1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Bypassing Options in ImageMode in AreaDetector
To: Iain Marcuson <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 14 Sep 2018 13:58:53 +0000
You could layer your own mbbo record on top which then writes to the original area detector record.
In your record, note that you don't have to use
ZRVL = 0
_ONVL_ = 1
TWVL = 2
You can use
ZRVL = 1
_ONVL_ = 2
TWVL = 16
So define the items in your mbbo to list only those values that you want to show on the UI,
and create your own top-level UI  with your mbbo.
-Kay
From: [email protected] <[email protected]> on behalf of Iain Marcuson <[email protected]>
Sent: Friday, September 14, 2018 9:50 AM
To: [email protected]
Subject: Bypassing Options in ImageMode in AreaDetector
I am using areaDetector in a product.  We only want to use “Single” and “Continuous” ImageMode, not “Multiple”.  In the first implementation, I modified ADBase.template to remove the “Multiple” option.  For a more portable solution, I made a new mbbo record without the Multiple option, and set the OUT field to $(P)$(R)ImageMode.  However, I had to define “ZRVAL” and “TWVAL”, skipping “ONVAL” (Multiple), leaving a gap in a drop-down menu.  Is there a way to avoid this gap?
Thank you,
Iain Marcuson
Software Engineer, Sydor Technologies
585.278.1168 | www.SydorTechnologies.com
Skype: [email protected]
Bypassing Options in ImageMode in AreaDetector Iain Marcuson
Prev: Bypassing Options in ImageMode in AreaDetector Iain Marcuson
Next: RE: Bypassing Options in ImageMode in AreaDetector Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 14 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
