Any error in engine(etl, mgmt)/logs/catalina.err?
There are a few environment variables which should be set properly, which I guess you have done it already.
For the connection issue, you can also try to set
export EPICS_CA_ADDR_LIST=localhost
for your testing case.
Guobao
I run the quickstart.sh of archive appliance, try to archive a PV as "rootHost:ai2" from testApp in the same machine. but at web page side, it
shows the pv can't be archived, not connected.
From the same shell, I can caget the value.
following is the message from starting the Archive appliance:
SRCDIR=/home/geyang/AA
DATADIR=/home/geyang/AA
Using org.epics.archiverappliance.config.persistence.InMemoryPersistence as the persistence layer
/home/geyang/AA/quickstart_tomcat
total 4
drwxrwxr-x 9 geyang geyang 4096 Sep 12 00:38 apache-tomcat-7.0.90
Using 64 bit versions of libraries
Starting in the foreground...
Using CATALINA_BASE: /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90
Using CATALINA_HOME: /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90
Using CATALINA_TMPDIR: /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/temp
Using JRE_HOME: /usr/local/jdk1.8.0_181/jre
Using CLASSPATH: /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/bin/bootstrap.jar:/home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/bin/tomcat-juli.jar
Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=128M; support was removed in 8.0
Sep 12, 2018 12:38:01 AM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: apache-tomcat-7.0.90/webapps/engine/WEB-INF/lib/native/linux-x86_64:/usr/local/lib:/usr/lib:/usr/X11R6/lib:/usr/local/epics/r3.14.12.5/base/lib/linux-x86_64:/usr/local/epics/r3.14.12.5/extensions/lib/linux-x86_64:/usr/local/epics/r3.14.12.5/extensions/src/epicsqt/framework/designer:/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
Sep 12, 2018 12:38:01 AM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-bio-17665"]
Sep 12, 2018 12:38:01 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 359 ms
Sep 12, 2018 12:38:01 AM org.apache.catalina.core.StandardService startInternal
INFO: Starting service Catalina
Sep 12, 2018 12:38:01 AM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.90
Sep 12, 2018 12:38:01 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/mgmt.war
Sep 12, 2018 12:38:03 AM org.apache.catalina.startup.TldConfig execute
INFO: At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
0 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Archiver Appliance Version 0.0.1_SNAPSHOT_14-June-2018T10-14-31
1 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService -
5 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - My identity is appliance0 and my mgmt URL is http://localhost:17665/mgmt/bpl
6 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Loading archappl.properties from the webapp classpath /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/mgmt/WEB-INF/classes/archappl.properties
7 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Done loading installation specific properties file from /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/mgmt/WEB-INF/classes/archappl.properties
38 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.ConvertPVNameToKey - The pv name components in this installation are separated by these characters [\:\-] and the key names are terminated by :
Sep 12, 2018 12:38:03 AM org.epics.archiverappliance.mgmt.pva.PvaMgmtService <init>
INFO: Creating an instance of PvaMgmtService
Sep 12, 2018 12:38:03 AM org.epics.archiverappliance.mgmt.pva.PvaServlet lambda$init$0
INFO: pool-1-thread-1
pvAccess Server v5.1.0-SNAPSHOT
CLASS : org.epics.pvaccess.server.impl.remote.ServerContextImpl
VERSION : pvAccess Server v5.1.0-SNAPSHOT
PROVIDER_NAMES : rpcService
BEACON_ADDR_LIST :
AUTO_BEACON_ADDR_LIST : true
BEACON_PERIOD : 15.0
BROADCAST_PORT : 5076
SERVER_PORT : 5075
RCV_BUFFER_SIZE : 16384
IGNORE_ADDR_LIST:
STATE : INITIALIZED
Sep 12, 2018 12:38:03 AM org.epics.archiverappliance.mgmt.pva.PvaServlet init
INFO: 2018-09-12T00:38:03.630-04:00[America/New_York]pvaMgmtService is operational.
