1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: BlackFly S with ADSpinnaker [SEC=UNCLASSIFIED]
Date: Tue, 25 Sep 2018 03:16:54 +0000
Hi Mark,
Here's my make output of ADSpinnaker:
> make
make -C ./configure install
make[1]: Entering directory '/home/ics/opt/areaDetector/ADSpinnaker/configure'
perl -CSD /home/ics/p4/tec/epics/base/trunk/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/home/ics/opt/areaDetector/ADSpinnaker/configure/O.linux-x86_64'
perl -CSD /home/ics/p4/tec/epics/base/trunk/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory '/home/ics/opt/areaDetector/ADSpinnaker/configure/O.linux-x86_64'
make[1]: Leaving directory '/home/ics/opt/areaDetector/ADSpinnaker/configure'
make -C ./spinnakerSupport install
make[1]: Entering directory '/home/ics/opt/areaDetector/ADSpinnaker/spinnakerSupport'
perl -CSD /home/ics/p4/tec/epics/base/trunk/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ..//..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=..//.. \
make[2]: Entering directory '/home/ics/opt/areaDetector/ADSpinnaker/spinnakerSupport/O.linux-x86_64'
Installing libSpinnaker.so
mkdir ../../lib
mkdir ../../lib/linux-x86_64
Installing libSpinnaker.so.1
Installing libSpinnaker.so.1.10.0.31
Installing libGenApi_gcc540_v3_0.so
Installing libGCBase_gcc540_v3_0.so
Installing libLog_gcc540_v3_0.so
Installing libMathParser_gcc540_v3_0.so
Installing libNodeMapData_gcc540_v3_0.so
Installing libXmlParser_gcc540_v3_0.so
Installing libptgreyvideoencoder.so
Installing libptgreyvideoencoder.so.1
Installing libptgreyvideoencoder.so.1.10.0.31
make[2]: Leaving directory '/home/ics/opt/areaDetector/ADSpinnaker/spinnakerSupport/O.linux-x86_64'
make[1]: Leaving directory '/home/ics/opt/areaDetector/ADSpinnaker/spinnakerSupport'
make -C ./spinnakerApp install
make[1]: Entering directory '/home/ics/opt/areaDetector/ADSpinnaker/spinnakerApp'
make -C ./src install
make[2]: Entering directory '/home/ics/opt/areaDetector/ADSpinnaker/spinnakerApp/src'
perl -CSD /home/ics/p4/tec/epics/base/trunk/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '/home/ics/opt/areaDetector/ADSpinnaker/spinnakerApp/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -D LINUX -std=c++11 -Wno-unknown-pragmas  -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/ics/p4/tec/epics/asyn/trunk/include     -I/home/ics/opt/areaDetector/ADSupport/include/os/Linux -I/home/ics/opt/areaDetector/ADSupport/include   -I/home/ics/opt/areaDetector/ADCore/include -I/home/ics/p4/tec/epics/base/trunk/include/compiler/gcc -I/home/ics/p4/tec/epics/base/trunk/include/os/Linux -I/home/ics/p4/tec/epics/base/trunk/include     -I ../../../spinnakerSupport/include    -MM -MF Acquisition.d  ../Acquisition.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -D LINUX -std=c++11 -Wno-unknown-pragmas  -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/ics/p4/tec/epics/asyn/trunk/include     -I/home/ics/opt/areaDetector/ADSupport/include/os/Linux -I/home/ics/opt/areaDetector/ADSupport/include   -I/home/ics/opt/areaDetector/ADCore/include -I/home/ics/p4/tec/epics/base/trunk/include/compiler/gcc -I/home/ics/p4/tec/epics/base/trunk/include/os/Linux -I/home/ics/p4/tec/epics/base/trunk/include     -I ../../../spinnakerSupport/include    -MM -MF ADSpinnaker.d  ../ADSpinnaker.cpp
