The data uploaded by the underlying device is a:00000000; if Va1 is alarmed, the uploaded data is a:00000001 ----- 原始邮件 ----- 发件人:Dirk Zimoch <[email protected]> 收件人:<[email protected]>, rivers <[email protected]>, kasemirk <[email protected]>, tech-talk <[email protected]> 主题:Re: No reply from device using asyn+streamdevice 日期:2018年09月11日 16点00分 Hello Debbie, It would be helpful to know the data your device is sending. Dirk On 11.09.2018 09:49, [email protected] wrote: > Hi everyone, > An IOC will have a device connected via Asyn+StreamDevice. The equipment > is self-developed. The protocol is very simple,and the data is > automatically uploaded. IOC compilation has no problems. But only one PV > variable has a return value. > > The protocol file is as follows: > Terminator = CR; > get { > in > "%*c:%(\$8.VAL)c%(\$7.VAL)c%(\$6.VAL)c%(\$5.VAL)c%(\$4.VAL)c%(\$3.VAL)c%(\$2.VAL)c%c"; > > } > > > The db file is as follows: > > record(stringin,"Va1") > { > field(SCAN,"5 second") > field(DTYP,"stream") > field(INP, "@devLeak.proto get(a,Va8,Va7,Va6,Va5,Va4,Va3,Va2) > $(Port) $(Addr)") > } > > record(stringin,"Va2") > { > } > > record(stringin,"Va3") > { > } > > record(stringin,"Va4") > { > } > > record(stringin,"Va5") > { > } > > record(stringin,"Va6") > { > } > > record(stringin,"Va7") > { > } > > record(stringin,"Va8") > { > } > > During the test, only Va1 has a return value, but sometimes the return > value of Va1 is reflected in Va3. Test record is as follows: > [root@localhost devLeak]# camonitor Va1 > Va1 2018-09-11 08:58:08.420435 0 > Va1 2018-09-11 09:46:39.943368 *** disconnected > CA.Client.Exception............................................... > Warning: "Virtual circuit disconnect" > Context: "localhost:5064" > Source File: ../cac.cpp line 1214 > Current Time: Tue Sep 11 2018 09:46:39.943325761 > .................................................................. > Va1 2018-09-11 09:47:16.571558 0 > Va1 2018-09-11 09:52:26.576883 1 > Va1 2018-09-11 10:12:26.598784 0 > > > -------------------------------------------------------------------------------------------------- > > > [root@localhost devLeak]# camonitor Va3 > Va3 2018-09-11 08:58:23.420664 0 > Va3 2018-09-11 09:02:03.424510 1 > Va3 2018-09-11 09:02:33.425080 0 > Va3 2018-09-11 09:46:39.943488 *** disconnected > CA.Client.Exception............................................... > Warning: "Virtual circuit disconnect" > Context: "localhost:5064" > Source File: ../cac.cpp line 1214 > Current Time: Tue Sep 11 2018 09:46:39.943456337 > .................................................................. > Va3 <undefined> UDF INVALID > Va3 2018-09-11 09:47:16.571506 0 > > -------------------------------------------------------------------------------------------------- > > > [root@localhost devLeak]# camoitor Va6 > bash: camoitor: command not found > [root@localhost devLeak]# camonitor Va6 > Va6 2018-09-11 08:58:48.421098 0 > Va6 2018-09-11 09:46:39.943463 *** disconnected > CA.Client.Exception............................................... > Warning: "Virtual circuit disconnect" > Context: "localhost:5064" > Source File: ../cac.cpp line 1214 > Current Time: Tue Sep 11 2018 09:46:39.943431255 > .................................................................. > Va6 2018-09-11 09:47:21.571481 0 > > > Since there are no compilation errors or warnings, I can't find the > problem. > > Regards, Debbie,IMP epics base R3.14.12.2 stream 2.6 asyn 4.30 linux-x86 > >
| ANJ, 12 Sep 2018 |
Home
News
About
Talk
Base
Modules
Extensions