Sep 12, 2018 12:38:03 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deployment of web application archive /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/mgmt.war has finished in 1,857 ms
INFO: Deploying web application archive /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/engine.war
Sep 12, 2018 12:38:05 AM org.apache.catalina.startup.TldConfig execute
1 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Archiver Appliance Version 0.0.1_SNAPSHOT_14-June-2018T10-14-31
4 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - My identity is appliance0 and my mgmt URL is http://localhost:17665/mgmt/bpl
4 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Loading archappl.properties from the webapp classpath /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/engine/WEB-INF/classes/archappl.properties
4 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Done loading installation specific properties file from /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/engine/WEB-INF/classes/archappl.properties
6 [localhost-startStop-1] INFO config.org.epics.archiverappliance.engine.pv.EngineContext - Creating 10 command threads as specified by org.epics.archiverappliance.engine.epics.commandThreadCount in archappl.properties
16 [JCA Command Thread] INFO config.org.epics.archiverappliance.engine.epics.JCAConfigGen - JCA/CAJ prop from archappl.properties is true
20 [JCA Command Thread] INFO config.org.epics.archiverappliance.engine.epics.JCAConfigGen - JCA Configuration:
<context class="com.cosylab.epics.caj.CAJContext">
<preemptive_callback>true</preemptive_callback>
<addr_list>192.168.1.112:5064 192.168.1.122:5064</addr_list>
<auto_addr_list>false</auto_addr_list>
<connection_timeout>30.0</connection_timeout>
<beacon_period>30.0</beacon_period>
<repeater_port>5065</repeater_port>
<server_port>5064</server_port>
<max_array_bytes>30.0</max_array_bytes>
<event_dispatcher class="org.epics.archiverappliance.engine.epics.JCAEventDispatcherBasedOnPVName"/>
</context>
31 [JCA Command Thread] INFO config.org.epics.archiverappliance.engine.epics.JCAConfigGen - JCA/CAJ prop from archappl.properties is true
36 [JCA Command Thread] INFO config.org.epics.archiverappliance.engine.epics.JCAConfigGen - JCA Configuration:
</context>
26 [JCA Command Thread] INFO config.org.epics.archiverappliance.engine.epics.JCAConfigGen - JCA/CAJ prop from archappl.properties is true
19 [JCA Command Thread] INFO config.org.epics.archiverappliance.engine.epics.JCAConfigGen - JCA/CAJ prop from archappl.properties is true
40 [JCA Command Thread] INFO config.org.epics.archiverappliance.engine.epics.JCAConfigGen - JCA Configuration:
</context>
41 [JCA Command Thread] INFO config.org.epics.archiverappliance.engine.epics.JCAConfigGen - JCA Configuration:
</context>
39 [JCA Command Thread] INFO config.org.epics.archiverappliance.engine.epics.JCAConfigGen - JCA Configuration:
</context>
38 [JCA Command Thread] INFO config.org.epics.archiverappliance.engine.epics.JCAConfigGen - JCA Configuration:
</context>
</context>
32 [JCA Command Thread] INFO config.org.epics.archiverappliance.engine.epics.JCAConfigGen - JCA/CAJ prop from archappl.properties is true
31 [JCA Command Thread] INFO config.org.epics.archiverappliance.engine.epics.JCAConfigGen - JCA Configuration:
</context>
</context>
46 [JCA Command Thread] INFO config.org.epics.archiverappliance.engine.epics.JCAConfigGen - JCA Configuration:
</context>
109 [localhost-startStop-1] INFO config.org.epics.archiverappliance.engine.pv.EngineContext - Creating 1 scan threads as specified by org.epics.archiverappliance.engine.epics.scanThreadCount in archappl.properties
182 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.ConvertPVNameToKey - The pv name components in this installation are separated by these characters [\:\-] and the key names are terminated by :
Sep 12, 2018 12:38:05 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deployment of web application archive /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/engine.war has finished in 1,957 ms
INFO: Deploying web application archive /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/etl.war
Sep 12, 2018 12:38:06 AM org.apache.catalina.startup.TldConfig execute
3 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - My identity is appliance0 and my mgmt URL is http://localhost:17665/mgmt/bpl