Installing dbd file ../../../dbd/ADSpinnakerSupport.dbd
mkdir ../../../dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -D LINUX -std=c++11 -Wno-unknown-pragmas  -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/ics/p4/tec/epics/asyn/trunk/include     -I/home/ics/opt/areaDetector/ADSupport/include/os/Linux -I/home/ics/opt/areaDetector/ADSupport/include   -I/home/ics/opt/areaDetector/ADCore/include -I/home/ics/p4/tec/epics/base/trunk/include/compiler/gcc -I/home/ics/p4/tec/epics/base/trunk/include/os/Linux -I/home/ics/p4/tec/epics/base/trunk/include     -I ../../../spinnakerSupport/include    -c ../ADSpinnaker.cpp
/usr/bin/ar -rc    libADSpinnaker.a         ADSpinnaker.o
/usr/bin/ranlib libADSpinnaker.a
Installing library ../../../lib/linux-x86_64/libADSpinnaker.a
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -D LINUX -std=c++11 -Wno-unknown-pragmas  -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/ics/p4/tec/epics/asyn/trunk/include     -I/home/ics/opt/areaDetector/ADSupport/include/os/Linux -I/home/ics/opt/areaDetector/ADSupport/include   -I/home/ics/opt/areaDetector/ADCore/include -I/home/ics/p4/tec/epics/base/trunk/include/compiler/gcc -I/home/ics/p4/tec/epics/base/trunk/include/os/Linux -I/home/ics/p4/tec/epics/base/trunk/include     -I ../../../spinnakerSupport/include    -c ../Acquisition.cpp
../Acquisition.cpp: In function 'int main(int, char**)':
../Acquisition.cpp:402:19: warning: passing NULL to non-pointer argument 1 of 'Spinnaker::CameraPtr::CameraPtr(int)' [-Wconversion-null]
  CameraPtr pCam = NULL;
../Acquisition.cpp:426:7: warning: passing NULL to non-pointer argument 1 of 'virtual Spinnaker::CameraPtr& Spinnaker::CameraPtr::operator=(int)' [-Wconversion-null]
  pCam = NULL;
/usr/bin/g++ -o Acquisition -Wl,-Bstatic -L/home/ics/opt/areaDetector/ADSpinnaker/lib/linux-x86_64 -Wl,-rpath,/home/ics/opt/areaDetector/ADSpinnaker/lib/linux-x86_64           -rdynamic -m64            Acquisition.o     -Wl,-Bdynamic -lSpinnaker -lpthread   -lreadline -lncurses -lm -lrt -ldl -lgcc
Installing created executable ../../../bin/linux-x86_64/Acquisition
mkdir ../../../bin
mkdir ../../../bin/linux-x86_64
make[3]: Leaving directory '/home/ics/opt/areaDetector/ADSpinnaker/spinnakerApp/src/O.linux-x86_64'
make[2]: Leaving directory '/home/ics/opt/areaDetector/ADSpinnaker/spinnakerApp/src'
make -C ./Db install
make[2]: Entering directory '/home/ics/opt/areaDetector/ADSpinnaker/spinnakerApp/Db'
mkdir O.Common
make[3]: Entering directory '/home/ics/opt/areaDetector/ADSpinnaker/spinnakerApp/Db/O.linux-x86_64'
Installing template file ../../../db/spinnaker.template
mkdir ../../../db
Installing template file ../../../db/spinnakerConvertPixelFormat.template
Installing template file ../../../db/spinnakerIntReadback.template
Installing template file ../../../db/spinnakerFloatProp.template
Installing template file ../../../db/spinnakerFloatMinMax.template
Installing template file ../../../db/spinnakerMenuProp.template
Installing template file ../../../db/spinnakerCmdProp.template
Installing template file ../../../db/spinnakerPropAuto.template
