1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 回复:Re: No reply from device using asyn+streamdevice
To: <[email protected]>, rivers <[email protected]>, kasemirk <[email protected]>, tech-talk <[email protected]>
Date: Wed, 12 Sep 2018 10:05:48 +0200
I will test your case, but have you considered using a mbbiDirect record with a %b format? (Assuming the digits can be 0 or 1)
Also if the device sends data automatically without being asked, SCAN "I/O Intr" should work better than "5 second".
record(mbbiDirect,"Va")
  field(SCAN,"I/O Intr")
  field(DTYP,"stream")
  field(INP, "@devLeak.proto get $(Port) $(Addr)")
get { in "a:%b"; }
In that case the bits will show up in Va.B0 ... Va.B7. Of course you can put them into individual records if required:
record(bi, "Va1")
  field(INP, "Va.B0 CP")
  field(ZNAM, "OK")
  field(ONAM, "Alarm")
  field(OSV,  "MAJOR")
On 12.09.2018 02:53, [email protected] wrote:
The data uploaded by the underlying device is a:00000000; if Va1 is alarmed, the uploaded data is a:00000001
----- 原始邮件 -----
发件人:Dirk Zimoch <[email protected]>
收件人:<[email protected]>, rivers <[email protected]>, kasemirk <[email protected]>, tech-talk <[email protected]>
主题:Re: No reply from device using asyn+streamdevice
日期:2018年09月11日 16点00分
Hello Debbie,
It would be helpful to know the data your device is sending.
Dirk
On 11.09.2018 09:49, [email protected] wrote:
 > Hi everyone,
 > An IOC will have a device connected via Asyn+StreamDevice. The equipment
 > is self-developed. The protocol is very simple,and the data is
 > automatically uploaded. IOC compilation has no problems. But only one PV
 > variable has a return value.
 >     The protocol file is as follows:
 >       Terminator = CR;
 > get {
 >                in
>  "%*c:%(\$8.VAL)c%(\$7.VAL)c%(\$6.VAL)c%(\$5.VAL)c%(\$4.VAL)c%(\$3.VAL)c%(\$2.VAL)c%c";
 > The db file is as follows:
 >        record(stringin,"Va1")
 >           field(SCAN,"5 second")
 >           field(INP, "@devLeak.proto get(a,Va8,Va7,Va6,Va5,Va4,Va3,Va2)
 > $(Port) $(Addr)")
 >       record(stringin,"Va2")
 >      record(stringin,"Va3")
 >      record(stringin,"Va4")
 >     record(stringin,"Va5")
 >     record(stringin,"Va6")
 >     record(stringin,"Va7")
 >    record(stringin,"Va8")
 > During the test, only Va1 has a return value, but sometimes the return
 > value of Va1 is reflected in Va3. Test record is as follows:
 > [root@localhost devLeak]# camonitor Va1
 > Va1                            2018-09-11 08:58:08.420435 0
> Va1                            2018-09-11 09:46:39.943368 *** disconnected
 > CA.Client.Exception...............................................
 >     Warning: "Virtual circuit disconnect"
 >     Context: "localhost:5064"
 >     Source File: ../cac.cpp line 1214
 >     Current Time: Tue Sep 11 2018 09:46:39.943325761
 > Va1                            2018-09-11 09:47:16.571558 0
 > Va1                            2018-09-11 09:52:26.576883 1
 > Va1                            2018-09-11 10:12:26.598784 0
 > [root@localhost devLeak]# camonitor Va3
 > Va3                            2018-09-11 08:58:23.420664 0
 > Va3                            2018-09-11 09:02:03.424510 1
 > Va3                            2018-09-11 09:02:33.425080 0
> Va3                            2018-09-11 09:46:39.943488 *** disconnected
 >     Current Time: Tue Sep 11 2018 09:46:39.943456337
 > Va3                            <undefined>  UDF INVALID
 > Va3                            2018-09-11 09:47:16.571506 0
 > [root@localhost devLeak]# camoitor Va6
 > bash: camoitor: command not found
 > [root@localhost devLeak]# camonitor Va6
 > Va6                            2018-09-11 08:58:48.421098 0
> Va6                            2018-09-11 09:46:39.943463 *** disconnected
 >     Current Time: Tue Sep 11 2018 09:46:39.943431255
 > Va6                            2018-09-11 09:47:21.571481 0
 > Since there are no compilation errors or warnings, I can't find the
 > problem.
 > Regards, Debbie,IMP epics base R3.14.12.2 stream 2.6 asyn 4.30 linux-x86
回复:Re: No reply from device using asyn+streamdevice fatimah1129
Prev: Re: Re: ArchiveEngine Silver
Next: Re: 回复:Re: No reply from device using asyn+streamdevice Christoph Schroeder
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: 回复:Re: No reply from device using asyn+streamdevice fatimah1129
ANJ, 12 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