3 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Loading archappl.properties from the webapp classpath /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/etl/WEB-INF/classes/archappl.properties
3 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Done loading installation specific properties file from /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/etl/WEB-INF/classes/archappl.properties
5 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.ConvertPVNameToKey - The pv name components in this installation are separated by these characters [\:\-] and the key names are terminated by :
Sep 12, 2018 12:38:07 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deployment of web application archive /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/etl.war has finished in 1,421 ms
INFO: Deploying web application archive /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/retrieval.war
Sep 12, 2018 12:38:08 AM org.apache.catalina.startup.TldConfig execute
3 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Loading archappl.properties from the webapp classpath /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/retrieval/WEB-INF/classes/archappl.properties
3 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Done loading installation specific properties file from /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/retrieval/WEB-INF/classes/archappl.properties
4 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.ConvertPVNameToKey - The pv name components in this installation are separated by these characters [\:\-] and the key names are terminated by :
Sep 12, 2018 12:38:08 AM org.epics.pvaccess.server.impl.remote.tcp.BlockingTCPAcceptor initialize
INFO: Configured TCP port 5075 is unavailable, trying to assign it dynamically.
INFO: Using dynamically assigned TCP port 34845.
Sep 12, 2018 12:38:08 AM org.epics.archiverappliance.retrieval.pva.PvaDataRetrievalService <init>
INFO: Creating an instance of PvaDataRetrievalService
Sep 12, 2018 12:38:08 AM org.epics.archiverappliance.retrieval.pva.PvaDataRetrievalServlet init
INFO: 2018-09-12T00:38:08.444-04:00[America/New_York]pvaDataRetrievalService is operational.
Sep 12, 2018 12:38:08 AM org.epics.archiverappliance.retrieval.pva.PvaDataRetrievalServlet lambda$init$0
INFO: pool-13-thread-1
BEACON_ADDR_LIST :
SERVER_PORT : 34845
IGNORE_ADDR_LIST:
STATE : INITIALIZED
Sep 12, 2018 12:38:08 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deployment of web application archive /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/retrieval.war has finished in 1,422 ms
Sep 12, 2018 12:38:08 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/ROOT
INFO: Deployment of web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/ROOT has finished in 22 ms
INFO: Deploying web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/docs
INFO: Deployment of web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/docs has finished in 17 ms
INFO: Deploying web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/examples
INFO: Deployment of web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/examples has finished in 103 ms
INFO: Deploying web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/host-manager
INFO: Deployment of web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/host-manager has finished in 75 ms
INFO: Deploying web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/manager
INFO: Deployment of web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/manager has finished in 24 ms
Sep 12, 2018 12:38:08 AM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-17665"]
Sep 12, 2018 12:38:08 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 6953 ms
10040 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Post startup for MGMT
10041 [Startup executor] DEBUG config.org.epics.archiverappliance.config.DefaultConfigService - Initializing the MGMT webapp's clustering
10290 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Setting my cluster port base to 16670 and using interface 127.0.0.1
11080 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Loading PVTypeInfo from persistence
11081 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Done loading 0 PVs from persistence into cluster
11081 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Loading aliases from persistence
11081 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Done loading 0 aliases from persistence into cluster