Installing template file ../../../db/spinnakerPropEnable.template
make[3]: Leaving directory '/home/ics/opt/areaDetector/ADSpinnaker/spinnakerApp/Db/O.linux-x86_64'
make[2]: Leaving directory '/home/ics/opt/areaDetector/ADSpinnaker/spinnakerApp/Db'
make -C ./op install
make[2]: Entering directory '/home/ics/opt/areaDetector/ADSpinnaker/spinnakerApp/op'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory '/home/ics/opt/areaDetector/ADSpinnaker/spinnakerApp/op'
make[1]: Leaving directory '/home/ics/opt/areaDetector/ADSpinnaker/spinnakerApp'
make -C ./iocs install
make[1]: Entering directory '/home/ics/opt/areaDetector/ADSpinnaker/iocs'
make -C ./spinnakerIOC install
make[2]: Entering directory '/home/ics/opt/areaDetector/ADSpinnaker/iocs/spinnakerIOC'
make[3]: Entering directory '/home/ics/opt/areaDetector/ADSpinnaker/iocs/spinnakerIOC/configure'
mkdir O.Common
make[4]: Entering directory '/home/ics/opt/areaDetector/ADSpinnaker/iocs/spinnakerIOC/configure/O.linux-x86_64'
make[4]: Leaving directory '/home/ics/opt/areaDetector/ADSpinnaker/iocs/spinnakerIOC/configure/O.linux-x86_64'
make[3]: Leaving directory '/home/ics/opt/areaDetector/ADSpinnaker/iocs/spinnakerIOC/configure'
make[3]: Entering directory '/home/ics/opt/areaDetector/ADSpinnaker/iocs/spinnakerIOC/spinnakerApp'
make[4]: Entering directory '/home/ics/opt/areaDetector/ADSpinnaker/iocs/spinnakerIOC/spinnakerApp/src'
mkdir O.Common
make[5]: Entering directory '/home/ics/opt/areaDetector/ADSpinnaker/iocs/spinnakerIOC/spinnakerApp/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -I/home/ics/p4/tec/epics/asyn/trunk/include     -I/home/ics/opt/areaDetector/ADSupport/include/os/Linux -I/home/ics/opt/areaDetector/ADSupport/include   -I/home/ics/opt/areaDetector/ADCore/include -I/home/ics/p4/tec/epics/base/trunk/include/compiler/gcc -I/home/ics/p4/tec/epics/base/trunk/include/os/Linux -I/home/ics/p4/tec/epics/base/trunk/include        -MM -MF spinnakerAppMain.d  ../spinnakerAppMain.cpp
Creating dbd file spinnakerApp.dbd
perl -CSD /home/ics/p4/tec/epics/base/trunk/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I../../../../../dbd -I/home/ics/p4/tec/epics/asyn/trunk/dbd -I/home/ics/opt/areaDetector/ADCore/dbd -I/home/ics/p4/tec/epics/base/trunk/dbd -o spinnakerApp.dbd ADSpinnakerSupport.dbd base.dbd NDPluginSupport.dbd ADSupport.dbd NDFileNull.dbd NDFileNetCDF.dbd NDFileTIFF.dbd NDFileJPEG.dbd NDFileNexus.dbd NDFileHDF5.dbd asyn.dbd
perl -CSD /home/ics/p4/tec/epics/base/trunk/bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../dbd -I../../../../../dbd -I/home/ics/p4/tec/epics/asyn/trunk/dbd -I/home/ics/opt/areaDetector/ADCore/dbd -I/home/ics/p4/tec/epics/base/trunk/dbd    -o spinnakerApp_registerRecordDeviceDriver.cpp ../O.Common/spinnakerApp.dbd spinnakerApp_registerRecordDeviceDriver /home/ics/opt/areaDetector/ADSpinnaker/iocs/spinnakerIOC
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -I/home/ics/p4/tec/epics/asyn/trunk/include     -I/home/ics/opt/areaDetector/ADSupport/include/os/Linux -I/home/ics/opt/areaDetector/ADSupport/include   -I/home/ics/opt/areaDetector/ADCore/include -I/home/ics/p4/tec/epics/base/trunk/include/compiler/gcc -I/home/ics/p4/tec/epics/base/trunk/include/os/Linux -I/home/ics/p4/tec/epics/base/trunk/include        -MM -MF spinnakerApp_registerRecordDeviceDriver.d  spinnakerApp_registerRecordDeviceDriver.cpp
