1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: BlackFly S with ADSpinnaker [SEC=UNCLASSIFIED]
To: "'POZAR, Andraz'" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 19 Sep 2018 13:43:15 +0000
Try building everything static.
I had the exact same issue with an Oryx camera on Ubuntu 18 with the very latest Spinnaker SDK. AD did not detect any cameras while the vendor software did. But the static build worked, no idea why. The exact same code fragments are used to initialize and detect the camera as is used in the example programs.
From: [email protected] <[email protected]> On Behalf Of POZAR, Andraz
Sent: Wednesday, September 19, 2018 12:02 AM
To: [email protected]
Subject: BlackFly S with ADSpinnaker [SEC=UNCLASSIFIED]
Hi all,
I’m struggling to get an IOC to connect to my BlackFly S camera which uses Spinnaker software.  I’m using the HEAD revision of areaDetector with ADCore, ADSupport and ADSpinnaker from the GitHub.
I’ve managed to build all components but when I start the IOC, it fails to connect to the camera:
ADSpinnakerConfig("SP1", 18260782, 0x1, 0)
2018/09/19 14:48:27.180 ADSpinnaker:connectCamera: no cameras found
2018/09/19 14:48:27.180 ADSpinnaker:ADSpinnaker:  camera connection failed (3)
Number of cameras detected: 0
I can see the camera using arv-tool-0.4 from aravisGigE component and list it’s feature without any problems.
Here’s my setup, as per documentation:
-          Ubuntu 16.04
-          GLIBC 2.23
-          GLIBCXX 3.4.21
-          GCC 5.4
Has anyone managed to get the IOC to talk to BlackFly S, model: BFS-PGE-16S2M-CS?
Andraz Pozar
Controls Engineer
Australian Synchrotron
Tel
Email
Web
+61 3 8540 5387
[email protected]
www.ansto.gov.au
fb tw ln yt
ansto
Important:
This transmission is intended only for the use of the intended addressee. It is confidential to the intended addressee and may contain privileged information and or copyright material. If this email is not intended for your attention, any use, printing, storage, reproduction or further disclosure of this communication (including all attachments) is strictly forbidden. If you have received this transmission in error, please notify me by telephone or email and immediately delete all copies of this transmission as well as any attachments.
BlackFly S with ADSpinnaker [SEC=UNCLASSIFIED] POZAR, Andraz
Prev: Re: BlackFly S with ADSpinnaker [SEC=UNCLASSIFIED] Mark Rivers
Next: Re: asynPortDriver and read/write access to record fields Loeher, Bastian Dr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: BlackFly S with ADSpinnaker [SEC=UNCLASSIFIED] POZAR, Andraz
Next: measComp 2-1 and TC32 John Dobbins
ANJ, 24 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
