Hi everyone, An IOC will have a device connected via Asyn+StreamDevice. The equipment is self-developed. The protocol is very simple,and the data is automatically uploaded. IOC compilation has no problems. But only one PV variable has a return value. The protocol file is as follows: Terminator = CR; get { in "%*c:%(\$8.VAL)c%(\$7.VAL)c%(\$6.VAL)c%(\$5.VAL)c%(\$4.VAL)c%(\$3.VAL)c%(\$2.VAL)c%c"; } The db file is as follows: record(stringin,"Va1") { field(SCAN,"5 second") field(DTYP,"stream") field(INP, "@devLeak.proto get(a,Va8,Va7,Va6,Va5,Va4,Va3,Va2) $(Port) $(Addr)") } record(stringin,"Va2") { } record(stringin,"Va3") { } record(stringin,"Va4") { } record(stringin,"Va5") { } record(stringin,"Va6") { } record(stringin,"Va7") { } record(stringin,"Va8") { } During the test, only Va1 has a return value, but sometimes the return value of Va1 is reflected in Va3. Test record is as follows: [root@localhost devLeak]# camonitor Va1 Va1 2018-09-11 08:58:08.420435 0 Va1 2018-09-11 09:46:39.943368 *** disconnected CA.Client.Exception............................................... Warning: "Virtual circuit disconnect" Context: "localhost:5064" Source File: ../cac.cpp line 1214 Current Time: Tue Sep 11 2018 09:46:39.943325761 .................................................................. Va1 2018-09-11 09:47:16.571558 0 Va1 2018-09-11 09:52:26.576883 1 Va1 2018-09-11 10:12:26.598784 0 -------------------------------------------------------------------------------------------------- [root@localhost devLeak]# camonitor Va3 Va3 2018-09-11 08:58:23.420664 0 Va3 2018-09-11 09:02:03.424510 1 Va3 2018-09-11 09:02:33.425080 0 Va3 2018-09-11 09:46:39.943488 *** disconnected CA.Client.Exception............................................... Warning: "Virtual circuit disconnect" Context: "localhost:5064" Source File: ../cac.cpp line 1214 Current Time: Tue Sep 11 2018 09:46:39.943456337 .................................................................. Va3 <undefined> UDF INVALID Va3 2018-09-11 09:47:16.571506 0 -------------------------------------------------------------------------------------------------- [root@localhost devLeak]# camoitor Va6 bash: camoitor: command not found [root@localhost devLeak]# camonitor Va6 Va6 2018-09-11 08:58:48.421098 0 Va6 2018-09-11 09:46:39.943463 *** disconnected CA.Client.Exception............................................... Warning: "Virtual circuit disconnect" Context: "localhost:5064" Source File: ../cac.cpp line 1214 Current Time: Tue Sep 11 2018 09:46:39.943431255 .................................................................. Va6 2018-09-11 09:47:21.571481 0 Since there are no compilation errors or warnings, I can't find the problem. Regards, Debbie,IMP epics base R3.14.12.2 stream 2.6 asyn 4.30 linux-x86
| ANJ, 11 Sep 2018 |
Home
News
About
Talk
Base
Modules
Extensions