Installing created dbd file ../../../dbd/spinnakerApp.dbd
mkdir ../../../dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -I/home/ics/p4/tec/epics/asyn/trunk/include     -I/home/ics/opt/areaDetector/ADSupport/include/os/Linux -I/home/ics/opt/areaDetector/ADSupport/include   -I/home/ics/opt/areaDetector/ADCore/include -I/home/ics/p4/tec/epics/base/trunk/include/compiler/gcc -I/home/ics/p4/tec/epics/base/trunk/include/os/Linux -I/home/ics/p4/tec/epics/base/trunk/include        -c spinnakerApp_registerRecordDeviceDriver.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -I/home/ics/p4/tec/epics/asyn/trunk/include     -I/home/ics/opt/areaDetector/ADSupport/include/os/Linux -I/home/ics/opt/areaDetector/ADSupport/include   -I/home/ics/opt/areaDetector/ADCore/include -I/home/ics/p4/tec/epics/base/trunk/include/compiler/gcc -I/home/ics/p4/tec/epics/base/trunk/include/os/Linux -I/home/ics/p4/tec/epics/base/trunk/include        -c ../spinnakerAppMain.cpp
/usr/bin/g++ -o spinnakerApp -Wl,-Bstatic -L/home/ics/opt/areaDetector/ADSpinnaker/lib/linux-x86_64 -L/home/ics/opt/areaDetector/ADSpinnaker/iocs/spinnakerIOC/lib/linux-x86_64 -L/home/ics/opt/areaDetector/ADCore/lib/linux-x86_64 -L/home/ics/opt/areaDetector/ADSupport/lib/linux-x86_64 -L/home/ics/p4/tec/epics/asyn/trunk/lib/linux-x86_64 -L/home/ics/p4/tec/epics/base/trunk/lib/linux-x86_64 -Wl,-rpath,/home/ics/opt/areaDetector/ADSpinnaker/lib/linux-x86_64 -Wl,-rpath,/home/ics/opt/areaDetector/ADSpinnaker/iocs/spinnakerIOC/lib/linux-x86_64 -Wl,-rpath,/home/ics/opt/areaDetector/ADCore/lib/linux-x86_64 -Wl,-rpath,/home/ics/opt/areaDetector/ADSupport/lib/linux-x86_64 -Wl,-rpath,/home/ics/p4/tec/epics/asyn/trunk/lib/linux-x86_64 -Wl,-rpath,/home/ics/p4/tec/epics/base/trunk/lib/linux-x86_64           -rdynamic -m64            spinnakerApp_registerRecordDeviceDriver.o spinnakerAppMain.o    -lADSpinnaker -lNDPlugin -lADBase -lnetCDF -ltiff -ljpeg -lxml2 -lNeXus -lhdf5 -lblosc -lszip -lzlib -lasyn -ldbRecStd -ldbCore -lca -lCom -Wl,-Bdynamic -lSpinnaker -lGCBase_gcc540_v3_0 -lGenApi_gcc540_v3_0 -lNodeMapData_gcc540_v3_0 -lMathParser_gcc540_v3_0 -lXmlParser_gcc540_v3_0 -lLog_gcc540_v3_0 -lptgreyvideoencoder -lswscale-ffmpeg -lavcodec-ffmpeg -lpthread   -lreadline -lncurses -lm -lrt -ldl -lgcc
Installing created executable ../../../bin/linux-x86_64/spinnakerApp
mkdir ../../../bin
make[5]: Leaving directory '/home/ics/opt/areaDetector/ADSpinnaker/iocs/spinnakerIOC/spinnakerApp/src/O.linux-x86_64'
make[4]: Leaving directory '/home/ics/opt/areaDetector/ADSpinnaker/iocs/spinnakerIOC/spinnakerApp/src'
make[3]: Leaving directory '/home/ics/opt/areaDetector/ADSpinnaker/iocs/spinnakerIOC/spinnakerApp'
make -C ./iocBoot install
make[3]: Entering directory '/home/ics/opt/areaDetector/ADSpinnaker/iocs/spinnakerIOC/iocBoot'
make -C ./iocSpinnaker install
make[4]: Entering directory '/home/ics/opt/areaDetector/ADSpinnaker/iocs/spinnakerIOC/iocBoot/iocSpinnaker'
make[4]: Nothing to be done for 'install'.
