1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: No reply from device using asyn+streamdevice
To: <[email protected]>, rivers <[email protected]>, kasemirk <[email protected]>, tech-talk <[email protected]>
Date: Tue, 11 Sep 2018 10:00:01 +0200
Hello Debbie,
It would be helpful to know the data your device is sending.
Dirk
On 11.09.2018 09:49, [email protected] wrote:
Hi everyone,
An IOC will have a device connected via Asyn+StreamDevice. The equipment is self-developed. The protocol is very simple,and the data is automatically uploaded. IOC compilation has no problems. But only one PV variable has a return value.
     The protocol file is as follows:
       Terminator = CR;
get {
               in  "%*c:%(\$8.VAL)c%(\$7.VAL)c%(\$6.VAL)c%(\$5.VAL)c%(\$4.VAL)c%(\$3.VAL)c%(\$2.VAL)c%c";
The db file is as follows:
        record(stringin,"Va1")
           field(SCAN,"5 second")
           field(DTYP,"stream")
          field(INP, "@devLeak.proto get(a,Va8,Va7,Va6,Va5,Va4,Va3,Va2) $(Port) $(Addr)")
       record(stringin,"Va2")
      record(stringin,"Va3")
      record(stringin,"Va4")
     record(stringin,"Va5")
     record(stringin,"Va6")
     record(stringin,"Va7")
    record(stringin,"Va8")
During the test, only Va1 has a return value, but sometimes the return value of Va1 is reflected in Va3. Test record is as follows:
[root@localhost devLeak]# camonitor Va1
Va1                            2018-09-11 08:58:08.420435 0
Va1                            2018-09-11 09:46:39.943368 *** disconnected
CA.Client.Exception...............................................
     Warning: "Virtual circuit disconnect"
     Context: "localhost:5064"
     Source File: ../cac.cpp line 1214
     Current Time: Tue Sep 11 2018 09:46:39.943325761
Va1                            2018-09-11 09:47:16.571558 0
Va1                            2018-09-11 09:52:26.576883 1
Va1                            2018-09-11 10:12:26.598784 0
[root@localhost devLeak]# camonitor Va3
Va3                            2018-09-11 08:58:23.420664 0
Va3                            2018-09-11 09:02:03.424510 1
Va3                            2018-09-11 09:02:33.425080 0
Va3                            2018-09-11 09:46:39.943488 *** disconnected
     Current Time: Tue Sep 11 2018 09:46:39.943456337
Va3                            <undefined>  UDF INVALID
Va3                            2018-09-11 09:47:16.571506 0
[root@localhost devLeak]# camoitor Va6
bash: camoitor: command not found
[root@localhost devLeak]# camonitor Va6
Va6                            2018-09-11 08:58:48.421098 0
Va6                            2018-09-11 09:46:39.943463 *** disconnected
     Current Time: Tue Sep 11 2018 09:46:39.943431255
Va6                            2018-09-11 09:47:21.571481 0
Since there are no compilation errors or warnings, I can't find the problem.
Regards, Debbie,IMP epics base R3.14.12.2 stream 2.6 asyn 4.30 linux-x86
No reply from device using asyn+streamdevice fatimah1129
Prev: No reply from device using asyn+streamdevice fatimah1129
Next: ArchiveEngine Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Re: No reply from device using asyn+streamdevice Eric Norum
ANJ, 08 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
