1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: No reply from device using asyn+streamdevice
To: [email protected]
Cc: EPICS <[email protected]>
Date: Wed, 12 Sep 2018 06:31:05 -0700
I’ve been following this thread while on travel the past few days.  One thing that I’ve not seen is the results of enabling ASYN device I/O messages to see what the device is actually sending.
What do you see if you add the following to your st.cmd file after configuring the port:
asynSetTraceIOMask(“<<your port name>>”,0,0x2)
asynSetTraceMask(“<<your port name>>”,0,0x9)
Apologies if this has already been mentioned and I’ve just missed the message suggesting it.
On Sep 12, 2018, at 6:09 AM, Dirk Zim
och <[email protected]> wrote:
Hi Debbie,
I am running a test setup with your records and protocol now for several hours and got no wrong inputs.
The only thing is that the order of digits is a bit strange: The 1st digit ends up in Va2, the 2nd in Va3 and so on until the 7th in Va8 and the 8th in Va1. But that is just a consequence of the order of your parameters.
I can only imagine that your device indeed sends the data you see.
Have you tried to monitor the data with another independent program to prove that the device really sends the data you expect?
Dirk
Eric Norum
[email protected]
回复:Re: No reply from device using asyn+streamdevice fatimah1129
Re: 回复:Re: No reply from device using asyn+streamdevice Dirk Zimoch
Prev: Re: 回复:Re: No reply from device using asyn+streamdevice Dirk Zimoch
Next: Re: ArchiveEngine Shen, Guobao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: SmarAct Picoscale device support Allan Serra Braga Bugyi
ANJ, 12 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