make[4]: Leaving directory '/home/ics/opt/areaDetector/ADSpinnaker/iocs/spinnakerIOC/iocBoot/iocSpinnaker'
make[3]: Leaving directory '/home/ics/opt/areaDetector/ADSpinnaker/iocs/spinnakerIOC/iocBoot'
make[2]: Leaving directory '/home/ics/opt/areaDetector/ADSpinnaker/iocs/spinnakerIOC'
make[1]: Leaving directory '/home/ics/opt/areaDetector/ADSpinnaker/iocs'
and ldd of the executable:
> ldd spinnakerApp
	linux-vdso.so.1 =>  (0x00007ffc4ef81000)
	libSpinnaker.so.1 => /home/ics/opt/areaDetector/ADSpinnaker/lib/linux-x86_64/libSpinnaker.so.1 (0x00007ff734e78000)
	libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007ff734c41000)
	libreadline.so.6 => /lib/x86_64-linux-gnu/libreadline.so.6 (0x00007ff7349fa000)
	librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007ff7347f2000)
	libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007ff7345ee000)
	libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007ff73426b000)
	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007ff733f62000)
	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007ff733d4c000)
	libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007ff733981000)
	libusb-1.0.so.0 => /lib/x86_64-linux-gnu/libusb-1.0.so.0 (0x00007ff733769000)
	libGenApi_gcc540_v3_0.so => /home/ics/opt/areaDetector/ADSpinnaker/lib/linux-x86_64/libGenApi_gcc540_v3_0.so (0x00007ff733218000)
	libGCBase_gcc540_v3_0.so => /home/ics/opt/areaDetector/ADSpinnaker/lib/linux-x86_64/libGCBase_gcc540_v3_0.so (0x00007ff732ffc000)
	libptgreyvideoencoder.so.1 => /home/ics/opt/areaDetector/ADSpinnaker/lib/linux-x86_64/libptgreyvideoencoder.so.1 (0x00007ff732df9000)
	libgomp.so.1 => /usr/lib/x86_64-linux-gnu/libgomp.so.1 (0x00007ff732bd7000)
	/lib64/ld-linux-x86-64.so.2 (0x00005583a2072000)
	libtinfo.so.5 => /lib/x86_64-linux-gnu/libtinfo.so.5 (0x00007ff7329ad000)
	libudev.so.1 => /lib/x86_64-linux-gnu/libudev.so.1 (0x00007ff73298d000)
	libMathParser_gcc540_v3_0.so => /home/ics/opt/areaDetector/ADSpinnaker/lib/linux-x86_64/libMathParser_gcc540_v3_0.so (0x00007ff732780000)
	libXmlParser_gcc540_v3_0.so => /home/ics/opt/areaDetector/ADSpinnaker/lib/linux-x86_64/libXmlParser_gcc540_v3_0.so (0x00007ff732440000)
	libLog_gcc540_v3_0.so => /home/ics/opt/areaDetector/ADSpinnaker/lib/linux-x86_64/libLog_gcc540_v3_0.so (0x00007ff732236000)
	libNodeMapData_gcc540_v3_0.so => /home/ics/opt/areaDetector/ADSpinnaker/lib/linux-x86_64/libNodeMapData_gcc540_v3_0.so (0x00007ff732018000)
	libswscale-ffmpeg.so.3 => /usr/lib/x86_64-linux-gnu/libswscale-ffmpeg.so.3 (0x00007ff731d89000)
	libavcodec-ffmpeg.so.56 => /usr/lib/x86_64-linux-gnu/libavcodec-ffmpeg.so.56 (0x00007ff730957000)
	libavutil-ffmpeg.so.54 => /usr/lib/x86_64-linux-gnu/libavutil-ffmpeg.so.54 (0x00007ff7306e8000)
	libavformat-ffmpeg.so.56 => /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56 (0x00007ff7302e9000)
