1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with 7.0.1.1 static built pvget
To: Phillip Sorensen <[email protected]>
Cc: Andrew Johnson <[email protected]>, [email protected]
Date: Tue, 11 Sep 2018 07:20:49 +0100
On 09/10/2018 04:14 PM, Phillip Sorensen wrote:
> Good Morning,
> I have found what apears to be a bug in the release of base 7.0.1.1.  If I build base 7.0.1.1 with STATIC_BUILD=YES, I get the following error with pvget when I try to read a PV:
> "Unknown provider "pva" for channel TEST:ai1"
> If I set STATIC_BUILD=NO, pvget works fine.  If I clone the latest base and set STATIC_BUILD=YES then pvget also works as expected.
This issue, along with many others, has been fixed since the first 7.x release, and will be included in the next one.
https://github.com/epics-base/pvAccessCPP/commit/abce3faa8675c92b9e8b00a26ad17b81aed84557
Problem with 7.0.1.1 static built pvget Phillip Sorensen
Prev: Re: areaDetector driver for webcams? Mark Rivers
Next: No reply from device using asyn+streamdevice fatimah1129
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Problem with 7.0.1.1 static built pvget Phillip Sorensen
ANJ, 11 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
