1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: Re: ArchiveEngine
Date: Wed, 12 Sep 2018 17:42:32 +0000
>> I run the quickstart.sh of archive appliance, try to archive a PV as "rootHost:ai2"
This is probably a matter of EPICS configuration. You can turn on verbose logging using quickstart.sh -v. This should turn on debug logging and you should get a little more detail on what's happening. You should see messages like
134883 [Event bus] DEBUG org.epics.archiverappliance.engine.pv.EPICS_V3_PV  - pv ofmshankar:arch:sine connectting
134884 [Event bus] DEBUG org.epics.archiverappliance.engine.pv.EPICS_V3_PV  - pv ofmshankar:arch:sine.RTYP connectting
If your EPICS configuration is set up correctly, you should see messages like
134953 [PVNameDispatcherPVNameEvents 0] DEBUG org.epics.archiverappliance.engine.pv.EPICS_V3_PV  - Connection changed for pv mshankar:arch:sine
and so on.
Murali
Prev: Re: ArchiveEngine Shen, Guobao
Next: SmarAct Picoscale device support Allan Serra Braga Bugyi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: BACnet Driver for EPICS Updated Webb, Steven B.
ANJ, 12 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