	libswresample-ffmpeg.so.1 => /usr/lib/x86_64-linux-gnu/libswresample-ffmpeg.so.1 (0x00007ff7300cb000)
	libva.so.1 => /usr/lib/x86_64-linux-gnu/libva.so.1 (0x00007ff72feaf000)
	libzvbi.so.0 => /usr/lib/x86_64-linux-gnu/libzvbi.so.0 (0x00007ff72fc23000)
	libxvidcore.so.4 => /usr/lib/x86_64-linux-gnu/libxvidcore.so.4 (0x00007ff72f90f000)
	libx265.so.79 => /usr/lib/x86_64-linux-gnu/libx265.so.79 (0x00007ff72ecf0000)
	libx264.so.148 => /usr/lib/x86_64-linux-gnu/libx264.so.148 (0x00007ff72e94b000)
	libwebp.so.5 => /usr/lib/x86_64-linux-gnu/libwebp.so.5 (0x00007ff72e6ef000)
	libwavpack.so.1 => /usr/lib/x86_64-linux-gnu/libwavpack.so.1 (0x00007ff72e4c6000)
	libvpx.so.3 => /usr/lib/x86_64-linux-gnu/libvpx.so.3 (0x00007ff72e0a1000)
	libvorbisenc.so.2 => /usr/lib/x86_64-linux-gnu/libvorbisenc.so.2 (0x00007ff72ddf8000)
	libvorbis.so.0 => /usr/lib/x86_64-linux-gnu/libvorbis.so.0 (0x00007ff72dbcd000)
	libtwolame.so.0 => /usr/lib/x86_64-linux-gnu/libtwolame.so.0 (0x00007ff72d9a9000)
	libtheoraenc.so.1 => /usr/lib/x86_64-linux-gnu/libtheoraenc.so.1 (0x00007ff72d76a000)
	libtheoradec.so.1 => /usr/lib/x86_64-linux-gnu/libtheoradec.so.1 (0x00007ff72d550000)
	libspeex.so.1 => /usr/lib/x86_64-linux-gnu/libspeex.so.1 (0x00007ff72d336000)
	libsnappy.so.1 => /usr/lib/x86_64-linux-gnu/libsnappy.so.1 (0x00007ff72d12e000)
	libshine.so.3 => /usr/lib/x86_64-linux-gnu/libshine.so.3 (0x00007ff72cf21000)
	libschroedinger-1.0.so.0 => /usr/lib/x86_64-linux-gnu/libschroedinger-1.0.so.0 (0x00007ff72cc4b000)
	libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007ff72ca31000)
	libopus.so.0 => /usr/lib/x86_64-linux-gnu/libopus.so.0 (0x00007ff72c7e7000)
	libopenjpeg.so.5 => /usr/lib/x86_64-linux-gnu/libopenjpeg.so.5 (0x00007ff72c5c3000)
	libmp3lame.so.0 => /usr/lib/x86_64-linux-gnu/libmp3lame.so.0 (0x00007ff72c34e000)
	libgsm.so.1 => /usr/lib/x86_64-linux-gnu/libgsm.so.1 (0x00007ff72c140000)
	libcrystalhd.so.3 => /usr/lib/x86_64-linux-gnu/libcrystalhd.so.3 (0x00007ff72bf24000)
	liblzma.so.5 => /lib/x86_64-linux-gnu/liblzma.so.5 (0x00007ff72bd02000)
	libssh-gcrypt.so.4 => /usr/lib/x86_64-linux-gnu/libssh-gcrypt.so.4 (0x00007ff72bab8000)
	librtmp.so.1 => /usr/lib/x86_64-linux-gnu/librtmp.so.1 (0x00007ff72b89c000)
	libmodplug.so.1 => /usr/lib/x86_64-linux-gnu/libmodplug.so.1 (0x00007ff72b511000)
	libgme.so.0 => /usr/lib/x86_64-linux-gnu/libgme.so.0 (0x00007ff72b2c2000)
	libbluray.so.1 => /usr/lib/x86_64-linux-gnu/libbluray.so.1 (0x00007ff72b079000)
	libgnutls.so.30 => /usr/lib/x86_64-linux-gnu/libgnutls.so.30 (0x00007ff72ad49000)
	libbz2.so.1.0 => /lib/x86_64-linux-gnu/libbz2.so.1.0 (0x00007ff72ab38000)
	libsoxr.so.0 => /usr/lib/x86_64-linux-gnu/libsoxr.so.0 (0x00007ff72a8d3000)
	libpng12.so.0 => /lib/x86_64-linux-gnu/libpng12.so.0 (0x00007ff72a6ad000)
	libnuma.so.1 => /usr/lib/x86_64-linux-gnu/libnuma.so.1 (0x00007ff72a4a2000)
	libogg.so.0 => /usr/lib/x86_64-linux-gnu/libogg.so.0 (0x00007ff72a298000)