11081 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Loading archive requests from persistence
11081 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Done loading 0 archive pv requests from persistence into cluster
11081 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Loading external servers from persistence
11081 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Done loading external servers from persistence
11087 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Start complete for webapp MGMT
11087 [Startup executor] INFO config.org.epics.archiverappliance.mgmt.MgmtPostStartup - Finished post startup for the mgmt webapp
12382 [http-bio-17665-exec-1] INFO config.org.epics.archiverappliance.mgmt.WebappReady - Received webAppReady from ENGINE
10517 [http-bio-17665-exec-2] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Post startup for ENGINE
10518 [http-bio-17665-exec-2] DEBUG config.org.epics.archiverappliance.config.DefaultConfigService - Initializing a non-mgmt webapp's clustering
10579 [http-bio-17665-exec-2] DEBUG config.org.epics.archiverappliance.config.DefaultConfigService - ENGINE connecting as a native client to 127.0.0.1:16670
10905 [http-bio-17665-exec-2] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Start complete for webapp ENGINE
13679 [http-bio-17665-exec-3] INFO config.org.epics.archiverappliance.mgmt.WebappReady - Received webAppReady from ETL
10132 [http-bio-17665-exec-4] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Post startup for ETL
10134 [http-bio-17665-exec-4] DEBUG config.org.epics.archiverappliance.config.DefaultConfigService - Initializing a non-mgmt webapp's clustering
10171 [http-bio-17665-exec-4] DEBUG config.org.epics.archiverappliance.config.DefaultConfigService - ETL connecting as a native client to 127.0.0.1:16670
11886 [Startup executor] DEBUG config.org.epics.archiverappliance.config.DefaultConfigService - Start archiving PVs from persistence.
11895 [Startup executor] DEBUG config.org.epics.archiverappliance.config.DefaultConfigService - Started 0 PVs from persistence.
10543 [http-bio-17665-exec-4] INFO config.org.epics.archiverappliance.etl.common.PBThreeTierETLPVLookup - Beginning ETL post startup; scheduling the configServiceSyncThread to keep the local ETL lifetimeId2PVName2LookupItem in sync
10543 [http-bio-17665-exec-4] DEBUG config.org.epics.archiverappliance.etl.common.PBThreeTierETLPVLookup - Done initializing ETL post startup.
10583 [http-bio-17665-exec-4] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Start complete for webapp ETL
15058 [http-bio-17665-exec-6] INFO config.org.epics.archiverappliance.mgmt.WebappReady - Received webAppReady from RETRIEVAL
10130 [http-bio-17665-exec-7] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Post startup for RETRIEVAL
10132 [http-bio-17665-exec-7] DEBUG config.org.epics.archiverappliance.config.DefaultConfigService - Initializing a non-mgmt webapp's clustering
10169 [http-bio-17665-exec-7] DEBUG config.org.epics.archiverappliance.config.DefaultConfigService - RETRIEVAL connecting as a native client to 127.0.0.1:16670
10514 [http-bio-17665-exec-7] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Start complete for webapp RETRIEVAL
15451 [http-bio-17665-exec-6] INFO config.org.epics.archiverappliance.mgmt.MgmtRuntimeState - All components in this appliance have started up. We should be ready to start accepting UI requests
Hi Geyang,
By meaning ArchiverEngine, I guess you are referring to Archiver Appliance?
If yes, you can simply download the pre-built binary from
https://github.com/slacmshankar/epicsarchiverap/releases/
There is a Quick Start how to run it on RHEL/CentOS for your testing purpose.
https://slacmshankar.github.io/epicsarchiver_docs/quickstart.html
Once you get your data archived, you can easily configure CS-S, and browse your history data.
You do not have to compile it yourself.
The answer might be different if you want to use RDB based archiver.
Guobao
I downloaded a pre-compiled version of CSS from https://ics-web.sns.ornl.gov/css/. But
I can't find where is ArchiveEngine executable file. Need I download the source code from github and compile it to get ArchiveEngine file? My system is CENTOS7.
Thanks a lot for your help.
Re: No reply from device using asyn+streamdevice Eric Norum
Re: Re: Re: ArchiveEngine Shankar, Murali
<2018>
2025
2026
Re: Re: ArchiveEngine Silver
<2018>
2025
2026
