): updated RMP = 940 for 13BMD:pm5.
>>> update(): dmov=1 for 13BMD:pm5.
>>> soft_rdbl_func(): updated RMP = 101 for 13BMD:pm6.
>>> In this case pm5 is working fine. It detected that dmov initially
>>> went to 0, and so at the end of the move it set the VAL field to
>>> match the RBV field.
>>> However, pm6 is not working correctly. It is detecting the readback
>>> changes, but it does not get the correct value of dmov. It always
>>> sees it as 1, not as 0 which it should. This means that at the end
>>> of the move it does not set the VAL field to match RBV. pm5 and pm6
>>> are configured identically, and they both get their DMOV value from
>>> the same field of the same transform record. Why does one work and one not work?
>>> Here are some symptoms of the problem:
>>> - Some soft motors work fine, and others do not, even when they are
>>> apparently configured identically. For one set of soft motors in one
>>> of my IOCs there are no updates printed with debugging in devSoft.cc.
>>> For these soft motors neither the RBV fields nor the VAL fields
>>> update at all when the real motors are moved.
>>> - The behavior of a particular motor is always the same, through
>>> multiple reboots, i.e. it either works or does not work.
>>> - This has all worked fine until this shutdown when I made a lot of changes:
>>> Base 3.15.5 > 7.0.1.1
>>> synApps modules (motor, calc, etc.): master January 2018 to
>>> master August 2018.
>>> - The devSoft.cc has not changed since 2015 so that cannot be the problem.
>>> - I tried reverting the motorRecord.cc to the commit from Jan. 4,
>>> 2018 which is what I was using in the last run when it worked fine.
>>> That did NOT fix the problem, which was very surprising. This
>>> suggests that perhaps the problem has something to do with links in
>>> the transform record, or some change in base?
>>> - I reverted the entire IOC application to the version I was running
>>> in the last run (3.15.5, master branch of synApps from January 2018)
>>> and all of the soft motors work fine. This seems to prove it is some
>>> software change in base 7.0.1 vs 3.15.5, or a change in synApps since
>>> January. But it is NOT the motor record itself.
>>> Help!
>>> Thanks,
>>> Mark
- Problems with soft motors Mark Rivers
- Re: Problems with soft motors Mooney, Tim M.
- Re: Problems with soft motors Andrew Johnson
- Re: Problems with soft motors Michael Davidsaver
- RE: Problems with soft motors Mark Rivers
RE: Keithley 2001 Digital multimeter IOC Mark Rivers
<2018>
2025
2026
<2018>
2025
2026