	liborc-0.4.so.0 => /usr/lib/x86_64-linux-gnu/liborc-0.4.so.0 (0x00007ff72a018000)
	libgcrypt.so.20 => /lib/x86_64-linux-gnu/libgcrypt.so.20 (0x00007ff729d36000)
	libgssapi_krb5.so.2 => /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2 (0x00007ff729aec000)
	libhogweed.so.4 => /usr/lib/x86_64-linux-gnu/libhogweed.so.4 (0x00007ff7298b9000)
	libnettle.so.6 => /usr/lib/x86_64-linux-gnu/libnettle.so.6 (0x00007ff729682000)
	libgmp.so.10 => /usr/lib/x86_64-linux-gnu/libgmp.so.10 (0x00007ff729402000)
	libxml2.so.2 => /usr/lib/x86_64-linux-gnu/libxml2.so.2 (0x00007ff729047000)
	libfontconfig.so.1 => /usr/lib/x86_64-linux-gnu/libfontconfig.so.1 (0x00007ff728e03000)
	libfreetype.so.6 => /usr/lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007ff728b59000)
	libp11-kit.so.0 => /usr/lib/x86_64-linux-gnu/libp11-kit.so.0 (0x00007ff7288f5000)
	libidn.so.11 => /usr/lib/x86_64-linux-gnu/libidn.so.11 (0x00007ff7286c1000)
	libtasn1.so.6 => /usr/lib/x86_64-linux-gnu/libtasn1.so.6 (0x00007ff7284ae000)
	libgpg-error.so.0 => /lib/x86_64-linux-gnu/libgpg-error.so.0 (0x00007ff728299000)
	libkrb5.so.3 => /usr/lib/x86_64-linux-gnu/libkrb5.so.3 (0x00007ff727fc7000)
	libk5crypto.so.3 => /usr/lib/x86_64-linux-gnu/libk5crypto.so.3 (0x00007ff727d98000)
	libcom_err.so.2 => /lib/x86_64-linux-gnu/libcom_err.so.2 (0x00007ff727b93000)
	libkrb5support.so.0 => /usr/lib/x86_64-linux-gnu/libkrb5support.so.0 (0x00007ff727988000)
	libicuuc.so.55 => /usr/lib/x86_64-linux-gnu/libicuuc.so.55 (0x00007ff7275f4000)
	libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007ff7273ca000)
	libffi.so.6 => /usr/lib/x86_64-linux-gnu/libffi.so.6 (0x00007ff7271c2000)
	libkeyutils.so.1 => /lib/x86_64-linux-gnu/libkeyutils.so.1 (0x00007ff726fbd000)
	libresolv.so.2 => /lib/x86_64-linux-gnu/libresolv.so.2 (0x00007ff726da2000)
	libicudata.so.55 => /usr/lib/x86_64-linux-gnu/libicudata.so.55 (0x00007ff7252eb000)
Cheers,
Andraz
-----Original Message-----
Sent: Monday, September 24, 2018 11:27 PM
To: POZAR, Andraz <[email protected]>
Cc: [email protected]
Please send the complete output when you build ADSpinnaker.  Since Mark Engbretson said it worked for him there must be some difference.  Also send the output of ldd on the executable.
BlackFly S with ADSpinnaker [SEC=UNCLASSIFIED] POZAR, Andraz
Re: BlackFly S with ADSpinnaker [SEC=UNCLASSIFIED] Mark Rivers
RE: BlackFly S with ADSpinnaker [SEC=UNCLASSIFIED] POZAR, Andraz
RE: BlackFly S with ADSpinnaker [SEC=UNCLASSIFIED] Mark Rivers
Prev: Linux PREEMPT-RT kernel tuning example for EPICS IOC Jeong Han Lee
Next: RE: Fanout PV to many records Abdalla Ahmad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: BlackFly S with ADSpinnaker [SEC=UNCLASSIFIED] Mark Rivers
Next: RE: BlackFly S with ADSpinnaker [SEC=UNCLASSIFIED] Engbretson, Mark S.
ANJ, 25 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
